Astir CS ballast weight
Old January 23rd 20, 01:58 AM posted to rec.aviation.soaring
soaringjac
Default Astir CS ballast weight
Does anyone have a photo they can post showing how the ballast weights get installed in the nose of the Astir CS? I just see two holes up there but not exactly sure what’s needed to install weights and how it should be setup
Old January 23rd 20, 03:03 PM posted to rec.aviation.soaring
Waveguru
The weights I've seen and used are pie shaped and mount in front of the seat under your legs. There are two posts there for the weight.
Boggs
Old January 23rd 20, 03:13 PM posted to rec.aviation.soaring
soaringjac
Boggs
I think thats for the different variants of the ship. We have a 102 iiib that the weights mount like you mention, but in the Astir CS we have it mounts in the nose. I assume they mount the same way though. There are just two holes up in the nose, not hardware or bolts or anything so im just trying to confirm how they actually mount up there. I would assume just with a bolt through those holes and through the weights with a nut holding them tight
Old January 23rd 20, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
Are those holes internally threaded?
Also, I looked at the flight manual for the Astir CS and it only talks
about ballast weight in the seat for lighter pilots.
Boggs
Dan, 5J
Old January 23rd 20, 05:08 PM posted to rec.aviation.soaring
soaringjac
It was hard for me to tell if they were threaded or not. I need to have a closer look next time I’m at the glider. I was told that the holes were to add weights. I do not see anything in the manual about adding weights up there, but apparently grob sells them. I guess I’ll try to contact Linder and see what they say
Old January 23rd 20, 06:05 PM posted to rec.aviation.soaring
Juliet11[_2_]
There were several methods used to add weights.
My ASTIR CS has threaded (metric) holes in the nose and the weights are kidney shaped.
Old January 23rd 20, 06:26 PM posted to rec.aviation.soaring
soaringjac
Awesome, thanks for the info!
Old January 23rd 20, 08:44 PM posted to rec.aviation.soaring
soaringjac
Did the bolts go in from the cockpit side or did the go in from where the tow hook is
Old January 24th 20, 07:22 PM posted to rec.aviation.soaring
Juliet11[_2_]
Look up "J11" comp number in the SSA comp numbers and give me a call.
Old January 24th 20, 07:46 PM posted to rec.aviation.soaring
Juliet11[_2_]
Use my cell phone number
DG-505MB weight & ballast Jacopo Romei Soaring 2 February 11th 17 02:58 PM
Empty weight of Grob Astir CS mike maskell Soaring 2 September 29th 10 01:44 PM
Twin Astir water ballast tanks Nick Kennedy Soaring 3 May 27th 08 11:36 PM
Weight and balance, ballast, trim when flying alone Mxsmanic Piloting 158 January 20th 08 10:33 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
