WGC 2012 Day 5 18m Task?
The graphic for the 18m task for Day 5 shows an overlap between points 66 and 67. Is that okay because they have to fly to point 31 that comes between 67 and 66?
Thanks, Ray |
On Thursday, August 9, 2012 8:11:30 PM UTC-6, rlovinggood wrote:
The graphic for the 18m task for Day 5 shows an overlap between points 66 and 67. Is that okay because they have to fly to point 31 that comes between 67 and 66? Thanks, Ray Go to Soaring spot dot com. It shows a better picture of the task. I believe the scale is just off on the WGC page due to compression. Regards, #711 |
Ray answered his own question. On an area task you visit each area in
turn. There's nothing in principle to stop the same area being used twice on a task, although it might look a bit confusing. Certainly nothing to stop an overlap between areas that are not one after the other. At 03:11 10 August 2012, Tom Kelley wrote: On Thursday, August 9, 2012 8:11:30 PM UTC-6, rlovinggood wrote: The graphic for the 18m task for Day 5 shows an overlap between points 66 and 67. Is that okay because they have to fly to point 31 that comes between 67 and 66? Thanks, Ray Go to Soaring spot dot com. It shows a better picture of the task. I believe the scale is just off on the WGC page due to compression. Regards, #711 |
Similar Threads | ||||
Circle Task | Chris | Soaring | 3 | December 21st 11 06:35 AM |
Task Building | Uncle Fuzzy | Soaring | 5 | August 5th 09 08:09 PM |
How to be a Task-setter / CD | noel.wade | Soaring | 5 | September 27th 08 02:00 AM |
New DMSt task: 4 TPs | Klaus T. | Soaring | 0 | January 9th 06 01:03 AM |
New Task | JJ Sinclair | Soaring | 5 | October 23rd 03 01:36 AM |
