CallAir A9-B muffler
Old July 5th 20, 04:15 AM posted to rec.aviation.soaring
David Cleveland
Default CallAir A9-B muffler
Do any of you tow guys out there know where to find a muffler for a CallAir A9-B?
I'm pretty sure the exhaust system is the same for either engine that came with the A-9B. It's probably the same for the A9-A as well, but I'm not sure. This particular airplane has a Lycoming IO-540-G1C5.
Old July 25th 20, 04:18 PM posted to rec.aviation.soaring
Larry Ruggiero
Look in Trade-a-Plane for exhaust system specialists. If it’s not too bad it can probably be repaired. Is it an actual muffler or a shroud for carb heat and/or cabin heat?
Larry Ruggiero, Pawnee driver, A&P/IA
Old July 25th 20, 08:31 PM posted to rec.aviation.soaring
Bob Youngblood
Call the guys at Plane Exhaust in Ft. Lauderdale, they are the experts, simply the best in the business.
Old July 27th 20, 04:46 AM posted to rec.aviation.soaring
David Cleveland
Thanks guys. It's the muffler, or actually the common exhaust chamber that combines the left and right exhaust manifolds prior to the exhaust pipe. The exit pipe connection to the chamber is rusted through. Completely disconnected. The heat shroud (which no longer has any use) is in bad shape as well, but not unserviceable.
Besides Plane Exhaust, Aerospace Welding Minneapolis has been recommended.
I've seen other modifications done to the exhaust systems of CallAir's. I don't think they were approved.
David
M20E Muffler [email protected] Owning 1 April 14th 08 11:49 PM
Callair A9A [email protected] Soaring 0 December 14th 06 12:32 AM
Where to find a used Mooney muffler? Dico Owning 3 August 15th 06 01:25 PM
Cessna Muffler Shroud RST Engineering Owning 13 May 19th 05 03:30 AM
Rotax 503DC After-Muffler Milcom Instrumentation Rotorcraft 1 September 27th 04 03:46 PM
