Alcohol in Fuel
I'm starting to notice a lot more pumps around these days with a
notice that they may contain up to 10% ethanol in the fuel mixture... Of course, they kind of puts a crimp in my autogas STC for my plane, but it got me to thinking if there might be a way to separate out the alcohol from the fuel mixture... The bio-diesel folks mix alcohol and lye with their veggie oil while they are making their fuel and then 'wash' the fuel later by adding water to it and either draining the water and glycerin from the bottom or pump the bio-diesel off the top... Could we do something like that with autogas? We wouldn't need the lye part of it, but wouldn't the water mix with the alcohol and settle to the bottom? |
Alcohol in Fuel
Yes. It would settle.. and what remains will be a lower octane grade of
gasoline. Sounds like a plan, but can get to be a pain with large quantities. Dave Grumman-581 wrote: I'm starting to notice a lot more pumps around these days with a notice that they may contain up to 10% ethanol in the fuel mixture... Of course, they kind of puts a crimp in my autogas STC for my plane, but it got me to thinking if there might be a way to separate out the alcohol from the fuel mixture... The bio-diesel folks mix alcohol and lye with their veggie oil while they are making their fuel and then 'wash' the fuel later by adding water to it and either draining the water and glycerin from the bottom or pump the bio-diesel off the top... Could we do something like that with autogas? We wouldn't need the lye part of it, but wouldn't the water mix with the alcohol and settle to the bottom? |
Alcohol in Fuel
Would this violate the STC? I've been kind of wondering the same thing.
mike "Dave S" wrote in message nk.net... Yes. It would settle.. and what remains will be a lower octane grade of gasoline. Sounds like a plan, but can get to be a pain with large quantities. Dave Grumman-581 wrote: I'm starting to notice a lot more pumps around these days with a notice that they may contain up to 10% ethanol in the fuel mixture... Of course, they kind of puts a crimp in my autogas STC for my plane, but it got me to thinking if there might be a way to separate out the alcohol from the fuel mixture... The bio-diesel folks mix alcohol and lye with their veggie oil while they are making their fuel and then 'wash' the fuel later by adding water to it and either draining the water and glycerin from the bottom or pump the bio-diesel off the top... Could we do something like that with autogas? We wouldn't need the lye part of it, but wouldn't the water mix with the alcohol and settle to the bottom? |
Alcohol in Fuel
I think you'd have to add something to the fuel to bring the octane
rating back up though. Perhaps going back to the early days of putting Octant in the fuel. -Robert |
Alcohol in Fuel
The legal issues with refining your own fuel, with the fire
department and EPA [fed and state] will make you not want to become an amateur chemist. Easier to ask your local fuel distributor to get you 300-1,000 gallons of the fuel you want, you'll get a better price and not have to worry about the fuel damaging the system, lye is very corrosive. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dave S" wrote in message nk.net... | Yes. It would settle.. and what remains will be a lower octane grade of | gasoline. | | Sounds like a plan, but can get to be a pain with large quantities. | | Dave | | | Grumman-581 wrote: | I'm starting to notice a lot more pumps around these days with a | notice that they may contain up to 10% ethanol in the fuel mixture... | Of course, they kind of puts a crimp in my autogas STC for my plane, | but it got me to thinking if there might be a way to separate out the | alcohol from the fuel mixture... The bio-diesel folks mix alcohol and | lye with their veggie oil while they are making their fuel and then | 'wash' the fuel later by adding water to it and either draining the | water and glycerin from the bottom or pump the bio-diesel off the | top... Could we do something like that with autogas? We wouldn't need | the lye part of it, but wouldn't the water mix with the alcohol and | settle to the bottom? |
Alcohol in Fuel
On Sat, 13 May 2006 12:02:40 -0500, "Jim Macklin"
wrote: The legal issues with refining your own fuel, with the fire department and EPA [fed and state] will make you not want to become an amateur chemist. Easier to ask your local fuel distributor to get you 300-1,000 gallons of the fuel you want, you'll get a better price and not have to worry about the fuel damaging the system, lye is very corrosive. I don't think that the lye would be necessary... Just mix water with the gasoline... The water will settle out with the alcohol and the gasoline will be on top... |
Alcohol in Fuel
("Grumman-581" wrote)
I don't think that the lye would be necessary... Just mix water with the gasoline... The water will settle out with the alcohol and the gasoline will be on top... If you were to run lab tests on the remaining gasoline, what do you think the final numbers would be? Similar to what it was before the introductin of 10% Ethanol? Or do you think the refineries compensate for the soon-to-be-blend by jacking up this, or lowering that? Montblack |
Alcohol in Fuel
notice that they may contain up to 10% ethanol in the fuel mixture... Do you live anywhere near a fuel terminal? You probably can't buy gas directly from them, but they might be able to tell you which filling stations request non-ethanol blended fuel. Check the yellow pages for Gasoline - Wholesale. |
Alcohol in Fuel
Don't try to remove the ethanol from the fuel, as the ethanol is used
to "finish" the refiner's base blend to raise it to the required octane rating. You could try it for your lawn mower, but no way in an airplane where the engine HAS to deliver power under all conditions. |
Alcohol in Fuel
True.
I just reading an article in Popular Mechanics [May 2006 issue] about ethanol based fuel. Said that it take 1.5 gallons to get same power as a gallon of gasoline. Listed all kinds of problems. Was intended for car drivers, but looked like good to know stuff fore every person who buys fuel or votes. -- James H. Macklin ATP,CFI,A&P "nrp" wrote in message oups.com... | Don't try to remove the ethanol from the fuel, as the ethanol is used | to "finish" the refiner's base blend to raise it to the required octane | rating. You could try it for your lawn mower, but no way in an | airplane where the engine HAS to deliver power under all conditions. | |
Similar Threads | ||||
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
