How come the wings bank when I use the rudder
On a 3 hour cross country today I was amusing myself by flying with
rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. |
"Paul kgyy" wrote in message
oups.com... On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. As you yaw, the "outside" wing is flying faster than the "inside" wing and generates more lift which gives you bank. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Paul kgyy wrote:
On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. It's called a yaw/roll couple. As you create yaw you acellerate the outside wing which then has more lift. It raises coupling with roll and you have turn. -- Dudley Henriques |
On Oct 20, 8:42 pm, Paul kgyy wrote:
On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. In addition to what others have said, another interesting question to ponder is why the airplane yaws when you bank. |
"Andrew Sarangan" wrote in message
oups.com... ... In addition to what others have said, another interesting question to ponder is why the airplane yaws when you bank. 'cause if it didn't, your feet would have nothing to do ;-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
In addition to what others have said, another interesting question to ponder is why the airplane yaws when you bank. The yaw is induced by the ailerons, so the only time you need to apply rudder is when you are changing your bank angle with the ailerons. On the side where the aileron is down, the wing has more lift, and more drag. On the other side, the lift is spoiled and there is less drag. The draggy wing yaws backwards, requiring opposite rudder. This is why when you initiate a bank, you need to apply rudder in the direction of the bank while the ailerons are in use, but not once you stabilize the bank and neutralize the ailerons. When you roll back wings level, you need to apply rudder the other direction to once again compensate for the ailerons. Dean |
Paul kgyy wrote:
On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. The rudder causes the airplane to yaw; one wing goes faster, generating more lift; the other wing goes slower, generating less lift. vince norris |
("Capt. Geoffrey Thorpe" wrote)
'cause if it didn't, your feet would have nothing to do ;-) http://www.ercoupe.org/images/37.jpg That would be awful...! :-) Montblack |
What gives, guys? Good question followed by three answers that
actually agree? What's up with that? Where's the usenet controversy? Bob The rudder causes the airplane to yaw; one wing goes faster, generating more lift; the other wing goes slower, generating less lift. vince norris -- I'm trying a new usenet client for Mac, Nemo OS X. You can download it at http://www.malcom-mac.com/nemo |
Isn't interesting that entry level RC Aircraft only have rudder and elevator
controls.. and then turn just fine. Funny that a full sized airplane would react the same way. In a stall, you pick up the low wing with rudder, not aileron, that only adds adverse yaw, more drag on the low wing, and fights the rudder. BT "Paul kgyy" wrote in message oups.com... On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. |
Similar Threads | ||||
GPS instead of turn and bank | Danny Deger | Piloting | 52 | February 8th 07 02:03 PM |
X-Wings and Canard Rotor Wings. | Charles Gray | Rotorcraft | 1 | March 22nd 05 12:26 AM |
Bank Check Aviation | Ron R | Piloting | 68 | January 19th 05 01:30 AM |
BREAKING THE BANK | Cribsheet | Piloting | 0 | December 22nd 04 06:27 PM |
key bank | CSA722 | Piloting | 0 | July 14th 03 07:04 AM |
