#211
FADEC = complex
Mxsmanic wrote in
: It appears that you are describing another form of pilot error. If one believes that they can set an autopilot and then take a nap, *that* is the problem, not the behavior of the autopilot. A lot of commercial pilots do that. Really? Exactly how many? A lot of accidents have occurred when automated systems allowed crews to lose their situational awareness. Autopilots are particularly implicated in this respect, perhaps because they've been around so long and work so well. I recollect one accident specifically attributed to pilot's loss of situational awareness (GPS, though, not AutoPilot). The details can be read about he http://www.ntsb.gov/Publictn/2006/AAB0601.pdf The pilots, not the automation, were implicated in this accident for failing to properly monitor their situation. Numerous navigational aids were available to them, and they were expected to use them to ensure they maintained situational awareness, even when the autopilot was on. Can you point me to an NTSB report where the automation was implicated in the Pilot's lack of situational awareness? I just can't find any. |
#212
FADEC = complex
Mxsmanic wrote in
: Catastrophic failure is usually caused by software, not hardware. "Guns don't kill people... Software kills people... A message from the NRA..." |
#213
FADEC = complex
karl gruber writes:
No. Boeing used fly by wire at LEAST a decade before Airbus. On civilian aircraft? Which ones, and in what way? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#214
FADEC = complex
Judah writes:
Really? Exactly how many? A number of the ones I've talked to. Sometimes it's hard to stay awake. The pilots, not the automation, were implicated in this accident for failing to properly monitor their situation. Numerous navigational aids were available to them, and they were expected to use them to ensure they maintained situational awareness, even when the autopilot was on. Ultimately it is the pilot's responsibility. But that doesn't prevent it from happening. Can you point me to an NTSB report where the automation was implicated in the Pilot's lack of situational awareness? I just can't find any. I've already posted a list of accidents. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#215
FADEC = complex
Judah writes:
A corollary statement to the above is that when a driver sets the cruise- control in his car, he no longer needs to monitor his speed, and will fail to notice if the speed in his car begins to change or if he has blows out a tire. To some extent, that is true. A tire blowing out usually catches one's attention, but a subtle change in speed may not. Is this what you do when you turn on the cruise control in your car? I refuse to use cruise control. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#216
FADEC = complex
"Mxsmanic" wrote I wasn't keeping score. I just like to talk about aviation. No you just talk about things that you know nothing about, and sims. -- Jim in NC |
#217
FADEC = complex
Mxsmanic wrote: Neil Gould writes: The pilot is *never* "allowed to lose awareness of the aspect that has been removed". Of course he is. If he turns on the autopilot and tells it to hold a heading, the autopilot will do so (in many cases) by moving the ailerons without any intervention on his part. But he is fully aware of his heading. He takes a quick glance at the DG or the GPS to verify the AP is doing what it is supposed to be doing. Thus freeing much brain power for other things. Unless he is holding the yoke, he has no awareness of how the ailerons are being moved by the autopilot. He knows exactly how the AP manipulates the ailerons. Indeed, the whole value of the autopilot resides in the fact that it can adjust the ailerons without his help, and he need not know their exact positions. Yes. Without the autopilot, he'd have to be continuously aware of this, which is a non-trivial task. And yakes up valuable time and brain power that could be better spent elsewhere. The flip side is that the pilot may not be aware of any unusual moves that the autopilot is making. He is aware. If the thrust from the engines is becoming asymmetrical, Not likely on my single engine plane. Easily seen on any twin engine plane as the MP and RPM gauge is in the regular scan, autopilot or no. the pilot may not realize it, because the autopilot adjusts to compensate for the difference in thrust. By the time the autopilot reaches the limit of its capabilities and disconnects, the adjustments it has made may be very extreme, and the pilot may be so surprised by the sudden change in the attitude of the aircraft that he cannot recover his awareness quickly enough to avoid an accident. No, utter crap. It is not necessary for the most part, and that's precisely why the automation exists. You can keep saying this a million times if you want. And you will be wrong each and every one of those million times. |
#218
FADEC = complex
Judah wrote: A corollary statement to the above is that when a driver sets the cruise- control in his car, he no longer needs to monitor his speed, and will fail to notice if the speed in his car begins to change or if he has blows out a tire. Is this what you do when you turn on the cruise control in your car? He makes $600 a month, there is no cruise control in his inventory. Except on his driving sim. |
#219
FADEC = complex
Newps writes:
But he is fully aware of his heading. But he is not aware of the position of the ailerons. He would be aware of that without the autopilot. Thus, he has lost a certain amount of situational awareness. He knows exactly how the AP manipulates the ailerons. But he doesn't know their positions. Not likely on my single engine plane. It is impossible on a single-engine plane. You can keep saying this a million times if you want. And you will be wrong each and every one of those million times. It is true that repeating something doesn't make it right or wrong. Ponder on that. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#220
FADEC = complex
"Mxsmanic" wrote in message ... Morgans writes: That is EXACTLY opposite from what is the truth. Unfortunately, no, it is not. Each automation system removes some aspect of the pilot workload. An unavoidable consequence of this is that the pilot is also allowed to lose awareness of the aspect that has been removed (if he were not, there'd be no point in the automation). Automation in the cockpits allows the pilot to MONITOR the systems ... He could do that already, when he was flying the plane himself. And automation does not require monitoring; that's why it is called automation. And if it did require monitoring, it would serve no purpose. The purpose of automation is to make things automatic--that is, to remove the need for monitoring and intervention. This entire post is absolute nonsense. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Similar Threads | ||||
Is this a Complex Plane? | [email protected] | Piloting | 12 | December 7th 05 03:19 AM |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? | Jack Allison | Owning | 12 | June 14th 04 08:01 PM |
Complex Aircraft Question | Chris | General Aviation | 5 | October 18th 03 04:40 AM |
