how many pounds thrust needed ?
Old September 14th 03, 04:28 AM
MB
Don't forget the Caproni A-21J/A-21SJ. I believe that was the first Jet
sailplane. They addressed the 'melting the tail" problem by splitting
the exhaust into two vectors, each having a slight angle away from the tail.
It was moderately heavy at the time (early 70's I think), ~1400 lbs, w/
220 lbs of thrust, but climbed well, particularly at altitude. Only a
few (+/-3) still registered.
Mike
Martin Hellman wrote:
Jim Culp wrote in message ...
How many pounds thrust might be needed
to keep a std class glider with std pilot aboard
such as a Std Libelle or Ls4 or Discus
a) continuing in level flight at 60-70 knots
b) climb at rate of 3oo fpm at 60-70 knots
CH gave formulas that work in a later post in this thread, but there's
a simpler (at least to me) way to calculate these numbers.
a) L/D is the ratio of Lift (which equals glider weight) to Drag. So,
if the ship weighs 705 lb and L/D=30 (as in CH's example), then the
drag is 705/30 = 23.5 lb. You have to use the L/D at the speed you are
operating, so drag will increase at higher speeds, where the L/D drops
off.
b) To get the additional, "climb thrust" needed for a given climb
rate, take the true air speed (60 kts), divide by the climb rate (3
kts) to get 20. Then divide the weight of the glider (705 lbs) by 20
to get the additional thrust needed for this climb rate (35.25 lb).
Add this additional, climb thrust to the level drag to get total
required thrust, 58.75 lb. Note that if the desired climb rate equaled
the true air speed, you would need to add 100% of the glider's weight
to the level drag. Which makes sense. A thrust to weight ratio of a
little more than 1 is needed for vertical flight.
It's interesting that nautical units are better than even metric
(km/hr and m/sec) for calculations like this, at least within 1%.
That's because, within 1% (OK, more like 1.01%) a nautical mile is
6000 feet, a number which is evenly divisible by the number of minutes
in an hour. That's why 300 fpm = 3 kts (within 1%).
Hope someone else finds this simpler too.
Martin
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
