Lyc IO-540 won't make RPM.
Do you ever have those days where you're just scratching your head?
I've got an IO-540 (strapped to the right side of an E-Model Piper Aztec) that won't generate full RPM. Let me describe the takeoff sequence. During the run-up, both the feather check and the mag check are normal (done at 1700 RPM and 2000 RPM respectively.) During the takeoff roll, all seems normal, but initial climb is sluggish (not alarmingly so, but just enough to notice). The right side RPM indicator shows about 2450 RPM, while the left side is showing just above 2600 RPM (as usual). When setting climb power, bringing the power back to 25-inches on both sides will not cause the left side to lose measurable RPM, but the right side loses about 100. Synchronizing the propellers does cause the "beating" to go away when the RPM indicators indicate the same RPM, so I'm confident that the RPM gauge is reading correctly. During the initial tear down, it was noticed that the set-screw for the right governor was set at about as high an RPM as possible. So the initial feeling was that the governor was having a bad day. So far, we've: 1. Sent he governor out for overhaul. (Prop shop reported that it was fine.) 2. Swapped the propellers between the engines. (Problem does not follow the propeller.) 3. Swapped the governors between the engines. (Problem does not follow the governor.) 4. Verified full travel on the propeller controls (both in the cockpit and at the governor). The tech reps are suggesting that we send the engine back to Mattituck (it's a factory remanufactured engine which has been "Mattitucked" with about 100 hours on it), but I get the feeling that the tech reps and mechanics are essentially in guessing mode. Does anyone have any suggestions on what else to think about before we pull the engine? Thanks! -Rob |
Oil pump? Oil galleys and passages through the engine to the governor? I
wonder if the engine or oil pump is providing enough oil volume or pressure to the governor to hold the prop in full fine pitch. After a previous owner of our Aztec had our right engine overhauled at Penn Yan the prop would feather during large power reductions. He pulled the engine, sent it back to Penn Yan and they found one of the internal oil ports in the engine leading to the governor had been sized wrong. Sorry I can't be more specific, but the return paperwork on the engine is pretty non-descript, it only mentions resizing the oil galley or port to a specific Lycoming service instruction number. Jim wrote in message ups.com... Do you ever have those days where you're just scratching your head? I've got an IO-540 (strapped to the right side of an E-Model Piper Aztec) that won't generate full RPM. Let me describe the takeoff sequence. During the run-up, both the feather check and the mag check are normal (done at 1700 RPM and 2000 RPM respectively.) During the takeoff roll, all seems normal, but initial climb is sluggish (not alarmingly so, but just enough to notice). The right side RPM indicator shows about 2450 RPM, while the left side is showing just above 2600 RPM (as usual). When setting climb power, bringing the power back to 25-inches on both sides will not cause the left side to lose measurable RPM, but the right side loses about 100. Synchronizing the propellers does cause the "beating" to go away when the RPM indicators indicate the same RPM, so I'm confident that the RPM gauge is reading correctly. During the initial tear down, it was noticed that the set-screw for the right governor was set at about as high an RPM as possible. So the initial feeling was that the governor was having a bad day. So far, we've: 1. Sent he governor out for overhaul. (Prop shop reported that it was fine.) 2. Swapped the propellers between the engines. (Problem does not follow the propeller.) 3. Swapped the governors between the engines. (Problem does not follow the governor.) 4. Verified full travel on the propeller controls (both in the cockpit and at the governor). The tech reps are suggesting that we send the engine back to Mattituck (it's a factory remanufactured engine which has been "Mattitucked" with about 100 hours on it), but I get the feeling that the tech reps and mechanics are essentially in guessing mode. Does anyone have any suggestions on what else to think about before we pull the engine? Thanks! -Rob |
That's interesting. My thought was that, as the oil pressure was OK (as
is the nitrogen pressure in the propeller hubs) we should be OK. Did you see normal oil pressure? Thanks, -Rob Jim Burns wrote: Oil pump? Oil galleys and passages through the engine to the governor? I wonder if the engine or oil pump is providing enough oil volume or pressure to the governor to hold the prop in full fine pitch. After a previous owner of our Aztec had our right engine overhauled at Penn Yan the prop would feather during large power reductions. He pulled the engine, sent it back to Penn Yan and they found one of the internal oil ports in the engine leading to the governor had been sized wrong. Sorry I can't be more specific, but the return paperwork on the engine is pretty non-descript, it only mentions resizing the oil galley or port to a specific Lycoming service instruction number. Jim wrote in message ups.com... Do you ever have those days where you're just scratching your head? I've got an IO-540 (strapped to the right side of an E-Model Piper Aztec) that won't generate full RPM. Let me describe the takeoff sequence. During the run-up, both the feather check and the mag check are normal (done at 1700 RPM and 2000 RPM respectively.) During the takeoff roll, all seems normal, but initial climb is sluggish (not alarmingly so, but just enough to notice). The right side RPM indicator shows about 2450 RPM, while the left side is showing just above 2600 RPM (as usual). When setting climb power, bringing the power back to 25-inches on both sides will not cause the left side to lose measurable RPM, but the right side loses about 100. Synchronizing the propellers does cause the "beating" to go away when the RPM indicators indicate the same RPM, so I'm confident that the RPM gauge is reading correctly. During the initial tear down, it was noticed that the set-screw for the right governor was set at about as high an RPM as possible. So the initial feeling was that the governor was having a bad day. So far, we've: 1. Sent he governor out for overhaul. (Prop shop reported that it was fine.) 2. Swapped the propellers between the engines. (Problem does not follow the propeller.) 3. Swapped the governors between the engines. (Problem does not follow the governor.) 4. Verified full travel on the propeller controls (both in the cockpit and at the governor). The tech reps are suggesting that we send the engine back to Mattituck (it's a factory remanufactured engine which has been "Mattitucked" with about 100 hours on it), but I get the feeling that the tech reps and mechanics are essentially in guessing mode. Does anyone have any suggestions on what else to think about before we pull the engine? Thanks! -Rob |
We didn't own the airplane when this occurred, we bought it just after the
engine came back from Penn Yan and the seller explained it to me. But, yes, he said oil pressure indicated normal. Jim wrote in message ups.com... That's interesting. My thought was that, as the oil pressure was OK (as is the nitrogen pressure in the propeller hubs) we should be OK. Did you see normal oil pressure? Thanks, -Rob Jim Burns wrote: Oil pump? Oil galleys and passages through the engine to the governor? I wonder if the engine or oil pump is providing enough oil volume or pressure to the governor to hold the prop in full fine pitch. After a previous owner of our Aztec had our right engine overhauled at Penn Yan the prop would feather during large power reductions. He pulled the engine, sent it back to Penn Yan and they found one of the internal oil ports in the engine leading to the governor had been sized wrong. Sorry I can't be more specific, but the return paperwork on the engine is pretty non-descript, it only mentions resizing the oil galley or port to a specific Lycoming service instruction number. Jim wrote in message ups.com... Do you ever have those days where you're just scratching your head? I've got an IO-540 (strapped to the right side of an E-Model Piper Aztec) that won't generate full RPM. Let me describe the takeoff sequence. During the run-up, both the feather check and the mag check are normal (done at 1700 RPM and 2000 RPM respectively.) During the takeoff roll, all seems normal, but initial climb is sluggish (not alarmingly so, but just enough to notice). The right side RPM indicator shows about 2450 RPM, while the left side is showing just above 2600 RPM (as usual). When setting climb power, bringing the power back to 25-inches on both sides will not cause the left side to lose measurable RPM, but the right side loses about 100. Synchronizing the propellers does cause the "beating" to go away when the RPM indicators indicate the same RPM, so I'm confident that the RPM gauge is reading correctly. During the initial tear down, it was noticed that the set-screw for the right governor was set at about as high an RPM as possible. So the initial feeling was that the governor was having a bad day. So far, we've: 1. Sent he governor out for overhaul. (Prop shop reported that it was fine.) 2. Swapped the propellers between the engines. (Problem does not follow the propeller.) 3. Swapped the governors between the engines. (Problem does not follow the governor.) 4. Verified full travel on the propeller controls (both in the cockpit and at the governor). The tech reps are suggesting that we send the engine back to Mattituck (it's a factory remanufactured engine which has been "Mattitucked" with about 100 hours on it), but I get the feeling that the tech reps and mechanics are essentially in guessing mode. Does anyone have any suggestions on what else to think about before we pull the engine? Thanks! -Rob |
A bad cam is one likely problem... The other and more ominous is that
you have a binding engine and are set up for catastrophic failure/seizure on takeoff... A 100 hour engine that won't make RPM is a hand grenade with the pin pulled... Don't fly it again and send it back... Insist they put 3 hours on the dyno after it is repaired and that it make target HP and RPM... denny - old pilot with the scars, financial and otherwise, to prove it... |
Trust me. I'm not flying an airplane with unexplained power loss or a
misbehaving propeller. If you lose the left one, the right one is sick. If you lose the right one, maybe it won't feather. (I plan on getting old.) I'm just trying to figure out if there is something else to look at before things get really expensive and time consuming. (It wouldn't be fun to pull the engine and send it out to have it turn out to be fine, and you just can't swap them around as easily as governors. :-)). -Rob Denny wrote: A bad cam is one likely problem... The other and more ominous is that you have a binding engine and are set up for catastrophic failure/seizure on takeoff... A 100 hour engine that won't make RPM is a hand grenade with the pin pulled... Don't fly it again and send it back... Insist they put 3 hours on the dyno after it is repaired and that it make target HP and RPM... denny - old pilot with the scars, financial and otherwise, to prove it... |
A couple of choices: Engine isn't producing full
horsepower-- or prop/gov are faulty. If the prop will run at command RPM with variation in manifold pressure while in flight, I'd say governor is OK. If it won't go to redline, but runs correctly at other rpms, it's a linkage or command problem. Some props won't go clear to redline until you roll along awhile. That is a function of the fine pitch setting on the prop. Props should be alike. When you are tooling along, it should go to redline rpm no problem even if engine is pretty lame. As you change manifold pressure, does the rpm overshoot and undershoot the target by small amounts? That would be normal. If it's low rpm only on takeoff, it could be the prop is on the fine pitch stop and the engine just can't spin it to red line there. If it's the engine, I'm in agreement with the camshaft crowd. This is a problem on Dukes. On those, you can detect the problem by comparing fuel flows... if the ff is low, the engine isn't pumping enough air which is usually a cam. I'd think if it was a friction problem it would have destroyed itself early in the flight. Think of the kilowatts of power involved!! Bill Hale BPPP instructor/ A&P wrote: Trust me. I'm not flying an airplane with unexplained power loss or a misbehaving propeller. If you lose the left one, the right one is sick. If you lose the right one, maybe it won't feather. (I plan on getting old.) I'm just trying to figure out if there is something else to look at before things get really expensive and time consuming. (It wouldn't be fun to pull the engine and send it out to have it turn out to be fine, and you just can't swap them around as easily as governors. :-)). -Rob Denny wrote: A bad cam is one likely problem... The other and more ominous is that you have a binding engine and are set up for catastrophic failure/seizure on takeoff... A 100 hour engine that won't make RPM is a hand grenade with the pin pulled... Don't fly it again and send it back... Insist they put 3 hours on the dyno after it is repaired and that it make target HP and RPM... denny - old pilot with the scars, financial and otherwise, to prove it... |
Denny wrote: A bad cam is one likely problem... I give em 100 to 300 hours. If it has been reground and not properly hardened. And if it is, then I would worry about the other side. What I don't know is why he would take a factory reman and send it to an engine overhaul shop? John |
On 11 Dec 2006 05:35:14 -0800, wrote:
The tech reps are suggesting that we send the engine back to Mattituck (it's a factory remanufactured engine which has been "Mattitucked" with about 100 hours on it), but I get the feeling that the tech reps and mechanics are essentially in guessing mode. snip Are we talking to Lycoming tech reps? Perhaps they need to re-read this: http://www.lycoming.textron.com/supp...ns/SI1462A.pdf My first thought is that you really need to verify the governor oil path to the propeller via the governor pad/crankcase through a passage in the front main bearing out the center of the crankshaft. If there is a governed oil loss at the crank/main bearing the engine will NOT turn up TO RPM. A restriction/reduction in the engine oil pressure supplied to the governor can have the same effect, but is not as common. If either happens on the most common single-engine installation (governor oil to increase pitch) you can't reduce prop RPM with the prop control on TO, on a twin (governor oil to decrease pitch), you can't make TO RPM. Haven't tallked to anybody at Mattituck for years, what do they say?? Regards; TC |
Similar Threads | ||||
Make Microsoft angry! | [email protected] | Piloting | 1 | June 30th 06 12:52 AM |
I need materials to make helium balloons. | John Doe | Home Built | 19 | December 7th 04 05:51 AM |
F/A-22 to make appearance at U.S. Air Force Academy parade | Otis Willie | Military Aviation | 14 | June 5th 04 11:11 PM |
Re; What do you think? | Kelsibutt | Naval Aviation | 0 | September 29th 03 06:55 AM |
Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 12:23 AM |
