VFR on top question
Old July 1st 06, 04:06 AM posted to rec.aviation.ifr
A Lieberman
Default VFR on top question
Scenario 1....
Severe clear weather from point A to point B going east. MRA is 7000 in
which part of this area is below ATC radar coverage from past experience.
Highest OROCA enroute is 2600, filing is direct from airport to airport.
If I filed "VFR on top" /G for 3500, would I be legal to file this plan
since I would be able to maintain visual flight rules (VFR)?
Scenario 2.....
Throw in an active MOA to the above. I would assume that I would get
vectors or an amended clearance around the active MOA even though I am "VFR
on top". Would this be a correct assumption?
Allen
Old July 1st 06, 04:15 AM posted to rec.aviation.ifr
john smith
Doesn't /G nullify the MRA?
Old July 1st 06, 04:22 AM posted to rec.aviation.ifr
A Lieberman
I'd suspect so John, EXCEPT if I have to join a victor highway via VOR or
intersection via VOR radials especially if scenario two panned out with a
hot MOA.
Allen
Old July 1st 06, 05:07 AM posted to rec.aviation.ifr
Jose[_1_]
hot MOA.
MRA is minimum RECEPTION altitude, presumably for the primary navaid.
It's primarily a physics thing, not a legal thing. GPS is not the
primary navaid, but can substitute, so you can navigate (even on the
ground) using GPS along VOR radials or Victor Airways.
I don't know the answer to the original question though.
Jose
The monkey turns the crank and thinks he's making the music.
Old July 1st 06, 02:08 PM posted to rec.aviation.ifr
Paul Tomblin
In a previous article, said:
Scenario 2.....
VFR is not prohibited in active MOAs, just discouraged. I would suspect
that they'd let you blunder on through in that situation.
Paul Tomblin
http://xcski.com/blogs/pt/
"To announce that there must be no criticism of the president, or that we
are to stand by the president, right or wrong, is not only unpatriotic and
servile, but is morally treasonable to the American public." -- Teddy Roosevelt
Old July 1st 06, 02:37 PM posted to rec.aviation.ifr
Steven P. McNicoll[_1_]
"A Lieberman" wrote in message
Scenario 1....
You can legally file anything, the question is can you legally be issued
what you've filed.
VFR-On-Top is still an IFR operation and all of the Instrument Flight Rules
apply to it with the exception of § 91.179 IFR cruising altitude or flight
level which directs pilots operating VFR-On-Top to comply with § 91.159 VFR
cruising altitude or flight level. You still have to comply with § 91.177
Minimum altitudes for IFR operations.
Filing VFR-On-Top does not relieve ATC of the requirement to assign routes
on airways or within normal navaid usable limits if radar monitoring cannot
be provided. If you're assigned an airway while VFR-On-Top the lowest
altitude you can use is that which conforms to § 91.159 and is at or above
the MEA.
Why do you want to do this anyway? In areas below radar coverage VFR-On-Top
has nothing to offer. You aren't provided any separation or traffic
advisories but you're still tied to a route. Why not just go VFR?
Scenario 2.....
"VFR on top". Would this be a correct assumption?
Yes.
Old July 1st 06, 02:41 PM posted to rec.aviation.ifr
"Paul Tomblin" wrote in message
VFR-On-Top is an IFR operation.
FAA Order 7110.65R Air Traffic Control
Chapter 9. Special Flights
Section 3. Special Use and ATC Assigned Airspace
9-3-3. VFR-ON-TOP
If the aircraft's route, track, or altitude may cause it to enter an active
Prohibited/Restricted/Warning Area, MOA, or ATCAA:
a. Inform the pilot to conduct flight "VFR-on-top" at least 500 feet above
the upper limit or lower limit of the airspace (subject to para 7-3-1,
VFR-on-top); or
PHRASEOLOGY-
MAINTAIN VFR-ON-TOP AT LEAST 500 FEET ABOVE/BELOW (upper/lower limit of
airspace) ACROSS (name or number of airspace) BETWEEN (fix) AND (fix);
and if the airspace is an ATCAA,
(name of ATCAA) IS ATC ASSIGNED AIRSPACE.
REFERENCE-
FAAO 7110.65, Class A Airspace Restrictions, Para 7-1-1.
b. Clear the aircraft via a routing which provides approved separation from
the airspace.
c. Exception: Some Prohibited/Restricted Areas are established for security
reasons or to contain hazardous activities not involving aircraft
operations. The addition of 500 (or 1,000) feet to the upper/lower limit of
these Prohibited/Restricted Areas is not required if the areas have been
identified by facility management.
REFERENCE-
FAAO 7210.3, Prohibited/Restricted Areas, Para 2-1-17.
Old July 1st 06, 05:27 PM posted to rec.aviation.ifr
A Lieberman
First of all, thanks for the reference on my question as it answered it
perfectly. I was planning a flight from KMBO to KEDN today.
Several reasons why I wanted to do the original scenerio.
Winds aloft from 3,500 to 5000 made for a 15 minute difference in flight
time. Had I gone to 7000 feet to ensure radar coverage, it would have
added another 5 minutes. With passengers, that extra 20 minutes would have
been significant difference.
Going the victor highways would have added about 20 minutes as compared to
direct.
Most importantly, I love the second pair of eyes for traffic advisories.
Sure, I could do flight following VFR, but since I am already in the
system, might as well stay in the system without the risk of being dropped.
And the most fun of it all, it's nice to see my flight path at
http://flightaware.com/live/flight/N...752Z/KMBO/KEKY
when I return home. Another way of keeping track of my flight time :-)
Website doesn't track VFR flight following too well.
As it turned out, couldn't launch today as I think something went south
with my starter or whatever engages the propeller (Bendex?)
Allen
Old July 1st 06, 05:41 PM posted to rec.aviation.ifr
have
direct.
dropped.
I still don't get it. If you have to go to 7000 to ensure radar coverage
then that's how high you'd have to go for that second pair of eyes. If
you're high enough to ensure radar coverage you're high enough to be cleared
direct.
Old July 1st 06, 08:28 PM posted to rec.aviation.ifr
A Lieberman
direct.
The radar outage would only be for a small segment of the flight. Why go
so high when I don't need to.
Not quite sure why the outage, since it happens right around the MEI
airport who has approach controllers but it does. Terrain isn't a factor
since it's flat as a board.
Now, I probably could request 7000 for that short period of time when I
expect out of radar contact, but by the time I climbed to 7000 feet the
time gained in flying the lower altitude would be lost in the climb to 7000
feet.
In other sectors, I have flown outside of radar coverage, but had to report
when a certain distance of a VOR, but this particular sector doesn't work
this way.
Bottom line for "flight planning purpose" I am only out of the second pair
of eyes for a very short duration of the flight. It was more efficient to
select a lower altitude for passenger considerations and lose the second
pair of eyes in a part of the trip where traffic is very minimal at best.
So, I'd be willing to give up 20 minutes of non radar coverage for a more
direct and quicker flight. If I was by myself, this all would have been a
moot point as I would just fly the victor highways.
Allen
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
