Microair 760
Old August 29th 06, 12:36 PM posted to rec.aviation.soaring
Ian K
Default Microair 760
Anybody got any hints or tips on setting up a Microair
760?
I have an eltec(?) mic from svsp that was recommended,
but the transmission is reported as low and distorted.Have
tweaked the mic gain pot, but doesn't seem to make
any difference. Batt voltage around 12.5v.
Old August 29th 06, 12:56 PM posted to rec.aviation.soaring
Mal[_2_]
"Ian K" wrote in message
news
760?
http://www.mrsoaring.com/microair.htm
Macca does he may even post in here check this newsgroup for previous
Microair posts.
Mal
Old August 29th 06, 12:59 PM posted to rec.aviation.soaring
Ray Lovinggood
Check your voltage at the radio.
A fellow club member received a new MicroAir just within
the past month or so. It would transmit and receive,
but it would receive only when the squelch was adjusted
to fully open.
Turned out he had some poor wiring in the panel. There
was a voltage drop in the panel due to the 'bird's
nest' wiring. He took it to a real avionics shop where
they rewired the panel and now, his MicroAir works
just fine. Yes, the avionics shop, 'Spark Chasers'
at the Johnston County Airport, North Carolina, USA,
bench tested the radio and did not find any problems
with it.
Ray Lovinggood
Carrboro, North Carolina, USA
LS1-d and MicroAir 760
760?
Microair 760 Ian K Soaring 2 January 21st 06 10:39 PM
Parts for sale Microair radio and Microair transponder User Home Built 2 December 14th 05 11:23 PM
Attn: Jim Weir- Microair 760 Billc851 Home Built 1 September 21st 05 05:44 PM
Microair 760 VHF-Transiver Erik Bennekou \(Privat\) Soaring 7 October 30th 03 01:00 PM
Microair vs Becker Ian McPhee Soaring 0 August 30th 03 09:45 PM
