Source for aileron/flaperon linkage fairings or covers?
Old September 7th 18, 10:53 PM posted to rec.aviation.soaring
Bret Hess
Default Source for aileron/flaperon linkage fairings or covers?
Where can we buy replacement split plastic fairings/covers for aileron or flaperon linkages?
Old September 7th 18, 11:08 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
The answer almost certainly depends on the make (and model) of glider,
but you haven't included that somewhat essential detail.
Martin | martin at
Gregorie | gregorie dot org
Old September 7th 18, 11:16 PM posted to rec.aviation.soaring
Bret Hess
PIK20E is my model. I hope there are sources where you can buy them by dimension.
Old September 7th 18, 11:36 PM posted to rec.aviation.soaring
I ran into that problem several years ago with the molded-in fairings on my Pegasus. Got tired of repairing them, so I made a male plug mold and had several sets vacuum formed. They were then cut out with a bandsaw, leaving a flange (3/8 in. wide) to sit flat on the surface. I removed the old set, down to the surface of the wing and ailerons and then stuck the new ones on with double-sided tape and then wing tape over the flange. Naturally, I haven't dinged one since.
Don't know whether they would work with the PIK-20E, but I do have some extra sets. I have sold a few sets (4 large forward fairings and 2 narrower ones that nest inside the large ones) to other Pegasus owners for $48/set including postage in the US. Contact me at: info (at) m m f a b r i c a t i o n (dot) com (remove spaces).
Info on strange linkage ? Dave Nadler Soaring 8 September 23rd 10 12:35 PM
Rod end bearing for DG 200 aileron linkage JC Soaring 1 August 11th 10 03:14 PM
stemme flaperon mix control bjarthur Soaring 6 October 22nd 08 02:23 AM
LS3 flaperon gap seal template needed Birdbones Soaring 2 May 14th 05 12:46 AM
Piper nosewheel steering linkage Jeremy Lew Piloting 2 November 19th 03 03:17 PM
