I think it was 1995, at Oshkosh, I attended a forum on the differences
between auto fuel and avgas. It was presented by a fellow who owned and operated one of the few refinerys which produce avgas. IIRC, a refinery turns crude oil into different hydro-carbons. They are all solvents, and all support combustion. They are ranked from light to heavy, based on how many hydrogen atoms there are per each carbon atom. Butane has two hydrogen, and octane has eight. The heaviest is asphalt, which is the goo left after all lighter fuels are driven off, has the most energy per lb, but is the most difficult to ignite. Auto fuel is a blend which includes the asphalt, as well as butane in the winter. Avgas has only three components, which do not include those at either end of the spectrum (ashalt and butane). So avgas does not leave the residue that old auto fuel will, nor does the engine start as easily, nor does it produce as much power. Because the avgas does not have the lighter components, it does not vapor lock as readily either. The octane rating compares the tendency of an engine to knock, based on the speed of the flamespread. Higher octane ratings mean only that the fuel burns more slowly, as if lead were added. It does not mean that the fuel has more power, only that engines can have a higher compression ratio without knock, so the engine can utilize more of the energy in the fuel. The lowest octane rating, that will not knock, makes the most power. If that fellow gives his talk again, you will certainly enjoy the hour. |
George wrote:
I think it was 1995, at Oshkosh, I attended a forum on the differences between auto fuel and avgas. It was presented by a fellow who owned and operated one of the few refinerys which produce avgas. IIRC, a refinery turns crude oil into different hydro-carbons. They are all solvents, and all support combustion. They are ranked from light to heavy, based on how many hydrogen atoms there are per each carbon atom. Butane has two hydrogen, and octane has eight. The heaviest is asphalt, which is the goo left after all lighter fuels are driven off, has the most energy per lb, but is the most difficult to ignite. It isn't the number of hydrogen atoms per carbon atom. It is the number of carbon atoms fundamentally as the number of hydrogen atoms is defined by the bond structure. Octane has 8 carbon atoms, but only 18 hydrogen atoms which isn't even close to an 8 to 1 ratio. Auto fuel is a blend which includes the asphalt, as well as butane in the winter. Avgas has only three components, which do not include those at either end of the spectrum (ashalt and butane). So avgas does not leave the residue that old auto fuel will, nor does the engine start as easily, nor does it produce as much power. Because the avgas does not have the lighter components, it does not vapor lock as readily either. The octane rating compares the tendency of an engine to knock, based on the speed of the flamespread. Higher octane ratings mean only that the fuel burns more slowly, as if lead were added. It does not mean that the fuel has more power, only that engines can have a higher compression ratio without knock, so the engine can utilize more of the energy in the fuel. The lowest octane rating, that will not knock, makes the most power. And burn speed is not related to octane rating. Two fundamental errors from the "expert", eh? Makes me question just how expert he really is. Matt |
On May 29, 8:55 pm, Matt Whiting wrote:
George wrote: I think it was 1995, at Oshkosh, I attended a forum on the differences between auto fuel and avgas. It was presented by a fellow who owned and operated one of the few refinerys which produce avgas. IIRC, snip makes the most power. And burn speed is not related to octane rating. Two fundamental errors from the "expert", eh? Makes me question just how expert he really is. Matt OK Matt, Which "expert" are you trying to insult? The author who went to a one hour forum about twelve years ago, or the poor guy who gives a talk at Oshkosh, which may or may not be remembered accurately by anybody twelve years later ? Personally, I am glad that you know how many carbon atoms are in octane, but if you do know so much, why not share it without insult? We don't have enough space for me to list all the data I've forgotten these last 12 years or so, even if I could. |
George wrote:
On May 29, 8:55 pm, Matt Whiting wrote: George wrote: I think it was 1995, at Oshkosh, I attended a forum on the differences between auto fuel and avgas. It was presented by a fellow who owned and operated one of the few refinerys which produce avgas. IIRC, snip makes the most power. And burn speed is not related to octane rating. Two fundamental errors from the "expert", eh? Makes me question just how expert he really is. Matt OK Matt, Which "expert" are you trying to insult? Neither. I was simply stating a fact that I don't trust an expert that gets two fundamental things that wrong. The author who went to a one hour forum about twelve years ago, or the poor guy who gives a talk at Oshkosh, which may or may not be remembered accurately by anybody twelve years later ? Personally, I am glad that you know how many carbon atoms are in octane, but if you do know so much, why not share it without insult? There was no insult. Matt |
Fuel prices--BTU's per gal. | Jerry Wass | Home Built | 18 | May 30th 07 11:15 AM |
Fuel prices | Paul kgyy | Owning | 14 | October 19th 05 10:55 PM |
Fuel Prices | Ross Richardson | Owning | 60 | September 30th 05 02:06 AM |
Fuel Prices | ~R | Rotorcraft | 0 | September 10th 05 03:56 PM |
Fuel Prices | S Green | Piloting | 0 | May 9th 04 09:47 PM |
