cleaning confor foam
Old June 26th 18, 04:21 AM posted to rec.aviation.soaring
Default cleaning confor foam
I had a blue confor foam pad in the seatpan of my my glider. I landed in Cordele right before a massive rainstorm, so the inside of the cockpit got wet.
The foam sat wet for two weeks and got moldy/mildue and smelly.
Do you know of any way to clean it?
By its very nature it is very porous so the amount of surface area is huge, and probably beyond hope, but thought I'd ask if anyone has ideas on how to save it?
It does not look bad. Soap and water helped some on the smell but how would it ever dry out without growing more mold?
Best I can tell Urethane is not negatively affected by bleach so I may try to soak it in a 10% solution.
Chris
Old June 26th 18, 05:14 AM posted to rec.aviation.soaring
Ben Hirashima
Maybe try to dry it with warm air. If it dries fast enough, mold won't have time to grow. Put it in front of a space heater that has a fan built in. Of course, be careful not to get it too hot.
Old June 26th 18, 05:29 AM posted to rec.aviation.soaring
Bleach kills mold but could shorten life of the foam-use minimal
Less damaging-soak foam with baking soda solution and like the previous poster said lots of dry air and air flow
Confor foam cushions - firmness? Movses Babayan Soaring 14 March 23rd 17 10:47 PM
Confor Seat Foam for Sale Casey[_2_] Soaring 2 January 18th 16 03:20 AM
Foam ? Neil Home Built 2 June 14th 04 04:10 PM
Foam BD5ER Home Built 17 September 20th 03 04:07 PM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 05:01 PM
