volkslogger connection?
Why there are two +12v and -12v pins in volkslogger? Should I connect
both pins to battery? |
pete83 wrote:
Why there are two +12v and -12v pins in volkslogger? Should I connect both pins to battery? There are two +12V and two GND pins. Both sets should be hooked up to the glider power supply. The reason there are two sets is to reduce the current through the relatively small individual wires in the cable. Marc |
pete83 a pensé très fort :
Why there are two +12v and -12v pins in volkslogger? Should I connect both pins to battery? Hi Have a look : http://www.planeur.net/telecharger/vl.htm Frederic www.planeur.net -- www.planeur.net - www.netcoupe.net |
Similar Threads | ||||
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo | Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT | Naval Aviation | 4 | April 3rd 04 03:17 AM |
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo | Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT | General Aviation | 4 | April 3rd 04 03:17 AM |
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo | Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT | Owning | 4 | April 3rd 04 03:17 AM |
Volkslogger flight log problem | Bill Staley | Soaring | 1 | October 7th 03 03:26 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
