ASK21 vs G103
In a few weeks I'll take my check ride in an ASK21. All of my training
to date has been in a G103. The examiner told me the ASK is a lot like the Grob just better. any advice? I'm a little concerned about taking my check ride in a glider I've never seen, but not overly concerned. The performance looks pretty similar and they're both fixed gear ships. So I'm thinkin' "no big deal". Doug |
solo89 wrote:
In a few weeks I'll take my check ride in an ASK21. All of my training to date has been in a G103. The examiner told me the ASK is a lot like the Grob just better. any advice? we use both for basic training, and they are comparable. The ASK21 is even better in rudder/aileron harmony. When it comes to performance, the Grob may have one or two points, but this is not relevant for the check flight. Did you train on a a Twin I (Twin Astir) or a Twin III ? The Twin I is a taildragger, the Twin II/III has a nose wheel, as the ASK21, so the landing characteristic is the same. You will have no problems. Eggert |
On Fri, 17 Oct 2003 10:58:58 +0200, Eggert Ehmke
wrote: solo89 wrote: In a few weeks I'll take my check ride in an ASK21. All of my training to date has been in a G103. The examiner told me the ASK is a lot like the Grob just better. any advice? we use both for basic training, and they are comparable. The ASK21 is even better in rudder/aileron harmony. When it comes to performance, the Grob may have one or two points, but this is not relevant for the check flight. Did you train on a a Twin I (Twin Astir) or a Twin III ? The Twin I is a taildragger, the Twin II/III has a nose wheel, as the ASK21, so the landing characteristic is the same. You will have no problems. Agreed. The ASK-21 is more responsive and has a more powerful rudder. You may find the trim a little disconcerting at first but that will soon pass. Its by the side of the stick and has nothing comparable to the Grob's trim housing to act as a reference for the pre take-off setting. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
On Fri, 17 Oct 2003 11:55:10 +0100, Martin Gregorie
wrote: You may find the trim a little disconcerting at first but that will soon pass. Its by the side of the stick and has nothing comparable to the Grob's trim housing to act as a reference for the pre take-off setting. The 21 has a trim setting display on the right side of the cockpit. Bye Andreas |
On Fri, 17 Oct 2003 15:12:27 +0200, Andreas Maurer
wrote: On Fri, 17 Oct 2003 11:55:10 +0100, Martin Gregorie wrote: You may find the trim a little disconcerting at first but that will soon pass. Its by the side of the stick and has nothing comparable to the Grob's trim housing to act as a reference for the pre take-off setting. The 21 has a trim setting display on the right side of the cockpit. Ours doesn't, but then it is pretty old. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
On Fri, 17 Oct 2003 15:50:14 +0100, Martin Gregorie
wrote: The 21 has a trim setting display on the right side of the cockpit. Ours doesn't, but then it is pretty old. What serial no. is it? Bye Andreas |
Thanks to all for the input.
I've been flying the G103 Twin II Acro. (I guess the Acro is a wasted distinction these days.) It does indeed sound very similar to the ASK21. I'm glad to hear the rudder and ailerons are better balanced. I do sometimes have trouble with my coordination in the 103. Just a few more flights and lots of book time between me and the test. Doug |
chances are.. if you know the DE or he knows you..
the DE will not be concerned about the differences.. but may evaluate (though it is not part of the PTS) how quickly you adapt to the ASK-21... if you learned in a Grob.. then the ASK will be easier.. the DE will be concentrating on your general flying.. procedures and decision making.. BT "solo89" wrote in message om... Thanks to all for the input. I've been flying the G103 Twin II Acro. (I guess the Acro is a wasted distinction these days.) It does indeed sound very similar to the ASK21. I'm glad to hear the rudder and ailerons are better balanced. I do sometimes have trouble with my coordination in the 103. Just a few more flights and lots of book time between me and the test. Doug |
We (London Gliding Club) have a half dozen K21s of
various vintages up to brand new. I think only the newest have the trim indicator. In my view, one of the most useless pieces of equipment imaginable. Feeling the position of the trim lever is easier and safer. Rob At 16:00 17 October 2003, Andreas Maurer wrote: On Fri, 17 Oct 2003 15:50:14 +0100, Martin Gregorie wrote: The 21 has a trim setting display on the right side of the cockpit. Ours doesn't, but then it is pretty old. What serial no. is it? Bye Andreas |
various vintages up to brand new. I think only the newest have the trim indicator. In my view, one of the most useless pieces of equipment imaginable. Feeling the position of the trim lever is easier and safer. Rob But it is useful to have that so you can set the trim correctly before takeoff. |
