Mystery help required
I took this at Chino, August 2008. I think it's a T-33 from memory.
Anyone able to confirm that Cheers and thanks. Glenn |
Mystery help required - 1 attachment
"Glenn" wrote
I took this at Chino, August 2008. I think it's a T-33 from memory. I don't think so Glenn. I flew one of the Navy's versions way back in 1959 and in this photo, I don't see the two side intakes for the engine air. |
"Glenn" wrote in news:4c56b838$0$28643$c3e8da3
@news.astraweb.com: I took this at Chino, August 2008. I think it's a T-33 from memory. Anyone able to confirm that |
Il 02/08/2010, Mitchell Holman ha detto :
"Glenn" wrote in news:4c56b838$0$28643$c3e8da3 @news.astraweb.com: I took this at Chino, August 2008. I think it's a T-33 from memory. Anyone able to confirm that It is a T-28 ciao Fabio |
@news.astraweb.com: I took this at Chino, August 2008. I think it's a T-33 from memory. Anyone able to confirm that Cheers and thanks. Glenn T-33, heres a shot of its predecessor, the P-80, except for the two large holes in the lower frames, the placement of the airtank against the bulkhead, and the cutouts for the engine on the rear frame for engine clearance, appears the same. you can even see the twin air inlets for the engine if you look close in both photos. |
@news.astraweb.com: I took this at Chino, August 2008. I think it's a T-33 from memory. Anyone able to confirm that Cheers and thanks. Glenn Borrowed & snipped Photo T-33 |
Anyone able to confirm that Cheers and thanks. Glenn Yup, T-33--- one can see the split air intakes, although it's pretty dark in the picture. I've served my time kneeling on those stringers and longerons, those loose cushions and cardboard boxes lying in there serve a good purpose. (no, not for sleeping when Chief is away!) Note: the large rectangular opening on the top of the fuselage is also an engine air inlet. two spring loaded doors are sucked open during high RPM ground operations when there is insufficient ram air coming through the fuselage ducts. (OK, I'm not sure about F-80, F-94 or TO-2/TV-2/T-1A/T2V-1) Old Chief Lynn |
Borrowed & snipped Photo T-33 You know, the engine sitting behind this aircraft looks much like a Rolls Royce Nene. I thought I knew everything, but now I'm not so sure. Did any US T-33's use the Rolls Royce? Old Chief Lynn |
"coffelt2" wrote in
: Borrowed & snipped Photo T-33 You know, the engine sitting behind this aircraft looks much like a Rolls Royce Nene. I thought I knew everything, but now I'm not so sure. Did any US T-33's use the Rolls Royce? Old Chief Lynn May not even be a US T-33, could be a Canadian built, hard to tell with the serial , From what I have read the US used the J-33-A Nene 10 perhaps ? I'm not an engine expert , not even a T-33 expert really not even an expert, at all in anything.. |
May not even be a US T-33, could be a Canadian built, hard to tell with the serial , From what I have read the US used the J-33-A Nene 10 perhaps ? I'm not an engine expert , not even a T-33 expert really not even an expert, at all in anything.. Don't destroy our image, John, we count on your posts on a daily basis. Good stuff, all the time! Old Chief Lynn |
Similar Threads | ||||
What is it? - mystery.jpg (1/1) [27K] | Netko | Aviation Photos | 12 | May 29th 10 02:43 PM |
IO-540 mystery | Paul Tomblin | Owning | 27 | August 31st 07 08:59 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
GPS Mystery | tony roberts | Owning | 5 | February 3rd 04 12:54 AM |
Halifax mystery | Geoffrey Sinclair | Military Aviation | 0 | November 14th 03 02:39 AM |
