#21
cloud flying regulations
T o d d P a t t i s t wrote: "Fox Two" wrote: there is still risk that the FAA will consider flight in Class G in IMC to be careless or reckless. They have done it at least once. I would be curious to know the rest of the story of that particular violation. Here's some more info - I haven't gone to the original cases yet, perhaps tonight I'll do so, but if you track down any of this and think there's something interesting there, I'm interested in hearing your thoughts. This is from a 1994 post in rec.aviation.ifr: ------------------------------------- Hi Todd, My opinion? The pilot was careless and reckless, and should have been violated. In his specific case, he was denied an IFR clearance due to traffic, and he chose to circumvent the system by charging forward anyway without a clearance. This is no different to me that running a red light at full speed through a busy intersection. He was a noodle head! The judge referenced an earlier case that also involved flying IFR through the Class G airspace underlying a transition area. The Class G airspace in question, while technically the same airspace as the Class G out west that extends all the way to 14,500 feet MSL, can be argued to be different 'in nature.' In my opinion (which appears to be the same as the judge's), there is a BIG difference between the Class G airspace that is only 10 miles away from Chicago O'Hare Airport, and the Class G airsapce that is 100 miles southwest of Albuquerque! Would I ever depart an airport into IMC without a clearance? Heck no! Would I fly through a cloud at 13,000 feet while in Class G airspace in an IFR certified aircraft without a clearance? You bet I would. Do I plan on doing so? No. My intention is to fly IFR in Class E and Class A airspace, with an ATC clearance. Now I need to see if my DAR would be willing to certify a glider for IFR! Chris Fleming, F2 El Paso, Texas |
Frank Whiteley wrote: I'm told some soaring pilots operating locally request discrete transponder codes and receive flight following and are offered climbs and cruise blocks above FL180 occassionally. Useful when cloud base may exceed FL240. This may be more common in California/Nevada due to long time agreements and experience. A former partner of mine once wrote up an article for the PASCO newsletter about blocking FL220-260? and cruising about 115miles from Truckee to Mt Whitney without turning. I don't think he was transponder equipped for that flight. Hi Frank, That's exciting stuff, and encouraging! I would be interested in reading that article if you can find it. Chris Fleming, F2 El Paso, Texas |
"T o d d P a t t i s t" wrote in message news "Fox Two" wrote: My opinion? The pilot was careless and reckless, and should have been violated. I wouldn't disagree. My point was just that you can read the wording of the regs with a microscope and still not be certain of where you stand. FAR 91.173 is about as short as any reg there is. It just says: No person may operate an aircraft in controlled airspace under IFR unless that person has-- (a) Filed an IFR flight plan; and (b) Received an appropriate ATC clearance. If they wanted to require (a) and (b) in Class G too, the change is pretty simple, just remove the 3 words "in controlled airspace." -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) Departures in IMC, under IFR, without a clearance are done all the time. As an example, the weather at Gold Beach, Oregon(4S1), is indefinite, 1/4mile, fog. The airport is in G airspace, and a pirep shows the tops at 500' and the fog extends offshore about a mile. I can, and have, legally departed this airport to climb to VFR conditions, within uncontrolled airspace. A clearance is only required to enter controlled airspace. At this, and many other locations, it is possible to climb over 10,000' without finding controlled airspace. Al G |
T o d d P a t t i s t wrote: I wouldn't disagree. My point was just that you can read the wording of the regs with a microscope and still not be certain of where you stand. The pilot didn't violate the IFR reg; but he did knowingly and intentionally jeopardize the safety of others. He was a noodle-head. That's why he was violated. Chris Fleming, F2 El Paso, Texas |
"Fox Two" wrote in message oups.com... T o d d P a t t i s t wrote: I wouldn't disagree. My point was just that you can read the wording of the regs with a microscope and still not be certain of where you stand. The pilot didn't violate the IFR reg; but he did knowingly and intentionally jeopardize the safety of others. He was a noodle-head. That's why he was violated. Chris Fleming, F2 El Paso, Texas I wholeheartedly agree. Al G |
Both the case and the fog scenario above involve departures without a clearance in IMC conditions, and both seem to be FAR legal. My problem is that, while they "seem" to be legal, the ALJ and the FAA disagree, at least for the two cases mentioned, calling it careless/reckless. I'm not sure how to interpret that in the context of proposed glider cloudflying in class G airspace. -- Hi Todd, While this sub-thread has gone off the primary topic of pilot and instrument requirements to fly a glider IFR, I'll try to explain this a different way: I believe that we all agree that there were no regulations that were violated in either of these cases, except the "Careless & Reckless" charge. Flying IFR in uncontrolled airspace without an ATC clearance is perfectly legal, perfectly safe, and pilots do it every day. But there is a judgement call that needs to take place. Using CFAR § 91.173 as a 'loophole' to climb through the extremely thin slice of 700 feet of uncontrolled airspace (from an airport that has a published instrument approach procedure, and possibly an IFR airplane on an instrument arrival) to enter the conjested controlled airspace of the Midwest is bad judgement, and by definition: careless & reckless. On the other hand, there are vast areas in the Western United States that are uncontrolled all the way up to 14,500 feet MSL. There are thousands of airports that are hundreds of miles away from lower levels of controlled airspace. It is in the spirit of accomodating aircraft in these areas that CFAR § 91.173 was written, not as a loophole to move to the front of the line to Indianapolis! Pilots shouldn't be afraid of CFAR § 91.13: Careless & Reckless Behavior. If you exercise good judgement, and work with the system, you'll be fine. This reg is for pilots that exerceise bad judgement, and work against the system. I hope that helps. Chris Fleming, F2 El Paso, Texas |
I don't think it's very far off topic. My interest has always been what is required to cloud fly a glider, and part of that interest has always been - "what about class G?" I've been trying to determine exactly when you think the FAA/NTSB would impose the careless/reckless charge on a glider pilot who went cloud flying in class G. I don't really care about instrument departures other than for what they tell us about gliders in the U.S. Since there are no glider/91.173 cases, we can only look at the instrument cases. Todd, I apologize. Flying gliders IFR is very much on topic. So you think the important factors a 1) the departure airport had a published approach. 2) it was in the Midwest - not out west. 3) it was a loophole to legally do what he couldn't do otherwise without a clearance. Yes, I do. And there are likely to be other factors with this case that contributed to this pilot's violation that we don't know about, such as: 1.) Why didn't this pilot get an IFR clearance prior to departure? 2.) Did he get a weather briefing (which is required), and 3.) if he did, why did he depart for an airport that was below minimums? 4.) Did his departure create a conflict with another aircraft? 5.) What was his attitude/behavior when questioned by ATC? I don't disagree, but presumably they did not have to let him into the front of the line at Indianapolis, in which case he'd have had to maintain VFR and go elsewhere. As to accommodating aircraft from small airports out west, don't most instrument pilots call and get a clearance with a release time and a void time? ATC simply won't give IFR clearances to aircraft operating from many (not all!) small, remote airports out west. That is the purpose of the intentional wording of CFAR § 91.173. I used to fly at an airport not far from the NYC Mode C veil that was notorious for low level fog. There were pilots who would depart through it to get to VMC. Would you consider them to be at risk of a 91.13 charge? Did it matter whether they intended to go VFR to their destination? It depends. I know that is a sucky answer, but CFAR § 91.13 is, by definition, subjective! I'll try to illustrate using two hypothetical situations from your New York Airport: Flight 1: A pilot departs without an IFR clearance through 500 feet of ground fog with visibility just shy of 1 mile. Above the fog, conditions are clear skies, and unrestricted visibility. The flight continues VFR to a VFR landing at the destination. Flight 2: A pilot departs without an IFR clearance through 500 feet of ground fog with visibility just shy of 1 mile. Above the fog, however, is an overcast layer at 2,000 feet with widely scattered rain showers. Many of the other airports in the area are reporting IFR conditions, as does the destination airport. While neither of these pilots violated the regs, one can argue that the 2nd pilot exercised poor judgement. If this departure created a conflict with another aircraft, and the pilot had a "So what, just give me my clearance already" attitude, then a violation would be probable. I'm not sure if it does. Any time that an aircraft is in IMC outside of controlled airspace without a clearance, there is *some* MAC risk with another aircraft that is talking to ATC or doing the same thing. You seem confident that it's legal in some circumstances, but not others. The IFR magazine article and the two cases cited seemed to say that it wasn't all that clear that it was ever legal no matter what the FARs seem to say. Again, this is just my opinion, but one based on a lot of experience flying IFR, and training and evaluating pilots at all levels of the system. CFAR § 91.13 is a vital tool for the FAA to protect those of us that work with the system from those who do not. If a glider is in cloud out west in class G, will the pilot be more like the fog departure case or the "loophole" case? I'd love to see a case that says - yes it's OK to depart in fog from an isolated airport to get to VMC and fly VFR. Is there such a case? Unfortunately, we may never have such a case. So all that I can say is follow your gut. If you aren't comfortable doing something, or a voice inside you is saying that maybe you should do something else, don't do it. Which brings us back to the beginning of the thread. While I believe it is possible for me to pick up a VFR clearance to operate a non-IFR equipped glider in class A airspace, I'm not willing to risk my career on it! I'm trying to work with the system to get an IFR clearance to operate an IFR-equipped glider in Class A airspace without a waiver. This is an exercise of legality and good judgement. Chris Fleming, F2 El Paso, Texas |
In Germany and in Switzerland, the principle of glider flying in clouds is
that you know that there is a glider at a precise position in that cloud, and that there is no other glider/aircraft at the same position. In Germany, an ATC clearance and a fligh plan is mandatory. In Switzerland, you can flow only in areas which are allocated for cloud flying, and you have to blind-radio your precise position twice on a frequency allocated for cloud flying before you enter the cloud. That all work of course only if there isn't a butthead who enters a cloud "just because he feels like". I wouldn't say that cloud flying is common practise in Germany, and in Switzerland it's rather used for training purposes than for x-country. "T o d d P a t t i s t" wrote in message ... "Fox Two" wrote: Yes, and that's why it's so tough trying to decide how glider cloudflying in class G might be treated. It seems to be handled in other countries in a way that gives some US trained airplane instrument pilots the willies - and a 91.13 charge would probably be initiated by someone with exactly that background - not a glider background, and certainly not a glider instrument background. I'm trying to work with the system to get an IFR clearance to operate an IFR-equipped glider in Class A airspace without a waiver. This is an exercise of legality and good judgement. This is something that I understand some glider pilots have managed to do fairly routinely I've read several reports of it in both the west and from wave off the eastern ridges. Thanks for your comments. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
Similar Threads | ||||
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Home Built | 331 | March 10th 06 01:07 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
