Spray insulation for aluminum trailers
Old July 20th 18, 08:14 PM posted to rec.aviation.soaring
Default Spray insulation for aluminum trailers
How does one go about having insulation installed inside an aluminum trailer?
Are there specific spray-on materials that are commonly applied that auto repair/painting shops would know how to work with? Are there some specific materials one should avoid? Seems like the material needs to be fairly abrasion resistant. Is the outgassing of some materials potentially damaging to a glider?
All the glued on carpet in my trailer is falling off for the second time and I do not look forward to redoing it all when a spray insulation may do double duty as padding for the glider bits and pieces.
Old July 20th 18, 11:44 PM posted to rec.aviation.soaring
Spray foam may add considerable weight to the top and over-burden the lifting mechanisms. Proceed with caution.
Old July 22nd 18, 03:18 AM posted to rec.aviation.soaring
That's it! That is all this forum has to offer on the subject of applying spray insulation to an aluminum top trailer. After all the discussion of Aluminum vs fiberglass?
I guess that implies that not a single person on this forum has any real world knowledge about insulating an aluminum top trailer?
Old July 23rd 18, 07:17 PM posted to rec.aviation.soaring
Thank you.
This is the first concrete suggestion/example of a method and materials to insulate the aluminum top.
Old July 23rd 18, 08:51 PM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Well.... I didn't use spray foam because of the permanence of it and once you pull the trigger you are not going to be able to clean up the potential of a horrific mess.
I did however line the entire interior with 3/4" cut and fit, foil lined foam boards.
Foil was positioned in the 'up' position, pushing back at, and stopping the UV from entering the trailer and touching anything in the interior. The surface temps are way way down now. Interior temp meets the ambient air temps of course, but not much more. The little mouse I found kick'n it recently would probably agree too. Very inexpensive, it was a day job, and if the next guy can't deal with the WTF fit and finish of it all .... remove it all in a few hours.
Started out as an experiment, turned into another permanent work-around/jury-rig. Did I mention cheeeeeeap ...
Old July 23rd 18, 11:37 PM posted to rec.aviation.soaring
Nick Kennedy
You may want to contact a local home insulating company that handles spray foam.
Its difficult to get it smooth thou in my experience. Google different types of spray foam and see what you find, good luck!
Old July 24th 18, 01:37 AM posted to rec.aviation.soaring
George Haeh
Rigid foam panels are available at any home improvement store. The trick will be finding a double sided tape tolerant of temperature extremes - or use a construction adhesive.
Be very careful of clearances, especially by the trailing edges of the wings.
Old July 25th 18, 10:06 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
POPS wrote on 7/23/2018 12:51 PM:
foam boards.
How did you attach the foam panels to the aluminum top?
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old July 26th 18, 06:58 AM
Member
foam boards.
This style: Attached with hot glue. Why hot glue? So the next guy can peel it off and roll off the glue with pressure from a rubber door stopper, if he's a Felix type and can't handle the look of things.
Just trim the hangers pins for the flush fit/finish with the capture push on caps.
https://www.soundproofcow.com/produc...IaAonTEALw_wcB
Old August 6th 18, 09:24 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
POPS wrote on 7/25/2018 10:58 PM:
email me)
- "A Guide
push on caps.
http://tinyurl.com/y78sg8gx
Good idea! I didn't know there was such a thing.
Applying insulation to Aluminum Cobra trailer [email protected] Soaring 0 July 14th 18 04:54 AM
Used Destination Trailers for Sale | Portland | Als Trailers [email protected] Soaring 3 January 21st 18 04:43 AM
Break out the spray planes c-47 - File 2 of 2 - C-47 Spray 2.jpg (1/1) john Szalay Aviation Photos 0 August 8th 16 02:40 PM
Break out the spray planes Iwo Jima - File 1 of 4 - C-47 spray 1.jpg (1/1) john Szalay Aviation Photos 0 August 8th 16 02:39 PM
Aluminum top Cobra trailers leaks - how frequent? AK Soaring 2 March 31st 10 11:05 PM
