#11
Crosswinds & Obstacles are a funny thing
"The approach end of the runway is a workable rule of thumb for computing a
touch down point to have maximum runway length available to correct errors in judgment or errors in "reading the wind effects", before using up all runway available and having to resort to the iron thermal supported go-around maneuver." BT "Kyle Boatright" wrote in message . .. "Dudley Henriques" wrote in message ... Kyle Boatright wrote: snip Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB Hi KB; The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. big snip of good stuff -- Dudley Henriques Agreed 100%, Dudley. What's your experience along the following line: This (insert lengthy experience based finding here) seems to be a workable rule of thumb for picking a good touchdown point for taking advantage or minimizing the negative impact of local obstacles to the wind. KB |
I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. ... [TRIMMED for Montblack] :-) Thoughts? KB Landing the airplane is a coincidence of the approach, remember that one? Always be prepared to go around or missed as the case may be. Lots and lots of easy, loose corrections. Fly the center line and dance, dance with the wind. I always think of it like when I finally learned to ski the bumps, the bumps are your friend, work with the bumps. Likewise with the wind, the wind is your partner, fly with the wind. Did something yesterday I haven't done since PPL training. I went around. Flying into Bar Harbor 22 short final, got below the tree line and she sank like a rock. Rather than fight it and muscle it onto the runway, power up, level off, and climb. I probably could have saved the landing, but it was good to have the quick ADM process fire and make a safe choice. KC |
("Kevin Clarke" wrote)
... [TRIMMED for Montblack] :-) Mmm.... and all the trimmings. Just for me. Thank you. Montblack |
On Tue, 16 Oct 2007 23:41:18 -0400, Dudley Henriques
wrote: Kyle Boatright wrote: I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB Hi KB; The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. I know this sounds over simplistic on the face of it, but you'd be surprised how many pilots get a handle on wind somewhere between the base turn and final and get mentally nailed into that wind mindset. The result can This as well may sound over simplistic and I hope I put it into the proper words and context. Although I take notice of the winds, both reported and forecast, I treat each landing pretty much the same be it on a calm day or with gusty wind. Remember, calm hot summer days may be loaded with up and down drafts that are present when wind conditions are reported as calm. IOW the only preconceived notions I have going into a landing are the winds are likely to be something other than forecast. Winds and gusts may show up on an otherwise calm day. Winds may be higher or less than forecast and the directions may be different or variable. Conversely a strong cross wind on final may turn out to be a direct head wind in ground effect or it might even have turned calm. I fly the plane and adjust to the conditions of the moment. The plane and I react and correct for changes. I don't have to stop and think "Hmmm the winds just changed 90 degrees, to correct for that I need to add left aileron and a bit of right rudder to stay aligned with the runway. Unless the winds are light, the pilot does not have time to reason all of this out. Like riding a bicycle, the movements to correct for drift one way or the other should be ingrained and instinctive as should adding or retarding throttle with up and down drafts. Any pilot who pays attention and practices a bit should be able to do this by the time they take the check ride. Certainly they will have to make adjustments when they move on to different types of aircraft where speed, inertial, control harmony and response must be taken into consideration. You've reduced the thinking and responding time to one of response/reaction times. easily be over concentration on an expected wind direction down through the approach. Then a sudden gust or wind change catches you napping. The result of that is a second or two DELAY in reaction time to the change. Usually it comes out ok, but if a pilot gets caught at exactly the wrong instant (usually down low just before the flare or entering the flare) that two second delay can suddenly become a potentially serious affair. When I was getting to the point where I could handle cross winds pretty well my instructors took me up to Houghton Lake (HTL). I think most pilots have a place like HTL some where nearby. The paved runway is a 4000' 09/27. About 200 yards to the north is a very straight and tall tree line with the ground level probably 20 or so feet above the runway although it's not apparent. When the wind is out of the north it drops over the trees to form a relatively smooth flow over the runway from the North. to the South of the runway is a slight rise. For some reason the winds seem to form an "S" over the runway. IOW as you are descending on final for 27 you have a strong, right cross wind, but some where around a 100 feet you hit a bit of turbulence and are likely to find the wind has switched 180 degrees and is out of the South. Around 30 feet or so there is another layer of turbulence and you are back to a wind out of the North. OTOH you can't expect it to be this way every time the wind is out of the North. I've been 90 degreed up there a couple of times and it's usually right over the threshold. Pay attention and it's nothing more than a reminder. It's not a place to be complacent with a mind set that is all set for a wind out of the North. That could be expensive, painful, or both. What I like to instill in the pilots I train (in my case have trained :-) is what I call a non committal mindset for wind on the approach. Loosely explained, this simply amounts to a pilot developing a habit pattern that digests wind data as received, and begins the approach with that data in mind, but instead of thinking of wind direction, I like pilots to think wind CONTROL. By thinking aircraft control as opposed to expected wind, what happens is that you are mentally and physically a bit more "loose" on the approach because you're not expecting a specific wind correction; you are correcting for what's HAPPENING NOW all through the approach. Basically it's nothing more than a slight change in the way a pilot THINKS and FLIES the approach. You're cutting into that 2 second reaction time because now you're flying the approach as though the winds were unexpected instead of expected. You have nothing to lose and everything to gain by using this mindset. If the winds are as expected, you're automatically correcting for them. But if you get nailed, you're loose and expecting that as well!! DH Some years back I was standing along side of 18/36 at 3BS when a company pilot delivered a brand new A36 to one of our more impoverished. The winds were strong and gusty out of the West. 24 would have been a more logical choice, but the FBO was about 1300 feet down 36 and that's where he was headed. As we stood there in the wind I watched that A36 come in with those big flaps pointed down. I could say the wings appeared to be absolutely steady without exaggeration. OTOH you could see the ailerons making some rather large excursions. That guy was good! He was the epitome of a pilot who reacts to the moment with just the right amount of input. No way can you fly like that and take time to think about what happening and what you need to do for control inputs. Roger (K8RI) |
Roger (K8RI) wrote:
That guy was good! He was the epitome of a pilot who reacts to the moment with just the right amount of input. No way can you fly like that and take time to think about what happening and what you need to do for control inputs. Roger (K8RI) You can probably sum up the entire experience of learning to fly in this one paragraph. When you break all of it down, it boils down to this one thing. You start out as a student flying the airplane by thinking about what you are doing as you do it. This is fine. This is why you have an instructor with you. You begin to become a pilot the instant you begin flying the airplane without having to think about what you are physically doing to make it fly. Your mind can now be occupied as it must be with WHERE you are taking the airplane instead of what you have to push or pull, in order to get it there. -- Dudley Henriques |
Similar Threads | ||||
Navy's 'Ring Of Steel Bomb' Flattens Obstacles | [email protected] | Naval Aviation | 0 | August 28th 07 03:27 AM |
%%%%HOW TO BE FUNNY!%%%% | Expert Humor | Soaring | 0 | March 31st 06 04:13 PM |
%%%%HOW TO BE FUNNY!%%%% | Expert Humor | Owning | 0 | March 31st 06 04:12 PM |
Garmin GPS196 Update v.4 - obstacles? | [email protected] | Piloting | 13 | March 16th 05 06:05 PM |
Funny B-2 Pic | Leadfoot | Military Aviation | 1 | October 26th 03 08:35 PM |
