Mode S overload
An interesting article just appeared in Aviation Ebrief:
"Holland's trial of Mode-S transponders led to a requirement that all aircraft operating within Dutch airspace be equipped with the transponders. However, the ATC system was overwhelmed by data from the Mode-S transponders, and now all aircraft flying below 1,200 feet are required to keep the transponders on standby." Here's a link to the full article: http://www.ainonline.com/news/single...le-in-holland/ I wonder how much testing and simulation has been done for busy US terminal areas? Charlie |
Mode S overload
There is a lot of concern in the US that the Mode S bandwidth is too limited
to support universal deployment in busy airspace like Chicago, Atlanta, New York. This is one reason that the FAA has selected ADS-B UAT instead of the Mode S based extended squitter technology for general aviation users in the US. Mike Schumann "cfinn" wrote in message ... An interesting article just appeared in Aviation Ebrief: "Holland's trial of Mode-S transponders led to a requirement that all aircraft operating within Dutch airspace be equipped with the transponders. However, the ATC system was overwhelmed by data from the Mode-S transponders, and now all aircraft flying below 1,200 feet are required to keep the transponders on standby." Here's a link to the full article: http://www.ainonline.com/news/single...le-in-holland/ I wonder how much testing and simulation has been done for busy US terminal areas? Charlie |
Mode S overload
On Sep 29, 6:20*pm, "Mike Schumann" mike-nos...@traditions-
nospam.com wrote: There is a lot of concern in the US that the Mode S bandwidth is too limited to support universal deployment in busy airspace like Chicago, Atlanta, New York. This is one reason that the FAA has selected ADS-B UAT instead of the Mode S based extended squitter technology for general aviation users in the US. Mike Schumann "cfinn" wrote in message ... An interesting article just appeared in Aviation Ebrief: "Holland's trial of Mode-S transponders led to a requirement that all aircraft operating within Dutch airspace be equipped with the transponders. However, the ATC system was overwhelmed by data from the Mode-S transponders, and now all aircraft flying below 1,200 feet are required to keep the transponders on standby." Here's a link to the full article: http://www.ainonline.com/news/single...mode-s-rule-pr... I wonder how much testing and simulation has been done for busy US terminal areas? Charlie What appears to have happened in the article about Schiphol is the system/operators were just overloaded with information. If the article is to be believed sounds just like poor planning. That is different than the fundamental design type arguments about Mode S capacity that Mike is referring to. The interest there is really ADS-B over Mode S (aka 1090ES) or over UAT. The Schiphol deployment is just the European mandated Mode S surveillance, not a full ADS-B deployment. There is disagreement between the Europeans and the US on Mode S directions and long term Mode S capacity. The Europeans basically believe Mode S will evolve to handle capacity concerns and pushed ahead that way. On one level they are getting things to happen. Products like the Trig TT21 which we get now over here is us benefit from European regulations pushing Mode S innovation. The FAA's more ambitious goals and therefor longer timeframes for ADS-B and Nextgen mean its going to be a while until we see what really happens here. One possibility is thanks to Europe Mode S deployments and the driver that has on products that Mode S and 1090ES will be more prevalent here in the GA fleet than the FAA envisioned. And after all ADS-B does not replace the need for a transponder for TCAS avoidance and so basic Mode S transponders are likely to be used in the GA fleet for some time. The interesting question is how ADS-B integrated. And UAT has the promise of extra data (FIS-B) vs. 1090ES. We'll have to see what happens. Bottom line for now is, especially if you fly in areas of airline/fast jet traffic, a transponder is likely a good investment. And if you fly near Reno *please* use one. A Mode S transponder having the benefit over a Mode C of having a greater than ~ 10 year life by surviving the USA Mode S requirement. Darryl |
Mode S overload
Darryl Ramm wrote:
And after all ADS-B does not replace the need for a transponder for TCAS avoidance and so basic Mode S transponders are likely to be used in the GA fleet for some time. The interesting question is how ADS-B integrated. Some manufactorers claim that their mode S transponders will be upgradable to ADS-B. |
Mode S overload
On Sep 30, 12:54*am, John Smith wrote:
Darryl Ramm wrote: And after all ADS-B does not replace the need for a transponder for TCAS avoidance and so basic Mode S transponders are likely to be used in the GA fleet for some time. The interesting question is how ADS-B integrated. Some manufactorers claim that their mode S transponders will be upgradable to ADS-B. Ah yes. But what ADS-B? That is 1090ES which just about all Mode S transponders now will support. Plug in a certified GPS and you should have ADS-B Dara out over 1090ES but you may or may not have ADS-B data in for TIS on that transponder and you cannot get FIS-B data services (e.g. Weather info) over 1090ES, for that you will need a UAT. I tried to make clear the ADS-B capabilities of the Trig and Becker Mode S transponders is described in the transponder comparison table at Cumulus soaring |
Similar Threads | ||||
New transponder mode S vs. mode C | Tom N. | Soaring | 39 | November 7th 06 07:40 AM |
Mode S transponders | Wallis | Home Built | 4 | March 10th 05 10:33 AM |
Mode C Indication | Jeff | Owning | 9 | May 5th 04 03:35 AM |
IFR training material overload | Brian H | Instrument Flight Rules | 7 | March 19th 04 04:35 PM |
Mode S questoin | JerryK | Instrument Flight Rules | 1 | July 17th 03 09:56 PM |
