How to - Tint a Plexiglass Canopy
I would like to tint the canopy on my asw-15.
I have heard that plexiglass does have gasses that are constantly released and will damage regular car tint applied to it. Would static cling tint sold from homedepot work for it? Anyone ever seen or heard of a glider tinted with film? The curvature shouldn't be a problem, I have a window tint side business for cars. I will need to cut the tint directly on the canopy. My only thought to not scratch it will be to place a thin flexible peice of metal strip behind the tint while cutting it. Any ideas? |
*Would static
cling tint sold from homedepot work for it? I have a small area of the static cling over/behind my head. I put it in an area that I almost never need to look through. I was just hoping to cut down on some heat. I did not need to join any additional pieces so that is not a problem. When sitting out in the sun the section of the canopy with the tint gets much hotter than the clear areas. I have not had any issue but I try to keep the canopy cover on when on the ground so differential heating does not become problematic. Chris |
On 17 juin, 04:25, Chris Ruf wrote:
*Would static cling tint sold from homedepot work for it? I have a small area of the static cling over/behind my head. *I put it in an area that I almost never need to look through. *I was just hoping to cut down on some heat. *I did not need to join any additional pieces so that is not a problem. When sitting out in the sun the section of the canopy with the tint gets much hotter than the clear areas. *I have not had any issue but I try to keep the canopy cover on when on the ground so differential heating does not become problematic. Chris Im interetsed by how you did it. Unfortunately, text gives no idea about details. Would you be kind to post pictures of your canopy? Cheers, Bruno |
Similar Threads | ||||
canopy tint | bagmaker | Soaring | 21 | August 9th 08 02:38 AM |
Plexiglass problem | Klettke | Home Built | 4 | July 31st 07 09:57 PM |
Plexiglass Glue | Jim Vincent | Soaring | 6 | March 23rd 07 08:25 PM |
Bonding Plexiglass | David Melby Cavalier | Home Built | 5 | November 21st 06 12:20 AM |
Windshields - tint or clear? | Roger Long | Piloting | 7 | February 10th 04 02:41 AM |
