#181
Cirrus Lands via Parachute in Nantucket
Ron Wanttaja wrote:
On Wed, 22 Aug 2007 15:23:22 +0200, Thomas Borchert wrote: For most pilots, though--and certainly for the particular flight that's been under discussion here--it would be irresponsible to act as PIC without having maintained private-pilot proficiency at basic instrument flying. Care to explain why VFR into IMC is one of the leading accident causes? How do you explain the very obvious disconnect between what you postulate a regular, average pilot's abilities to be - and reality? Actually, VFR into VMC *is* a leading accident cause, but the rate is lower than the leading cause by nearly an order of magnitude. Though it depends on how you lump together causes, really. As many of you now, I've done an in-depth analysis of homebuilt accidents in the 1998-2004 timeframe. As a Control Group, I did a similar analysis of Cessna 172/Cessna 210 accidents. Here's how my results came out: Cause Percent General Pilot Error 52.5% Fuel Exhaustion/Starvation 8.9% VFR to IFR 5.2% Undetermined Loss of Power 4.7% Maintenance Error 4.6% Other Mechanical 4.2% Engine Mechanical 3.7% Buzzing 2.7% Inadequate Preflight 1.6% Carb Ice 1.2% Fuel System 0.9% Fuel Contamination 0.5% Manufacturer Error 0.3% Other 6.8% (lumps in 12 less-common events like midairs, pilot incapacitation, etc.) "General Pilot Error" in my analysis includes any accident that stemmed from the pilot's improper use of stick-and-rudder skills, including the judgement aspects (undershoots, overshoots, etc.). So about 5% of the 172/210 accidents were due to an attempt to continue VFR flight into IFR conditions. I don't know how much different the Cirrus would be than my control group, but my cursory look over a couple of years seems to show it's similar. Cases where the CAPS was used...or where the CAPS could/should have been used... are still outnumbered by the instances of overshoots/undershoots, loss of control on rollout, brake fires, etc. Ron Wanttaja Ron, what is VFR into IFR and IFR conditions. Is this anything like VFR into IMC? :-) Matt |
#182
Matt, If flying in a manner that just meets the MINIMUM standard to achieve a pilot certificate in the US is what you consider "perfect and infallible", Ok, one more try, then I'll give up: Im my experience (and I passed the same rides on the first try), there's a VAST difference between doing basic instrument flight as required for VFR pilots under the hood or with a CFI present, and flying in the clouds with no one but yourself present, fully knowing you have gotten yourself into a situation that a) you shouldn't be, b) you aren't legal to be in and c) has a very high potential to kill you. If you have the nerves of steel not to see a difference there, I can't help it, but my view is supported by the accident statistics with overwhelming clarity. VFR flight into IMC is a leading accident cause. Ask yourself why that might be. Then try to pull another "Ha, ha, ha" on me. That is why this should be regularly practiced and checked during every BFR. I once accidentally flew into IMC prior to getting my instrument rating. I did as I was trained and transitioned to instruments, made a 180 and within a couple of minutes was out of the snow storm and back into VMC. It was a shock at first, but then the training kicked in and I executed as taught. It wasn't a big deal. Then again, I had a crusty old instructor who really taught you how to fly and every BFR checked the stuff that people didn't practice often such as flying on instruments. I'm always amazed when I hear of BFRs that cover takeoffs and landings and stuff you do every flight and completely ignore the stuff like simulated emergency landings, fire in the cockpit, electrical failure, inadvertent flight into IMC, etc., that you almost never encounter during normal flight. The accident statistics support that many pilots are not competent. No disagreement from me on that point. However, this has nothing to do with "perfect and infallible" and everything to do with basic competence of instruction and maintaining proficiency on your own between BFRs. Matt |
#183
Ron Rosenfeld wrote:
On Sat, 18 Aug 2007 16:52:04 -0400, Owen Rogers wrote: Looks like another save for BRS and Cirrus. Apparently a Cirrus was attempting to land ACK VFR last night when they ran into weather (fog and low visibility after sunset on the island are common in the summer). They pulled the Ballistic Recovery System parachute about 5 miles northeast of ACK. The two aboard had minor injuries but will be ok. Nobody was injured on the ground. Here is a news link: http://www.capecodonline.com/apps/pb...180319/-1/NEWS Other reports said that it was a Cirrus, although the make/model hasn't been confirmed yet. And finally, the NTSB preliminary report: http://www.ntsb.gov/ntsb/brief.asp?e...21X01216&key=1 If the report is accurate, we have a non-instrument rated pilot who, when ACK suddenly "went IFR", "informed the controller that he was capable of executing the ILS approach". Five minutes later, Cape Approach informed the tower controller that the pilot had deployed the parachute. If the report is accurate, the pilot is not only incompetent but a liar as well. It will be curious to see the full report... Matt |
#184
On Sun, 19 Aug 2007 10:45:41 -0700, Ron Wanttaja
wrote: On Sun, 19 Aug 2007 17:05:47 GMT, Matt Whiting wrote: Thomas Borchert wrote: If a pilot pulls the chute because he judges an uncontrolled parachute descent to be less risky than trying to keep the plane upright for a few minutes in simple instrument cruise flight, then he has judged himself to have less than the minimum required competence for a private pilot. That's BS, plain and simple. The instrument flying requirement is required for the test, barely. There is no requirement at all to keep it current. Otherwise, all certified pilots would be instrument pilots. That's BS, at least in the US. I can't speak for other parts of the world. That is why we have biennial flight reviews, to see if currency is being maintained. A private pilot should be capable of doing anything required of their certificate. Flying straight and level on instruments is a far cry from being instrument rated. I've been taking BFRs since they were instituted, and don't believe I've been put under the hood more than once or twice since my original Private flight test. And *that* was ~35 years ago. My experience has been the opposite. I don't remember having had a BFR without going under the hood. OTOH I always eat the same thing for breakfast just in case some one asks I'll get it right. Every time Cirrus BRS deployments come up, I'm reminded of the anti-parachute arguments during WWI. Ron Wanttaja |
#185
"Matt Whiting" wrote in message
... Ron, what is VFR into IFR and IFR conditions. Is this anything like VFR into IMC? :-) Matt.. VFR into IFR conditions is when you slew that Cessna 172 above FL180 grin -- Doug Semler, MCPD a.a. #705, BAAWA. EAC Guardian of the Horn of the IPU (pbuhh). The answer is 42; DNRC o- Gur Hfrarg unf orpbzr fb shyy bs penc gurfr qnlf, abbar rira erpbtavmrf fvzcyr guvatf yvxr ebg13 nalzber. Fnq, vfa'g vg? |
#186
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Aluckyguess wrote: You know in reality it took a lot of balls to pull that chute. Something in the pilots mind was really wrong. Imagine yourself looking over to the passenger after minutes that seemed like hours and saying, dude hold on im going to pull the chute. the passenger replies what, what's the problem. The problem even with all this cool **** in front of me I have no idea where I'm at. Or maybe he said we just lost the alternator and the backup isn't enough juice for me to fly in imc. As they are floating down into the abyss the pilot looks over and says I hope this thing floats. I really cant imagine how scary this ordeal was. Weren't you one of the guys that was bitching because we didn't have enough information to discuss the issue? Now you are adding in alternator failures and even the conversation that went on in the cockpit. I am just making something up, a scenario out of the blue. I have no idea what happened. I do know the pilot and passenger are still alive and to me that is all that matters. |
#187
On Wed, 22 Aug 2007 22:18:36 GMT, Matt Whiting wrote:
Ron, what is VFR into IFR and IFR conditions. Is this anything like VFR into IMC? :-) Whatever you guys with the flickery-humming things in your instrument panel call it when the forward view looks like the inside of a cow. :-) Ron Wanttaja |
#188
On Wed, 22 Aug 2007 15:34:35 +0000 (UTC), Dylan Smith
wrote: On 2007-08-22, Ron Wanttaja wrote: I've had one gen-u-wine emergency in my flying life, an engine failure in my 150 about 23 years ago. Hmm. Were you the Ron Wanttaja who wrote the ILAFFT about that incident? Something to do with fuel contamination, if I remember right. No, that was my evil twin, Ron "Skippy" Wanttaja. Yep, t'was me. May 1987, reprinted in ILAFFT #3. Strange, the Usenet posting that I did after the event is *almost* on Google. When I search for it, I find a couple of responses, but not the original article. Just a follow-up by sometime who wanted to tell their own story, and a smart-a** response from Ron Natalie. Funny how things never change. :-) Ron Wanttaja |
#189
#190
And finally, the NTSB preliminary report: http://www.ntsb.gov/ntsb/brief.asp?e...21X01216&key=1 If the report is accurate, we have a non-instrument rated pilot who, when ACK suddenly "went IFR", "informed the controller that he was capable of executing the ILS approach". Five minutes later, Cape Approach informed the tower controller that the pilot had deployed the parachute. That sort of revives the stupid pilot theory. Actually that is a good initial guess for most GA crashes. Ron Lee |
Similar Threads | ||||
Customs at KACK (Nantucket)? | [email protected] | Piloting | 4 | July 9th 06 05:42 PM |
Martha's Vineyard or Nantucket | Paul | Owning | 9 | February 20th 06 10:39 PM |
N1 lands in BED: | Bush | Piloting | 50 | February 17th 06 08:16 AM |
Ack and Back-Plane Headed To Nantucket Missing: | Bushleague | Piloting | 5 | December 5th 05 01:22 PM |
Nantucket airport | John S | Piloting | 7 | November 4th 04 07:32 PM |
