ASW27a Water Ballast Bag removal
Old June 12th 15, 03:21 PM posted to rec.aviation.soaring
Default ASW27a Water Ballast Bag removal
Has anybody had involvement with the removal of ASW27a Water Ballast Bags? In particular is it possible to disconnect the bag from the wing dump valve by means of the inner large knurled bag connector rather than dismantling the valve from the wing itself.
Old June 15th 15, 12:22 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Am 15.06.2015 um 11:24 schrieb Jim White:
dump
should be easy to remove. The water bag is connected to the wing water
inlet by means of a Gardena-type connection. Reach into the wing and
twist (or pull), the actuator for the connection should be on the water
bag side of the connection.
Peter Scholz
ASW24 JE
not on mine
You are right, the ASW 27 is indeed different:
Take off the lid fromm the root rib and pull out the rod from the valve.
Untie the string for the water bag on the root rib, and fasten the end
of the string again, so that it cannot slip into the wing.
On the water outlet (underside if the wing) unscrew the screw with a
caliper 2 pin spanner with 3mm pins (e.g. Gedore No. 44/7").
Now you can pull the water bags carefully out of the wing. Take care not
to damage the tube within the water bag, about 2.5m long. It works best
when you place a long bench in front of the wing (before the root rib),
where you can place the water bag on.
(translated from the ASW 27 Maintenance Manual)
Peter Scholz
ASW24 JE
Water Ballast Tripod [email protected] Soaring 3 July 31st 12 05:43 PM
Libelle 301 water ballast [email protected] Soaring 3 January 15th 08 02:40 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
