#71
"Richard Kaplan" wrote in message s.com... MGW Tower routinely seems to not know where I am located when I call in on the approach. They will sometimes, for example, ask me to "Report DIXIN Inbound" when I am already inside DIXIN; if they saw me on radar they would not ask for such a report. You said pilots are not told "Radar Service Terminated" on the ILS 18 to MGW. If Morgantown does not have radar then pilots should be told that radar service is terminated. The MVA is indeed 3000 MSL in the WAY area. How do you know? So as mentioned in an earlier posting IFR traffic could be at 3000 MSL in the MGW area and thus conflicting with the departure procedure from MGW runway 18. Enroute traffic is typically kept higher for that very reason. One reason why I might execute an approach at MGW to get into WAY would be in the winter if I anticipate possible icing in the descent and I want the option to land at MGW if I accumulate ice vs. continue to WAY if I am ice-free. Full flaps are not permitted on my airplane after I have encountered icing conditions, and I would much prefer to execute such a landing straight-in out of an ILS to the 5000 foot runway at MGW rather than to fly a traffic pattern around WAY and land on its 3500 foot, slightly sloping runway. Another reason why I might execute an approach at MGW to get into WAY is to get a sense of whether I am likely to be able to complete a visual approach to WAY. Circling WAY at 3000 feet I might be able to see straight down to the airport yet forward visibility might be reduced when I start a visual approach to WAY; the only way to get below 3000 feet at WAY is to cancel IFR, so I could find myself IMC on a VFR flight plan below radar and radio reception altitudes. I have found that a better plan is to execute the ILS into MGW and then decide if the weather will allow me to proceed IFR to WAY or if I should instead land at MGW. So executing an instrument approach at MGW has nothing to do with proceeding IFR to WAY then? It's just to get a check on the weather? You fly the approach, miss, and then climb to the MVA and proceed to WAY? |
#72
"Steven P. McNicoll" wrote in message news You said pilots are not told "Radar Service Terminated" on the ILS 18 to MGW. If Morgantown does not have radar then pilots should be told that radar service is terminated. That is a valid point and something which I agree would be helpful for me to clarify.... I will ask Morgantown tower directly next time I get a chance. Either way, it does not get away from the initial topic of discussion which is that an IFR clearance on takeoff from MGW runway 18 should never contain the words "On Takeoff Turn Left ...." The MVA is indeed 3000 MSL in the WAY area. How do you know? I have asked ATC (Clarksburgh Approach) this question many times on IFR flight plans approaching WAY. Enroute traffic is typically kept higher for that very reason. Yes, but for all I know enroute traffic was landing at a nearby airport and thus kept lower or maybe wanted lower to avoid winds or icing or wanted lower by request to stay IMC or had an emergency or any number of reasons. So executing an instrument approach at MGW has nothing to do with proceeding IFR to WAY then? It's just to get a check on the weather? You fly the approach, miss, and then climb to the MVA and proceed to WAY? If the weather is marginal VFR for WAY, say minimum ceiling for a visual approach into WAY with 3 miles visibility, I might well go missed on the ILS to MGW and then continue IFR from MGW to WAY by my preference to help with separation from other aircraft. -- Richard Kaplan, CFII www.flyimc.com |
#73
"Richard Kaplan" wrote in message s.com... That is a valid point and something which I agree would be helpful for me to clarify.... I will ask Morgantown tower directly next time I get a chance. I phoned Morgantown tower, they have no BRITE. Either way, it does not get away from the initial topic of discussion which is that an IFR clearance on takeoff from MGW runway 18 should never contain the words "On Takeoff Turn Left ...." There are many things an IFR clearance should not contain, but without a transcript we do not know what it did contain. I have asked ATC (Clarksburgh Approach) this question many times on IFR flight plans approaching WAY. Okay, but remember this is the same facility that apparently cleared you for an approach when another IFR aircraft would be conflicting with the missed approach segment. Yes, but for all I know enroute traffic was landing at a nearby airport and thus kept lower or maybe wanted lower to avoid winds or icing or wanted lower by request to stay IMC or had an emergency or any number of reasons. Separation is the first priority. You don't grant a request that compromises separation. If the weather is marginal VFR for WAY, say minimum ceiling for a visual approach into WAY with 3 miles visibility, I might well go missed on the ILS to MGW and then continue IFR from MGW to WAY by my preference to help with separation from other aircraft. How do you know what the weather is at WAY? What does an approach at MGW have to do with proceeding IFR to WAY? |
#74
nk.net... How do you know what the weather is at WAY? What does an approach at MGW have to do with proceeding IFR to WAY? WAY is close enough to MGW for me to be able to make a reasonable estimate of whether I can get into WAY based on weather in MGW... it is not perfect but it is a pretty effective plan considering I have done this for years and thus know the local weather patterns very well. Since I am IFR, if I cannot get into WAY then no harm is done -- I could just ask for a clearance back to MGW and land. -- Richard Kaplan, CFII www.flyimc.com |
#75
"Richard Kaplan" wrote in message s.com... WAY is close enough to MGW for me to be able to make a reasonable estimate of whether I can get into WAY based on weather in MGW... it is not perfect but it is a pretty effective plan considering I have done this for years and thus know the local weather patterns very well. Since I am IFR, if I cannot get into WAY then no harm is done -- I could just ask for a clearance back to MGW and land. I don't follow. If you're assuming the weather at WAY is similar to the weather at MGW, then just the need to do an approach at MGW should tell you that an approach is needed at WAY. Since WAY has no approach you won't be able to get in. |
#76
ink.net: I don't follow. If you're assuming the weather at WAY is similar to the weather at MGW, then just the need to do an approach at MGW should tell you that an approach is needed at WAY. Since WAY has no approach you won't be able to get in. He didn't say that the weather is similar. He said "WAY is close enough to MGW for me to be able to make a reasonable estimate of whether I can get into WAY based on weather in MGW..." -- John Godwin Silicon Rallye Inc. |
#77
"John Godwin" wrote in message ... He didn't say that the weather is similar. He said "WAY is close enough to MGW for me to be able to make a reasonable estimate of whether I can get into WAY based on weather in MGW..." What's the difference? |
#78
"Steven P. McNicoll" wrote in news:fD0ab.6502
: What's the difference? In our area, for example, if LVK reports overcast, there's a very good chance that all the airports skirting the SF bay are too. On the otherhand, LVK can report clear and the bay airports may STILL be socked in. There are several microclimates here and locals can gauge one area based on an other but understand that the prevailing weather may not necessarily be similar. -- John Godwin Silicon Rallye Inc. |
#79
"John Godwin" wrote in message ... In our area, for example, if LVK reports overcast, there's a very good chance that all the airports skirting the SF bay are too. On the otherhand, LVK can report clear and the bay airports may STILL be socked in. There are several microclimates here and locals can gauge one area based on an other but understand that the prevailing weather may not necessarily be similar. That's all very interesting, but what's the difference between assuming the weather at WAY is similar to the weather at MGW, and saying "WAY is close enough to MGW for me to be able to make a reasonable estimate of whether I can get into WAY based on weather in MGW..."? |
#80
"Steven P. McNicoll" wrote in message ink.net... I don't follow. If you're assuming the weather at WAY is similar to the weather at MGW, then just the need to do an approach at MGW should tell you that an approach is needed at WAY. Since WAY has no approach you won't be able to get in. There are 2 possible situations where it makes sense to do the approach to MGW and then go IFR to WAY: (1) If I need to descend through an icing layer or potential icing layer to get down to VFR conditions, I would rather do that descent to the longer, ILS-equipped runway at MGW than to WAY. If I get any icing on the descent, I will land at MGW. If I get no icing on descent, I will proceed to WAY, but if visibility is margainal (say 3 miles) I would prefer to proceed IFR to WAY. (2) If reported weather is such that I do not think I will get into WAY (say 1500-2) but I break out at MGW and realize the weather is better than expected (say 2500-3 in light rain), I would give it a try at WAY but I would still want to proceed IFR from MGW to WAY if visibility is legal but marginal for VFR. -- Richard Kaplan, CFII www.flyimc.com |
Similar Threads | ||||
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
MN Airport Closure Notification Legislation (S.F. 2178/H.F. 2737) | Dan Hoehn | General Aviation | 1 | May 25th 04 01:52 PM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! | Bill Mulcahy | General Aviation | 3 | October 1st 03 05:39 AM |
