Weight & Bal Calc ASK-21
Since this thread appeared, I contacted Matt Herron about phone apps. Getting the feeling it's not going to happen.
However, I downloaded the Appventive Weight + Balance app for Android and it works well. Will contact the developer with a couple of questions, primarily wanting to increase resolution an order of magnitude. It's $10, and can be with you when you're adding a passenger, water ballast, etc. I move the fuel tanks, rename them and use weight as the input for water ballast. Will also try Matt's SeeG program. The Jonker Sailplanes spreadsheet for the JS1 is the best I've used so far, wish all manufacturers had something like that to download. But spreadsheets aren't great on a smart phone. Jim |
I found these pages from the manual which are much clearer and, easy to print graph. http://www.alexander-schleicher.de/w...TM35_US_HB.pdf Question for anyone: How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)? To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear? |
On Sunday, November 1, 2015 at 7:21:27 AM UTC-5, Casey Cox wrote:
I found these pages from the manual which are much clearer and, easy to print graph. http://www.alexander-schleicher.de/w...TM35_US_HB.pdf Question for anyone: How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)? To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear? If you generally follow the diagram it ends up on the straight taper of the tail boom which is pretty long and non critical. Measure the length of your level, multiply by .052, and make a spacer that dimension. QED UH |
I found these pages from the manual which are much clearer and, easy to print graph. http://www.alexander-schleicher.de/w...TM35_US_HB.pdf Question for anyone: How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)? To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear? Here is wording in another manual; The horizontal reference line is the centre line of the fuselage tail cone or a 1000 : 45 wedge template levelled out on the top side of the fuselage aft portion |
If you generally follow the diagram it ends up on the straight taper of the tail boom which is pretty long and non critical. Measure the length of your level, multiply by .052, and make a spacer that dimension. QED UH Ok, thats sounds simple enough. I've never actually performed a W/B with an incidence board, but thought that the location would be more critical than you mentioned due to it seems fuselage booms taper slight at first and increases towards tail. Just a general observance though and never really measured or compared. Thanks. |
On Sunday, November 1, 2015 at 6:22:23 AM UTC-7, Casey Cox wrote:
On Sunday, November 1, 2015 at 7:21:27 AM UTC-5, Casey Cox wrote: I found these pages from the manual which are much clearer and, easy to print graph. http://www.alexander-schleicher.de/w...TM35_US_HB.pdf Question for anyone: How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)? To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear? Here is wording in another manual; The horizontal reference line is the centre line of the fuselage tail cone or a 1000 : 45 wedge template levelled out on the top side of the fuselage aft portion It is always easier to use a professional to weigh your glider. However, per my owner's manual, I did the math (1000:45/2) on a 50" piece of 2 x 4, cut the smaller piece (approx. 2.25 in) and duct taped it at a right angle. I then took the glider and my assy to our local A&P. He had a fancy digital incidence scale in addition to good aircraft weight scales. Although we went with his methodology, I was happy to see me homemade incidence taper was dead on. Design with a supercomputer, measure with a micrometer, cut with a sawzall... Cheers Gene |
Or, as we said in the Air Farce: Measure with a micrometer, mark with a
grease pencil, cut with an axe. I don't think we had supercomputers back then... On 11/1/2015 7:35 AM, GeneReinecke wrote: On Sunday, November 1, 2015 at 6:22:23 AM UTC-7, Casey Cox wrote: On Sunday, November 1, 2015 at 7:21:27 AM UTC-5, Casey Cox wrote: I found these pages from the manual which are much clearer and, easy to print graph. http://www.alexander-schleicher.de/w...TM35_US_HB.pdf Question for anyone: How does one calculate or develop what I've seen called (Wedge), (Level Line), (Incidence Board)? To ensure the fuselage is level, and in this case for the ASK-21 is 1000:52. And also in this case there is no reference of exact placement. Wouldn't it change the level if the board is more forward or more to the rear? Here is wording in another manual; The horizontal reference line is the centre line of the fuselage tail cone or a 1000 : 45 wedge template levelled out on the top side of the fuselage aft portion It is always easier to use a professional to weigh your glider. However, per my owner's manual, I did the math (1000:45/2) on a 50" piece of 2 x 4, cut the smaller piece (approx. 2.25 in) and duct taped it at a right angle. I then took the glider and my assy to our local A&P. He had a fancy digital incidence scale in addition to good aircraft weight scales. Although we went with his methodology, I was happy to see me homemade incidence taper was dead on. Design with a supercomputer, measure with a micrometer, cut with a sawzall... Cheers Gene -- Dan, 5J |
I just found one specific glider manual stating 1000:40 with 300 mm in front of vertical stabilizer. Either it makes some difference in this specific glider or the manufacture is more precise.
Casey |
Similar Threads | ||||
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
Flap Hinge Moment Calc | Bo | Home Built | 2 | February 2nd 05 10:26 AM |
Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 06:01 AM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
Route calc. | Montblack | Piloting | 0 | July 11th 03 01:52 AM |
