#151
Cirrus Lands via Parachute in Nantucket
Matt Whiting wrote:
Ron Wanttaja wrote: On Tue, 21 Aug 2007 14:00:07 GMT, Matt Whiting wrote: Ron Wanttaja wrote: No, I think the CFIs are just using the discretion that the AC 61-98A allows them. The first question they ask is generally, "What kind of flying do you do." Since I take my BFRs at the FBO on the base I'm based at, they all know the Fly Baby. I think they figure out that fifteen minutes under the hood won't do me a durn bit of good. That is true, but you must admit that your brand of flying is a pretty small segment of the overall private pilot segment. I personally believe that I'm obligated to maintain proficiency in all operations required in the Private and Instrument PTS documents. I have a similar obligation to maintain proficiency with respect to my PE license. The requirement is codified in case of the PE and not, as best I know, with respect to my pilot certificate. However, even if no FAR requires me to maintain proficiency relative to what was required to obtain my certificate, it simply is common sense to me to do so. Certainly; I think we're more agreeing than disagreeing. My comments were aimed at the party (not you) who was claiming that any level of IFR expertise less than that required for the Private check ride was unacceptable. Flying solo all the time DOES lead to bad habits, and I use the BFR to get them swatted down a bit. The fact that my BFRs never include hood work is an indication that the local CFIs agree that it's not necessary, for the flying I do. Yes, but a Cirrus pilot absolutely should be checked for basic instrument competency (180 turn, S&L, and 500 fpm climbs and descents). I should elaborate that I'm not just picking on Cirrus here. I would say the above for any high performance GA airplane. Matt |
#152
On Aug 22, 1:05 am, Ron Wanttaja wrote:
Certainly; I think we're more agreeing than disagreeing. My comments were aimed at the party (not you) who was claiming that any level of IFR expertise less than that required for the Private check ride was unacceptable. Actually, I agree with you that there are unusual exceptions to the general rule that I stated. There's an exception in cases where there's no possibility that emergency instument-flight skill could be useful. For most pilots, though--and certainly for the particular flight that's been under discussion here--it would be irresponsible to act as PIC without having maintained private-pilot proficiency at basic instrument flying. What I find especially distrubing is that some pilots have been arguing that it's ok for the typical pilot to fly for months or years with no effort to practice instrument flying, merely because the FAA does not spell out how much practice is required to stay proficient. |
#153
Matt,
If flying in a manner that just meets the MINIMUM standard to achieve a pilot certificate in the US is what you consider "perfect and infallible", Ok, one more try, then I'll give up: Im my experience (and I passed the same rides on the first try), there's a VAST difference between doing basic instrument flight as required for VFR pilots under the hood or with a CFI present, and flying in the clouds with no one but yourself present, fully knowing you have gotten yourself into a situation that a) you shouldn't be, b) you aren't legal to be in and c) has a very high potential to kill you. If you have the nerves of steel not to see a difference there, I can't help it, but my view is supported by the accident statistics with overwhelming clarity. VFR flight into IMC is a leading accident cause. Ask yourself why that might be. Then try to pull another "Ha, ha, ha" on me. -- Thomas Borchert (EDDH) |
#154
that's been under discussion here--it would be irresponsible to act as PIC without having maintained private-pilot proficiency at basic instrument flying. Care to explain why VFR into IMC is one of the leading accident causes? How do you explain the very obvious disconnect between what you postulate a regular, average pilot's abilities to be - and reality? -- Thomas Borchert (EDDH) |
#155
On Aug 22, 9:23 am, Thomas Borchert
wrote: For most pilots, though--and certainly for the particular flight that's been under discussion here--it would be irresponsible to act as PIC without having maintained private-pilot proficiency at basic instrument flying. Care to explain why VFR into IMC is one of the leading accident causes? How do you explain the very obvious disconnect between what you postulate a regular, average pilot's abilities to be - and reality? Yes, I'm glad to explain. You're confusing competence with perfection. Private-pilot competence at instrument flying means this: if a pilot with that competence accidentally enters IMC, and she realizes she's in IMC and tries to fly by instruments, and the conditions aren't complicated (that is, there's no icing, TS, proximity to challenging terrain, etc.), then the pilot can fly the plane with only a small chance of making a fatal mistake. But given many such occurrences, that small chance will sometimes manifest itself, so there will still be some crashes. In addition, many (perhaps the large majority) of the VFR-into-IMC crashes result because the pilot did NOT maintain basic instrument competence, or because the accidentally-encountered instrument conditions were NOT uncomplicated. So there's no disconnect at all between my statement above and the occurrence of some VFR-into-IMC accidents. My statement in no way implies that such accidents can never occur, even for competent pilots. |
#156
chance of making a fatal mistake. But given many such occurrences, that small chance will sometimes manifest itself, so there will still be some crashes. "Many such occurences"??? What do you base that statement on? Pilots (competent ones, at that) regularly fly into clouds while VFR? In addition, many (perhaps the large majority) of the VFR-into-IMC crashes result because the pilot did NOT maintain basic instrument competence, or because the accidentally-encountered instrument conditions were NOT uncomplicated. So the majority of pilots is not competent? Hmm. As far as can see, the disconnect is still there. And I also think it's at the heart of this discussion. -- Thomas Borchert (EDDH) |
#157
On Aug 22, 9:19 am, Thomas Borchert
wrote: Matt, If flying in a manner that just meets the MINIMUM standard to achieve a pilot certificate in the US is what you consider "perfect and infallible", Ok, one more try, then I'll give up: Im my experience (and I passed the same rides on the first try), there's a VAST difference between doing basic instrument flight as required for VFR pilots under the hood or with a CFI present, and flying in the clouds with no one but yourself present, fully knowing you have gotten yourself into a situation that a) you shouldn't be, b) you aren't legal to be in and c) has a very high potential to kill you. I completely agree. There is indeed a vast difference. IMC is indeed harder. But no one has been saying that because you can fly with foggles to PTS standards, you can therefore fly in IMC to PTS standards. Rather, the claim is just that if you can fly with foggles to PTS standards, then you can very probably manage to keep the plane upright for a few minutes in roughly straight and roughly level flight in uncomplicated IMC. Flying to PTS standards is much HARDER than what you have to do to turn around and head vaguely north (say) in order to get back to nearby VMC. my view is supported by the accident statistics with overwhelming clarity. Not even close. Look at the 2006 Nall Report. There were a total of 49 fatal weather accidents. The report says that "most" were VMC into IMC--let's say about 30. Now, how many of those involved a PTS- proficient pilot in uncomplicated IMC? We don't know, but if half of those crashes involved challenging IMC, and if (independently) half involved non-proficient pilots (say, ones who never practice instrument flying after getting their certificate), then we're down to 7 or 8 accidents involving a proficient pilot in uncomplicated IMC. Of course, that's just a guess. The actual number could be lower (to a minimum of zero) or higher (to a maximum of 49). But unless you have some additional data, there is no "overwhelming clarity"--indeed, no evidence at all--that more than a handful of accidents occur when a PTS-proficient pilot inadvertantly enters uncomplicated IMC. Instead, the statistics are consistent with the claim that a PTS-proficient pilot can very probably manage to fly out of simple IMC. Of course, there's no guarantee. Competence does not imply perfection, and even a competent pilot has a small chance of making a fatal mistake in ANY phase of flight. |
#158
On Wed, 22 Aug 2007 15:23:22 +0200, Thomas Borchert
wrote: For most pilots, though--and certainly for the particular flight that's been under discussion here--it would be irresponsible to act as PIC without having maintained private-pilot proficiency at basic instrument flying. Care to explain why VFR into IMC is one of the leading accident causes? How do you explain the very obvious disconnect between what you postulate a regular, average pilot's abilities to be - and reality? Actually, VFR into VMC *is* a leading accident cause, but the rate is lower than the leading cause by nearly an order of magnitude. Though it depends on how you lump together causes, really. As many of you now, I've done an in-depth analysis of homebuilt accidents in the 1998-2004 timeframe. As a Control Group, I did a similar analysis of Cessna 172/Cessna 210 accidents. Here's how my results came out: Cause Percent General Pilot Error 52.5% Fuel Exhaustion/Starvation 8.9% VFR to IFR 5.2% Undetermined Loss of Power 4.7% Maintenance Error 4.6% Other Mechanical 4.2% Engine Mechanical 3.7% Buzzing 2.7% Inadequate Preflight 1.6% Carb Ice 1.2% Fuel System 0.9% Fuel Contamination 0.5% Manufacturer Error 0.3% Other 6.8% (lumps in 12 less-common events like midairs, pilot incapacitation, etc.) "General Pilot Error" in my analysis includes any accident that stemmed from the pilot's improper use of stick-and-rudder skills, including the judgement aspects (undershoots, overshoots, etc.). So about 5% of the 172/210 accidents were due to an attempt to continue VFR flight into IFR conditions. I don't know how much different the Cirrus would be than my control group, but my cursory look over a couple of years seems to show it's similar. Cases where the CAPS was used...or where the CAPS could/should have been used... are still outnumbered by the instances of overshoots/undershoots, loss of control on rollout, brake fires, etc. Ron Wanttaja |
#159
On Aug 22, 10:30 am, Thomas Borchert
wrote: In addition, many (perhaps the large majority) of the VFR-into-IMC crashes result because the pilot did NOT maintain basic instrument competence, or because the accidentally-encountered instrument conditions were NOT uncomplicated. So the majority of pilots is not competent? Hmm. No, that doesn't follow at all! Surely the nonproficient pilots would be OVERREPRESENTED in the sample consisting of fatal crashes! So your extrapolation to the general pilot population is completely spurious. |
#160
Similar Threads | ||||
Customs at KACK (Nantucket)? | [email protected] | Piloting | 4 | July 9th 06 05:42 PM |
Martha's Vineyard or Nantucket | Paul | Owning | 9 | February 20th 06 10:39 PM |
N1 lands in BED: | Bush | Piloting | 50 | February 17th 06 08:16 AM |
Ack and Back-Plane Headed To Nantucket Missing: | Bushleague | Piloting | 5 | December 5th 05 01:22 PM |
Nantucket airport | John S | Piloting | 7 | November 4th 04 07:32 PM |
