BMW engine aircraft suitable?
"Ralf Mueller" wrote in message ... just read about the new BMW S 1000 RR bike. The complete engine assembly is less than 60 KG. Engine puts out 193HP (112 Nm, 12,000rpm). Wouldn't that one (slightly detuned) make a nice SLA powerplant ;-)) 193 HP ??? Are you positive about that number? I would like to see where that number came from, if it is available on the net, if you wouldn't mind. If it is correct, that should do rather nicely. People have flown BMW bike engines in the past. I believe that most of the successful ones have used a different gearbox to reduce the prop RPM. Seems to me that I remember that they adapted a Rotax gearbox to the job, but I doubt that there are any Rotax gearboxed that could handle 193 HP. -- Jim in NC |
Similar Threads | ||||
More Sukhoi Su-35 images (suitable as wallpaper!) | Canuck[_8_] | Aviation Photos | 0 | September 23rd 09 03:54 AM |
Aircraft suitable for zero g flight | David Findlay | Aerobatics | 2 | July 23rd 05 02:43 PM |
A suitable way to go on this NG? | Quilljar | Simulators | 4 | January 17th 05 09:05 PM |
Suitable glider avionics | James | Soaring | 0 | October 29th 04 03:54 AM |
Suitable coating for spring-steel wire? | Wright1902Glider | Home Built | 6 | February 9th 04 04:12 PM |
