#11
generator mufflers
I always wanted to put a big car muffler on my generator. If it can quite a
V8, it should work on a small one lunger. Anyone try this? |
generator mufflers
You are dealing with sound pulses of a certain pattern and frequencies.
Large might not do as good a job as a muffler designed to the engine. -- Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "Chief McGee" wrote in message news:Rmdug.838844$084.688499@attbi_s22... I always wanted to put a big car muffler on my generator. If it can quite a V8, it should work on a small one lunger. Anyone try this? |
generator mufflers
"Chief McGee" wrote in message news:Rmdug.838844$084.688499@attbi_s22... I always wanted to put a big car muffler on my generator. If it can quite a V8, it should work on a small one lunger. Anyone try this? It works, but not as well as you might think. They are made with the resonance and flow rate of the bigger engine. The exhaust running into a bucket of steel -- Jim in NC wool would work better. |
generator mufflers
"flybynightkarmarepair" wrote in message ups.com... Neighbors will be happier if your run the exhaust into a galvanized bucket filled with water. The exhaust, via suitable hose (few are) or flexible metal tubing. should extend BELOW the water level. There should be a top on the bucket, vented around the edges to direct the much reduced noise DOWN. I'll bet the water muffler does well at reducing the exhaust note, (at the expense of considerable back pressure) but you will be surprised at how much noise those Home Depot class generators make that is NOT from the exhaust. About the only thing that will quiet them down is a heavy, remotely sited, generator shed. If you really want quiet, those inverter generators made by Yamaha and Honda are awesome. Expensive, but after all this is an aviation group. Money is obviously no object, right? Vaughn |
generator mufflers
Try two hub caps in the shape of a frizz-be(sp).Cut a hole in one cap
and weld it to the top of your exhaust pipe,weld the other cap one or two inches above the first cap.You won't hear the exhaust. LJ Chief McGee wrote: I always wanted to put a big car muffler on my generator. If it can quite a V8, it should work on a small one lunger. Anyone try this? |
generator mufflers
In article
, "Vaughn Simon" wrote: If you really want quiet, those inverter generators made by Yamaha and Honda are awesome. Expensive, but after all this is an aviation group. Money is obviously no object, right? Vaughn, I am having difficulty finding a Yamaha generator dealer locally. Yamaha's site is no help. Is this something that is a regional commodity? |
generator mufflers
generator mufflers
generator mufflers
One other thing to do is check around the rental yards for a brand called AGEKO? I belive. We used hundreds of their units in the refinery during hurricane season. I could stand next to a 50Kw unit running at full load and carry on a conversation with someone standing right next to the unit and not have to have our voices much above a whisper. They have the most sound deadened units that I've ever heard before. How they do their units would be a good lesson on what works well. Craig C. |
generator mufflers
wrote in message ps.com... One other thing to do is check around the rental yards for a brand called AGEKO? I belive. We used hundreds of their units in the refinery during hurricane season. I could stand next to a 50Kw unit running at full load and carry on a conversation with someone standing right next to the unit and not have to have our voices much above a whisper. They have the most sound deadened units that I've ever heard before. How they do their units would be a good lesson on what works well. Did you read the decibels on that 3000 watt Yamaha? 57 db! Unbelievable!! Light traffic is louder than that! Most of the other brands operate at 67 to 72, with some as loud as 80 db. They carry a nice price, but if quiet is important, those seem to be the units to go with. -- Jim in NC |
