#31
Twin take off on one engine?
On Thu, 3 Sep 2009 17:42:52 -0700 (PDT), Richard wrote in
: ... I googled the heck out of it and could not find any thing single engine take off of a 747. I couldn't find anything I thought was reliable--some claims and counterclaims on groups or forums like this. What is clear is that the 747 can and has done lots of ferry flights with one of the four engines inoperative. If you're already up in the air with decent altitude and a light payload, one engine might keep you in the air. My personal bet is that one engine won't do for liftoff. Two would probably be OK. Three--people have done it, so there's no doubt about it. Marty -- Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.* See http://www.big-8.org for info on how to add or remove newsgroups. |
#32
You could probably do it in a skymaster. We had a 58 barron loose one
engine and was almost impossible to taxi. No was you could take off. Legal or not |
#33
On Sep 4, 8:47*am, Clark wrote:
"Flaps_50!" wrote in news:d7b4faf4-4167-46cd-8692- : According to the data I can find, the 747 can't climb on one engine so how can it take off? Cheers Hmmm, empty weight is about 360,000 lbs plus a little fuel and 50,000 lbs of thrust. It aught to work. I suspect your data are in error or perhaps you're considering a loaded 747. It comes from the certification requirements of a commercial 747 climbing on 3 engines. The excess thrust is calculated from the rate of climb in that condition and knowing that 1 HP is 33,000 ft lbs / rminute. Perhaps my math is wrong but I don't calculate an excess thrust of 120,000 lbs... What do you get? Cheers |
#34
On Sep 4, 3:26*pm, "Martin X. Moleski, SJ"
wrote: On Thu, 3 Sep 2009 17:42:52 -0700 (PDT), Richard wrote in : ... I googled the heck out of it and could not find any thing single engine take off of a 747. I couldn't find anything I thought was reliable--some claims and counterclaims on groups or forums like this. What is clear is that the 747 can and has done lots of ferry flights with one of the four engines inoperative. If you're already up in the air with decent altitude and a light payload, one engine might keep you in the air. Wasn't there was a case of a single engine landing with no go around being possible? Cheers |
#36
On Sep 11, 1:02*am, "Peter Dohm" wrote:
"Clark" wrote in message ... "Flaps_50!" wrote in news:2ce85d20-5c84-4425-a1bf- : On Sep 4, 8:47 am, Clark wrote: "Flaps_50!" wrote in news:d7b4faf4-4167-46cd-8692- : According to the data I can find, the 747 can't climb on one engine so how can it take off? Cheers Hmmm, empty weight is about 360,000 lbs plus a little fuel and 50,000 lbs *of thrust. It aught to work. I suspect your data are in error or perhaps you 're considering a loaded 747. It comes from the certification requirements of a commercial 747 climbing on 3 engines. The excess thrust is calculated from the rate of climb in that condition and knowing that 1 HP is 33,000 ft lbs / rminute. Perhaps my math is wrong but I don't calculate an excess thrust of 120,000 lbs... What do you get? Cheers What I get is that I suspect your numbers are at gross weight. I suggest looking at the problem as stated rather than making up your own conditions. -- --- there should be a "sig" here What I get is the latest successfull troll: *please ignore him. I see, discussion using physics and aeronautics about real aircraft performance is a troll to you. You clearly prefer BS. The 747 figures I used: empty weight 403,000 #, MTOW 870,000 #. Minimum fuel 70,000 #, thrust available 60,000 #. That gave me TOW of 473,000 # which is quite a bit more than Clark 'estimated' so the drag would be proportionally higher. In the absence of any ref to the claimed actual takeoff on one engine, it sounds like urban piloting myth. |
#37
On Sep 11, 2:19*pm, Clark wrote:
"Flaps_50!" wrote : On Sep 11, 1:02*am, "Peter Dohm" wrote: "Clark" wrote in message .. . "Flaps_50!" wrote in news:2ce85d20-5c84-4425-a1bf - : On Sep 4, 8:47 am, Clark wrote: "Flaps_50!" wrote in news:d7b4faf4-4167-46cd-86 92- : According to the data I can find, the 747 can't climb on one engine *so how can it take off? Cheers Hmmm, empty weight is about 360,000 lbs plus a little fuel and 50,000 lbs *of thrust. It aught to work. I suspect your data are in error or perhaps you 're considering a loaded 747. It comes from the certification requirements of a commercial 747 climbing on 3 engines. The excess thrust is calculated from the rate of climb in that condition and knowing that 1 HP is 33,000 ft lbs / rminute. Perhaps my math is wrong but I don't calculate an excess thrust of 120,000 lbs... What do you get? Cheers What I get is that I suspect your numbers are at gross weight. I sugges t looking at the problem as stated rather than making up your own conditions. -- --- there should be a "sig" here What I get is the latest successfull troll: *please ignore him. I see, discussion using physics and aeronautics about real aircraft performance is a troll to you. You clearly prefer BS. The 747 figures I used: empty weight 403,000 #, MTOW 870,000 #. Minimum fuel 70,000 #, thrust available 60,000 #. That gave me TOW of 473,000 # which is quite a bit more than Clark 'estimated' so the drag would be proportionally higher. In the absence of any ref to the claimed actual takeoff on one engine, it sounds like urban piloting myth. While your efforts are some-what commendable (at least you tried) they don't fit the timeframe and conditions. It was a one time deal on an early model 747. Lower empty weight and minimum fuel wouldn't necessarily apply as long as W&B and structural load conditions were met. It was reported as a one-off ferry flight. I believe that Peter is rather overly sensitive to say the least. Thank you for the further info. Even if our opinions differ on this question, I really would appreciate a pointer to the actual event so I can look into the difference between my theoretical drag estimates and some heavy performance data. i Cheers |
#38
"Flaps_50!" wrote in message ... : Thank you for the further info. Even if our opinions differ on this question, I really would appreciate a pointer to the actual event so I can look into the difference between my theoretical drag estimates and some heavy performance data. i I invested 20 minutes of my life in a Google search for a 747 single-engine takeoff and found nothing. I assume that I am not alone but I also acknowledge that a single search proves nothing one way or another.. Perhaps more importantly, the collective memories of this group have come up with nothing specific over the last week or two. Until I see a believable reference, I respectfully choose to believe that it didn't happen. Vaughn |
#39
Aztec crash.
Vr is 70mph. Vmc is 80mph. Vy is 120mph. The latest article said he knew he had an engine out and was taking off single engine. Prop wouldn't be feathered because you can't feather Piper twins on the ground after the engine is dead; you need 800rpm. Best effort takeoff with 25 degrees flaps, 2 engines, he'd need around 1200' to clear 50' obstacle. No flaps for him because it's too much drag, so add 50%. Half the engine power is gone, so assuming no loss to lift, you'd still take twice as long to accelerate. That's 3600'. What sort of climb should he expect? Best climb at 120mph at sea level will be about 250fpm. Sub out 50fpm for being 815' MSL Plus 50' obstacle. Assume he was at 4000lbs and add 150fpm. So, call it 350fpm at 120mph clean (gear up, prop feathered). At Vr, he's not going to climb out of ground effect. With gear down, he's not going to get out of ground effect. With an unfeathered prop he's not going to get out of ground effect. He's have to hug ground effect for best acceleration, as pulling up too much would induce too much drag. Assuming he had all of that resolved, you'd still have to factor in the distance to get to a climbing airspeed. Vyse of 120 means he probably could expect climb performance at about 100 or 105mph. Based on a whole lot of best case assumptions, you've still chewed up the entire 5000' runway just to get to some minimum climb speed. Add in best practices of abort if not climbing by 2/3 down the runway, and another 25% distance because it's obviously not in new condition, he shouldn't have attempted such a takeoff, even on a ferry flight, unless he had 9000' to go with. Even so, the POH says that if you haven't gotten to within 5mph of Vyse before the engine fails, that you should abort the takeoff, even if you're in the air. "Power to idle, land straight ahead." 747 single engine takeoff Can it fly on 1 engine? Yes. Can it maintain altitude? Maybe. Can it take off? If it were stripped, light on fuel, maybe. The Boeing 747 has four turbofans. 4-engine transport category aircraft are required to demonstrate a 3% positive gradient with an engine out and gear up. BEW is about half of MGW on a 747. Parasite drag is 2.2%, and you're looking at around 150% engine power for climb. But there would be more induced drag from the rudder pressures, so you might have to strip the plane and unload 2 of the engine pods. Boeing might also go past the mins, or use derated engines, so you this might all be doable. Even so, you'd probably need 5 miles to accelerate to V2. With passengers, landing fuel, cargo, luggage, SEATS, single engine, max power, you're still descending. That's all hypothetical though. A decent flight sim could probably test this with some model tweaks. AA's sim center could probably test this. Boeing might have some calculations for this on file somewhere. |
#40
On Tue, 15 Sep 2009 19:02:38 -0700 (PDT), JDS Davis wrote in
: Aztec crash. ... The latest article said he knew he had an engine out and was taking off single engine. ... Do you have a link to the latest article? A reference? Marty -- Big-8 newsgroups: humanities.*, misc.*, news.*, rec.*, sci.*, soc.*, talk.* See http://www.big-8.org for info on how to add or remove newsgroups. |
Similar Threads | ||||
Twin engine wing-jumper | gatt[_2_] | Piloting | 37 | February 21st 08 07:57 PM |
What 2 seat, twin engine GA plane??? | Charles Talleyrand | Owning | 14 | February 9th 08 10:32 PM |
twin-engine kits available | [email protected] | Home Built | 38 | January 31st 08 08:49 PM |
Twin engine prop rotation? | Chris Wells | General Aviation | 12 | December 19th 07 08:52 PM |
pressurized twin-engine, 16 to 19 seats buy | Federico Prüssmann | Owning | 0 | September 25th 03 06:44 PM |
