The inadvisability of charging LiFePO4 batteries below 32F/0C(aka below freezing)
On Friday, March 23, 2018 at 8:48:40 AM UTC-7, jfitch wrote:
I'll give you a scenario for yours: the cheap Chinese cable clip used in the engine bay to secure the battery cable falls out, letting the positive battery cable fall against the engine. That short circuits the battery when the starter button is pressed, sinking 1000 amps and setting the entire wiring harness on fire, which passes right under your butt and next to the fuel tank. "Houston, we have a problem...." I may have only "mass produced Chinese circuits" to prevent this from happening in my glider, but at least I have something. Not a direct reply, but I took delivery of a brand new glider from Schleicher that had one (out of four) bad LFP battery. All the batteries are fused at the battery with circuit breaker on panel for each instrument. Kept blowing fuses. Schleicher told me they had not heard of a battery going bad, but quickly refunded monies to purchase a new battery. No problems with new battery. I have also had a NiCad runaway on a helicopter (at sunset of course in the mountains). Batteries burn really well. Life is full of risk v reward. Know your risks and reward. |
Can you explain what was "bad" with this battery, and can such a problem develop eventually in a good battery? I'm puzzled what would cause the fuse at the battery to blow when there wasn't a short circuit downstream.
On Friday, March 23, 2018 at 12:56:41 PM UTC-4, Jonathan St. Cloud wrote: Not a direct reply, but I took delivery of a brand new glider from Schleicher that had one (out of four) bad LFP battery. All the batteries are fused at the battery with circuit breaker on panel for each instrument. Kept blowing fuses. Schleicher told me they had not heard of a battery going bad, but quickly refunded monies to purchase a new battery. No problems with new battery. I have also had a NiCad runaway on a helicopter (at sunset of course in the mountains). Batteries burn really well. Life is full of risk v reward. Know your risks and reward. |
I have no idea why is was "bad". I just knew that every time I took glider out of box fuse was melted. We checked the trailer top solar chargers with controllers, they were fine as was solar charger and controller in glider.. One bad one out of bunch, replaced it no further problems.
On Friday, March 23, 2018 at 12:28:46 PM UTC-7, wrote: Can you explain what was "bad" with this battery, and can such a problem develop eventually in a good battery? I'm puzzled what would cause the fuse at the battery to blow when there wasn't a short circuit downstream. On Friday, March 23, 2018 at 12:56:41 PM UTC-4, Jonathan St. Cloud wrote: Not a direct reply, but I took delivery of a brand new glider from Schleicher that had one (out of four) bad LFP battery. All the batteries are fused at the battery with circuit breaker on panel for each instrument. Kept blowing fuses. Schleicher told me they had not heard of a battery going bad, but quickly refunded monies to purchase a new battery. No problems with new battery. I have also had a NiCad runaway on a helicopter (at sunset of course in the mountains). Batteries burn really well. Life is full of risk v reward. Know your risks and reward. |
On 3/23/2018 5:35 PM, Jonathan St. Cloud wrote:
I have no idea why is was "bad". I just knew that every time I took glider out of box fuse was melted. We checked the trailer top solar chargers with controllers, they were fine as was solar charger and controller in glider. One bad one out of bunch, replaced it no further problems. On Friday, March 23, 2018 at 12:28:46 PM UTC-7, wrote: Can you explain what was "bad" with this battery, and can such a problem develop eventually in a good battery? I'm puzzled what would cause the fuse at the battery to blow when there wasn't a short circuit downstream. On Friday, March 23, 2018 at 12:56:41 PM UTC-4, Jonathan St. Cloud wrote: Not a direct reply, but I took delivery of a brand new glider from Schleicher that had one (out of four) bad LFP battery. All the batteries are fused at the battery with circuit breaker on panel for each instrument. Kept blowing fuses. Schleicher told me they had not heard of a battery going bad, but quickly refunded monies to purchase a new battery. No problems with new battery... Snip Since this thread has drifted already... ....on the subject of "explaining battery 'badness'," ~2012 I encountered a wet-cell SLA starter battery in a friend's car; it/she was suffering from 'intermittent/sudden deadness,' in the 'car won't start/suddenly quits running' sense of things. Got lucky while troubleshooting, and noted the battery's voltage suddenly halve (12.6-6.3V as I recall)...to eventually return to 12.6V. Ultimately confirmed it started/ran-fine when DVM-showing 12.6V, and was 'quite silent' when the battery showed 6.3V (big surprise). Since the battery was ~1yr-old from A-zone, I advised her to return it for a new one (and don't take, "But it checks out OK on our tester," as an acceptable - though quite possibly true - return-outcome). Return accomplished; problem hasn't recurred in the years since then. An EE brother said he'd never heard of such a failure (nor had AE-degreed I). If it happens, it must be possible. 'Weird internal shorts,' weird internal opens,' I wouldn't bet agin' either of 'em being possible... Bob W. --- This email has been checked for viruses by AVG. http://www.avg.com |
The point is batteries can burn, explode, catch fire... (even if there has never been a problem before) Keep that in mind if you change batteries and want to take a long flight on unproven batteries. From the MD500 POH, the only event you land immediately (even if over a forest according to factory pilots) is a battery run away (the only red button on the warning panel), I had one of those while flying. Ended up getting stalked by mountain lion. My batteries are double fused and each instrument has a breaker.
On Friday, March 23, 2018 at 5:00:00 PM UTC-7, BobW wrote: On 3/23/2018 5:35 PM, Jonathan St. Cloud wrote: I have no idea why is was "bad". I just knew that every time I took glider out of box fuse was melted. We checked the trailer top solar chargers with controllers, they were fine as was solar charger and controller in glider. One bad one out of bunch, replaced it no further problems. On Friday, March 23, 2018 at 12:28:46 PM UTC-7, wrote: Can you explain what was "bad" with this battery, and can such a problem develop eventually in a good battery? I'm puzzled what would cause the fuse at the battery to blow when there wasn't a short circuit downstream. On Friday, March 23, 2018 at 12:56:41 PM UTC-4, Jonathan St. Cloud wrote: Not a direct reply, but I took delivery of a brand new glider from Schleicher that had one (out of four) bad LFP battery. All the batteries are fused at the battery with circuit breaker on panel for each instrument. Kept blowing fuses. Schleicher told me they had not heard of a battery going bad, but quickly refunded monies to purchase a new battery. No problems with new battery... Snip Since this thread has drifted already... ...on the subject of "explaining battery 'badness'," ~2012 I encountered a wet-cell SLA starter battery in a friend's car; it/she was suffering from 'intermittent/sudden deadness,' in the 'car won't start/suddenly quits running' sense of things. Got lucky while troubleshooting, and noted the battery's voltage suddenly halve (12.6-6.3V as I recall)...to eventually return to 12.6V. Ultimately confirmed it started/ran-fine when DVM-showing 12.6V, and was 'quite silent' when the battery showed 6.3V (big surprise).. Since the battery was ~1yr-old from A-zone, I advised her to return it for a new one (and don't take, "But it checks out OK on our tester," as an acceptable - though quite possibly true - return-outcome). Return accomplished; problem hasn't recurred in the years since then. An EE brother said he'd never heard of such a failure (nor had AE-degreed I). If it happens, it must be possible. 'Weird internal shorts,' weird internal opens,' I wouldn't bet agin' either of 'em being possible... Bob W. --- This email has been checked for viruses by AVG. http://www.avg.com |
On 3/23/2018 6:21 PM, Jonathan St. Cloud wrote: Ended up getting stalked by mountain lion. My batteries are double fused and each instrument has a breaker. Just another reason for always being armed while flying, as was required by state law when I lived in Alaska.Â* And how do you double fuse a battery, a switch to select one or the other? I recall that the Saberliner 40 had the NiCd battery mounted in a lower aft compartment which had the elevator control cables passing through.Â* A battery overheat warning (read thermal runaway) was a no-****, get it on the ground now, situation, or death would soon follow... -- Dan, 5J |
Ended up getting stalked by mountain lion. Note to Tom... please add 'Catamount Evasion' to pre-solo training syllabus. |
Similar Threads | ||||
LifePO4 batteries for motorgliders - are we there yet? | Chris | Soaring | 13 | January 9th 16 03:43 PM |
LiFePO4 Batteries on sale. | [email protected] | Soaring | 20 | December 9th 15 05:34 PM |
K2 vs. StarkPower LiFePo4 batteries | Fox Two[_2_] | Soaring | 36 | April 16th 15 05:14 PM |
LiFePO4 Batteries | vontresc | Soaring | 56 | June 27th 14 07:25 PM |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
