#61
"WingFlaps" wrote in message ... On Mar 13, 1:16 pm, "Vaughn Simon" wrote: As I read it, this is not VFR it's an IF test... I read it that way also, which is why I suitably qualified my answer Cheers back atcha Vaughn |
#62
"Dudley Henriques" wrote in message ... Any stall in the pattern can be a serious problem. You need stall and yaw rate to induce spin. Of all the possible scenarios to have if you manage to be ham handed enough to get into a stall in the pattern, a stall from a slip is the most anti-spin. Then comes a coordinated stall with no yaw induced at the break, and finally the worst condition is a stall from a skidding turn. No matter which scenario, angle of attack MUST be lowered, and any yaw rate MUST be neutralized IMMEDIATELY! -- Dudley Henriques Can you please elaborate on the stall from a slip condition. I am fond of the bush pilot style pattern, using180 degree constant slipping turn to final and would also be interested in your thoughts on these. TIA Happy landings, |
#63
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote in message
news:tOKdnXSOOaMvyEXanZ2dnUVZ_vamnZ2d@wideopenwest .com... Stall speed changes with increasing G (increasing lift). Increasing G comes Strictly speaking, the increasing G correlates to an increasing coefficient of lift which comes from an increasing angle of attack which comes from the moment generated by the tail which comes from an increasing pull (assuming a constant airspeed). (just trying to get a head start on the nit picking) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#64
Private wrote:
"Dudley Henriques" wrote in message ... Any stall in the pattern can be a serious problem. You need stall and yaw rate to induce spin. Of all the possible scenarios to have if you manage to be ham handed enough to get into a stall in the pattern, a stall from a slip is the most anti-spin. Then comes a coordinated stall with no yaw induced at the break, and finally the worst condition is a stall from a skidding turn. No matter which scenario, angle of attack MUST be lowered, and any yaw rate MUST be neutralized IMMEDIATELY! -- Dudley Henriques Can you please elaborate on the stall from a slip condition. I am fond of the bush pilot style pattern, using180 degree constant slipping turn to final and would also be interested in your thoughts on these. TIA Happy landings, I see no problems at all with a constant slipping turn approach, and in fact favor this type myself when flying prop fighters such as the P51 and the F8F and even the Pitts Spcial due to the better visibility during these approaces over the nose and ahead and inside the turn as the approach is flown. Slips are basically anti spin. You can actually increase the angle of attack available in front of your critical angle of attack as you deepen a slip. The ultimate example of this would be knife edge flight where forward stick pressure is required to reduce angle of attack to near the 0 lift point on the wing. Of course you won't be doing any knife edge flight on a slipping approach, but the slip you are in is still anti spin. Even if you stall the airplane in a slip, the likely result will be a break over the top, which is a much better stall break than a skidding stall break which will usually break under the bottom. You have much more time to recover from a slipping stall entry than you do from a skid entry. The bottom line is that it's quite safe to fly a slipping approach if you are aware, flying properly and watching what you are doing. -- Dudley Henriques |
#65
On Mar 13, 9:14*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
D0t C0m wrote: "skym" wrote in message ... While making a turn to base and final recently, I was aware that I was going to be wide with my normal turn from downwind through base to final, so I banked more to keep as close to the runway centerline as possible. *I kept thinking about the infamous and usually fatal stall/ spin by some pilots in this situation, *I kept thinking that if I keep the ball centered, even with a very steep bank, that I would be ok and not auger in. *Some of you instructors and old pros...is this correct? (Not that I intend to make it a practice.) Instead of asking about keeping the ball centered, perhaps you should be asking why you elected to flirt with a pilot error fatality by cranking and yanking for the sake of a few style points... So what if you overshoot the turn???? Note: as others are beating to death - stall speed doesn't change with bank. Stall speed changes with increasing G (increasing lift). Increasing G comes from pulling on the yoke/stick. Period. No pull, no G, no increase in stall. More pull, more G, higher stall. *Wings level, wings banked, wings upside down - makes no difference. so if i am doing a steep descending turn , I wont be pulling back on the stick as much as a steep level turn, hence less g ? This would seem to contradict others comments that you pull the same no of g in a bank whether it is level or descending. I am still confused. Terry |
#66
On Mar 13, 9:35*am, "Vaughn Simon"
wrote: "Dudley Henriques" wrote in message ... Exactly. The difference between a loaded turn and simply allowing the nose to fall through with reduced back pressure. * *Reducing back pressure is something an inexperienced pilot is instinctively loath to do when manuvering close to the ground, much more likely to be pulling. on the contrary I have a habit of deliberately pushing forward on the yoke as I turn onto final, it comes from a fear of stalling and the fact that being at this stage of the landing procedure I want my attention focused outside the cockpit to ensure I line up out of the turn on the runway centerline, and not worrying about my airspeed. Terry |
#67
terry wrote:
On Mar 13, 9:35 am, "Vaughn Simon" wrote: "Dudley Henriques" wrote in message ... Exactly. The difference between a loaded turn and simply allowing the nose to fall through with reduced back pressure. Reducing back pressure is something an inexperienced pilot is instinctively loath to do when manuvering close to the ground, much more likely to be pulling. on the contrary I have a habit of deliberately pushing forward on the yoke as I turn onto final, it comes from a fear of stalling and the fact that being at this stage of the landing procedure I want my attention focused outside the cockpit to ensure I line up out of the turn on the runway centerline, and not worrying about my airspeed. Terry You had good instruction Terry. I'd only add for you to monitor your airspeed as well. In other words, never omit an available cue. "We don't fly in a single cue world" Chris Patterakis USAF Thunderbirds Lead -- Dudley Henriques |
#69
"Jim Stewart" wrote in message .. . My instructor carefully pointed out the difference between a stall on final as opposed to a snap spin. I suspect a misuse in terminology, IMHO normal usage of the term 'snap' is to refer to a 'snap roll' (or as the Brits would say, 'flick roll') which is a roll performed with (loading and) rudder only and is really a spin in the logitudinal plane or direction of flight. A stall might be recoverable with no more damage than a looseness of the bowels whereas a spin could really fsk up your day. The gist of his advice was that if you keep the turn coordinated or even add a little extra aileron, the up wing will have to come all the way down through level before it will spin, giving you time get the nose down and level the wings before that spin can develop. IMHO, a combination of stall and yaw in a decending turn (arrival stall) is most likely to result in a spin under the bottom, where the aircraft will enter the spin by dropping the lower or inside wing. On the other hand, a stall combined with yaw in a climbing turn (departure stall) is most likely to result in a spin over the top where the aircraft will enter the spin by dropping the upper or outside wing. I suspect that you or your instructor may be confusing the two. Your instructor is correct that most consider a slip to be more spin resistant than a skid and some/most will maintain that a turning slip is even more spin resistant than cordinated flight. IMHO stall/spin awareness training should include lots of demonstrations (at safe altitude (where recover is made @2000')) of at least incipient (and preferably full spin) spin entry (and recovery) from both arrival and departure stall spins and demonstrations of the circumstances likely to lead to each. OTOH, a flat turn to final can quickly develop into a spin before you can get it under control. IMHO, A flat turn is most likely to be a skid, which most consider to be the uncoordinated condition most likely to result in a spin. Happy landings, |
#70
WJRFlyBoy wrote:
On Wed, 12 Mar 2008 13:46:16 +0000 (UTC), Bertie the Bunyip wrote: Tina wrote in news:874d408e-73e6-4064-8d08- : I don't think anyone has suggested this, but there is a nearly universal cure if you find yourself uncomfortably out of a reasonable approach condition -- simply say to yourself this isn't looking good enough, go around, and do better the next time. It's my uneducated opinion that too many perfectly good airplanes get turned to scrap because pilots continue to commit to an action that has become untenable. You have a hand on the throttle and it's important to remember to be ready to push it in if you don't like the way things are shaping up. Absolutely. Don't let ego get in the way of good judgement. True again. Sometimes it's not ego, though. A lot of thigs come into play, especially if conditions are tough. It's a curious thing, the sort of single-mindedness that often accompanies an accident. Bertie Lesson here is go-around if concerned and make sure you are preset for that option? Well trained pilots will fly the approach treating it as a constantly changing dynamic. They will be planning for the next anticipated action based on all prevailing cues. Along with this they will have an accompanying exit plan keyed by any expected parameter not being met by any of these cues. The go around trigger should occur if a critical parameter isn't met. Each pilot will have a different trigger level based on various human factors involving the pilot's training and his/her mental processing in play on the approach. This is the pedantic version of "If it don't look good, it usually ain't no good......take it around!! :-))" -- Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Implications of.....keeping the speed up | [email protected] | Instrument Flight Rules | 48 | January 15th 07 12:41 AM |
| Gamepad, stopping throttle axis from being auto-centered | DenisK | Simulators | 1 | December 20th 06 10:16 AM |
| Keeping a builders log | Lou | Home Built | 24 | January 28th 06 11:46 PM |
| Thanks for ideas on drilling a centered hole! | Scott | Home Built | 12 | October 25th 04 03:52 AM |
| Keeping Me Out of Your Warbird? | Stephen Harding | Military Aviation | 47 | February 12th 04 05:34 PM |
