Short SC.1
https://en.wikipedia.org/wiki/Short_SC.1
The Short SC.1 was the first British fixed-wing vertical take-off and landing (VTOL) jet aircraft. It was developed by Short Brothers. It was powered by an arrangement of five Rolls-Royce RB108 turbojets, four of which were used for vertical flight and one for conventional horizontal flight. The SC.1 had the distinction of being the first British fixed-wing VTOL aircraft and the first one to transition between vertical and horizontal flight modes; it was also the first VTOL-capable aircraft with a fly-by-wire control system. The SC.1 was designed and produced in response to a Ministry of Supply (MoS) requirement for a suitable aircraft for conducting flight studies into VTOL flight, as well as specifically into the transition between vertical and horizontal flight. Two prototypes were used for flight testing between 1957 and 1971. Research data from the SC.1 test programme contributed to the development of the Hawker Siddeley P.1127 and the subsequent Hawker Siddeley Harrier, the first operational VTOL aircraft. In October 2012, the Short SC.1 received Northern Ireland's first Engineering Heritage Award as a recognition of its significant achievement in the engineering field. The SC.1 has its origins in a submission by Short Brothers to meet a Ministry of Supply (MoS) request for tender (ER.143T) for a vertical take-off research aircraft, which had been issued in September 1953. On 15 October 1954, the proposed design was accepted by the Ministry and a contract was promptly placed for two aircraft to meet Specification ER.143D. As envisioned, the aircraft was to be used for a series of flight tests to investigate its behaviour during the transition between vertical and horizontal flight modes, to determine the optimum and minimum level of assistance required from the auto-stabiliser during the transition process, to uncover likely operational issues, and to develop related support aids and equipment for the pilot to develop an all-weather approach and landing system. Short constructed two prototypes, designated XG900 and XG905. The Short SC.1 was a single-seat low wing tailless delta wing aircraft of approximately 8,000 lb all-up weight (max. 7,700 lb for vertical flight). It was powered by four vertically-mounted, lightweight Rolls-Royce RB108 lift engines that provided a total vertical thrust of 8,600 lb, along with a single RB.108 cruise engine in the rear of the aircraft to provide thrust for forward flight. The lift engines were mounted vertically in side-by-side pairs in a central bay so that their resultant thrust line passed close to the centre of gravity of the aircraft. These pairs of engines could be swivelled fore-and-aft to produce vectored thrust for acceleration/deceleration along the aircraft's longitudinal axis. During conventional flight, the lift engines would be shut down; before beginning the transition from horizontal to vertical flight, they would be started using compressed air from the single cruise engine. The compressed air provided the initial rotation of the engine but a pressure drop from intake to exhaust had to be present also as the compressed air alone was not adequate for reaching idle speed. Considerable wind-tunnel and flight development of the air intake was required because at the start of transition from horizontal flight vertically-mounted engines have to tolerate a crosswind equal to the forward flight speed without surging or excessive vibrations. The required uniformity of flow was achieved with the help of a set of 7 hinged gills which opened to a forward-facing position to direct air into a plenum which supplied the engines. The behaviour of a vertically-mounted RB108 in terms of re-ingestion and ground erosion had been investigated with an installation representative of that intended for the SC.1 during ground operation in a Meteor at Hucknall Aerodrome. Initially, a series of scuttles were fitted to the exit nozzles of the lift engines to maintain a low-pressure environment beneath the engines to ensure that the engine rotor would be "windmilling" in the correct direction prior to supplying the compressed air for starting; due to the effectiveness of intake and engine design changes, the scuttles became unnecessary. The cockpit layout was mainly conventional, but complicated by the large number of systems the pilot had to monitor. For its role as a research aircraft it had comprehensive recording equipment. Role Experimental aircraft Manufacturer Short Brothers Designer Hugh Graham Convay (Shorts chief engineer) First flight 2 April 1957 (CTOL) 26 May 1958 (VTOL) Retired 1971 Status Retired and preserved Primary user Royal Aircraft Establishment Number built 2 Constructed at Short's Belfast factory in Northern Ireland, the first SC.1 prototype, XG900, first undertook initial engine runs at this facility. After being transported by sea to England, XG900, which was initially fitted only with the propulsion engine, was delivered to the Royal Aircraft Establishment (RAE) at Boscombe Down to begin the flight test programme. On 2 April 1957, the prototype conducted the type's maiden flight, which was also its first conventional takeoff and landing (CTOL) flight. As a result of ground suitability tests, it was determined that conventional runway concrete, pavement, and even grass strips would be adequate for vertical takeoff and landing of the SC.1; however, debris that may be forced out from imperfect surfaces would pose a risk to personnel but not to the aircraft itself. The test programme also allowed experience upon the maintenance and serviceability of a VTOL aircraft to be acquired, even though these were not primary objectives of the design nor the research effort; throughout the programme, an overall average of 2.6 flights were performed per week. While numerous errors with the auto-stabiliser were reported during flights, no fault ever occurred that endangered the aircraft or had any effect upon its control. Testing found significant difficulty in measuring actual engine thrust, leading to further tests using improved intakes and instrumentation. Ultimately, the engines proved to be far less problematic than might have been expected considering the experimental nature of the aircraft and its power-plants; and when faults occurred in the triplex auto-stabiliser they were easy to locate, in part due to the system's self-checking nature. According to a Ministry of Aviation report, the SC.1 was determined to have been an effective research vehicle when operated within the limits imposed by its small size and restricted capacity; however it was found that a larger aircraft would be necessary for more extensive tests of the instruments and guidance equipment. The SC.1 flew for over ten years, during which it provided a great deal of data that served to influence later design concepts such as the "puffer jet" controls on the Hawker Siddeley P.1127, the precursor of the Hawker Siddeley Harrier. The flight testing work relating to vertical takeoff and landing techniques and technologies also proved to be invaluable, and helped further Britain's lead in the field. The Short SC.1 was ultimately rendered obsolete by the emerging Harrier which, amongst other things, proved that it was unnecessary to carry an additional four engines solely for the purposes of lift-off and landing. Specifications General characteristics Crew: 1 Length: 25 ft 6 in (7.77 m) Wingspan: 23 ft 6 in (7.16 m) Height: 10 ft 8 in (3.25 m) Wing area: 211.5 sq ft (19.65 m2) Aspect ratio: 2.61:1 Airfoil: NACA 0010 Empty weight: 6,260 lb (2,839 kg) Gross weight: 7,700 lb (3,493 kg) (VTOL operations) Max takeoff weight: 8,050 lb (3,651 kg) (CTOL operations) Powerplant: 1 × Rolls-Royce RB108 turbojet, 2,130 lbf (9.5 kN) thrust (forward flight) Powerplant: 4 × Rolls-Royce RB108 turbojets, 2,130 lbf (9.5 kN) thrust each Performance Maximum speed: 246 mph (396 km/h, 214 kn) Range: 150 mi (240 km, 130 nmi) Service ceiling: 8,000 ft (2,400 m) Rate of climb: 700 ft/min (3.6 m/s) Wing loading: 38.1 lb/sq ft (186 kg/m2) Thrust/weight: (CTOL): 0.265 (VTOL): 1.11 * |
Similar Threads | ||||
Short Empire pics 3 [3/8] - Short Empire_VH-ABB inside.jpg (1/1) | Miloch | Aviation Photos | 0 | April 27th 19 02:42 PM |
Short Empire pics 3 [2/8] - Short Empire_VH-ABB cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | April 27th 19 02:42 PM |
Short Empire pics [1/8] - airplane-decor-short-sunderland.jpg (1/1) | Miloch | Aviation Photos | 0 | April 27th 19 02:38 PM |
Short Sunderland Flying Boat pics [14/21] - Short Mayo 1938.jpg (1/1) | Miloch | Aviation Photos | 0 | September 2nd 16 09:06 PM |
