Pitot Heat Failure in a Piper
"Aaron Coolidge" wrote in message
... The heating elements - there are 2 in the pitot tube - are supposedly not repairable. I had one bad heating element a few years ago and a new heated pitot tube from DMFS was "only" about $250. If the pitot tube is replaced you are supposed to re-do the transponder/IFR cal as you are "opening the static system". After working on the static system, all you need to do is check for leaks. An airframe mechanic can perform the check and recertify the static system. Pump the static system until the altimeter reads 1000' above field elevation and check for leaks (less than 100 fpm is passing). No requirement to recertify the altimeter, encoder or transponder. Mike F. |
Similar Threads | ||||
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
TSA requirement of Security Awareness Training | dancingstar | Piloting | 3 | October 5th 04 02:17 AM |
pitot heat question | K. Ari Krupnikov | Instrument Flight Rules | 7 | December 11th 03 01:51 AM |
Pitot heat | Paul Mennen | Owning | 10 | November 6th 03 09:54 AM |
Pitot heat | Paul Mennen | Piloting | 10 | November 6th 03 09:54 AM |
