Seeyou NMEA to Winpilot/Seeyou
Old May 30th 06, 04:26 PM posted to rec.aviation.soaring
Default Seeyou NMEA to Winpilot/Seeyou
Hello,
Did any one succeeded to feed Winpilot (or Seeyou Mobile) with the NMEA
output of Seeyou
- Via Bluetooth ?
- Via USB craddle ?
Thanks
Jean
Old May 31st 06, 04:28 AM posted to rec.aviation.soaring
Jean wrote:
Hello,
output of Seeyou
- Via Bluetooth ?
- Via USB craddle ?
Thanks
Jean
I've had luck in running Winpilot with a NEMA output from both SeeYou
and Condor simulator. The main criteria is to have it output to a
serial port and to have the com port number assigned correctly on the
output.
I do not think these programs are setup to accept input via the
bluetooth or usb [but i may be wrong], I would expect you to have good
luck with the old syle serial port.
Chris
Old June 1st 06, 09:22 PM posted to rec.aviation.soaring
Jean wrote:
Did work ultimately - by defining a "serial" connection from the IPAQ BT
manager. Still a conflict with Activesync ..
Yes, you have to turn off Acivesync. You can configure activesyn to not
make connections by port type [serial, usb etc].
This allows the port to be used by SeeYou for output.
Chris
Old June 3rd 06, 11:38 AM posted to rec.aviation.soaring
Have create a new BT serial port "Server" from the Configuration Panel and
now it works in parallel with Activesync,
Jean
"Jean" a écrit dans le message de news:
Hello,
output of Seeyou
- Via Bluetooth ?
- Via USB craddle ?
Thanks
Jean
Attention Cambridge GPS-NAV, OLC and SeeYou users--v3.5 is now current Doug Haluza Soaring 2 May 30th 06 03:06 AM
Using mobile SeeYou Robert Hart Soaring 3 May 10th 06 09:42 PM
SeeYou Training Paul Remde Soaring 0 April 13th 06 04:46 PM
SeeYou Training DVD Now Shipping Paul Remde Soaring 0 January 25th 06 09:33 PM
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 12:25 AM
