IO 470 Fouled Plug
Old January 28th 06, 02:10 AM posted to rec.aviation.owning
Default IO 470 Fouled Plug
My engine analyzed is telling me that the spark plug on the #6
cylinder, left mag is fouled. I have a new plug, but can't tell which
cylinder #6 is and whether it's the plug on the top or the bottom....
Can anyone tell me which plug it is...?
Thanks much,
Anthony
Old January 28th 06, 03:30 AM posted to rec.aviation.owning
Number 6 is the rearmost cylinder. Trace the wires to work out which plug is
connected to the left mag.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 28th 06, 04:24 AM posted to rec.aviation.owning
I think that the cylinders are numbered on the intake manifold. THe
number is cast right into the manifold. Also, I believe that the bottom
plugs are the ones that tend to foul. Did you try to do a lean runup to
try and "un-foul" the plug? I have had good luck doing that.
Jon Kraus
'79 Mooney 201
4443H @ TYQ
Thanks much,
Anthony
Old January 28th 06, 04:29 AM posted to rec.aviation.owning
In article YyBCf.1306$Ix.796@trnddc07,
George Patterson
I have an old Continental Operators's handbook (for the E-225 series),
which shows #1 as rifgt rear, #6 is left front. I doubt that Continental
has changed their numbering system on the O-470 series.
On a Lycoming, #1 is right front; #6 is left rear.
Remve "_" from email to reply to me personally.
Old January 28th 06, 04:56 AM posted to rec.aviation.owning
According to my A&P at the time, right front was #1 on my Continental O-200.
George Patterson
Old January 28th 06, 05:01 AM posted to rec.aviation.owning
"George Patterson" wrote in message
news:mQCCf.13187$K17.13085@trnddc03...
O-200.
George Patterson
Right rear is #1 on an O-200. Left front is #4.
Old January 28th 06, 05:17 AM posted to rec.aviation.owning
"Prooving" that on different engines there are different numbering
schemes.
Old January 28th 06, 01:40 PM posted to rec.aviation.owning
O-200.
Lycomings have the numbers stamped right in the engine case. Don't
Continentals?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 28th 06, 01:42 PM posted to rec.aviation.owning
Thanks much,
Anthony
#6 should be the front most cylinder.
Look at the plug leads mine are labeled T1, B1,T2,B2, etc.
Michelle
Old January 28th 06, 01:44 PM posted to rec.aviation.owning
"Jay Honeck" wrote in message
news:hvKCf.517589$084.337062@attbi_s22...
O-200.
Continentals?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Yes, they are cast into the case.
Fouled plug IO 470 [email protected] General Aviation 7 January 29th 06 06:03 PM
Plug fouled Denny Owning 9 September 2nd 05 05:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 10:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Clearing a fouled plug Roger Long Piloting 3 July 6th 04 05:53 AM
