Strictly speaking, the change of wiring is a change to the type
certificate. You could deem it a minor modification and do it with a log book entry. You would be ok unless somewhere down the line someone wanted to debate the point. Then the $115 would look pretty cheap. Bill Hale |
"John Kunkel" wrote: "Mike Noel" wrote in message ... My service manual (page 4D1) states that the #1 aluminum wire can be replaced by #3 copper by following procedures in 43-13. No STC or kit needed, just get some wire and terminals and do it by the book. You *can* change the wiring per the SB836, but because the approved data is the SB and maintenance manual, but may *only* use the materials specified in the SB or maintenance manual. Go ahead and try to find exactly the specified wire and particular terminal numbers. Some of them are next to impossible to find, especially in qty 1 each. The Bogert cables are pricey. American Aviation has an STC kit that is about $130, which went on my Cherokee over the winter while my engine was being overhauled. You could barely buy the wire and terminals for that much. #2 aircraft cable is expensive and you need a lot of it for a PA28 with a rear mounted battery. |
Similar Threads | ||||
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
Wire for homebuilts. | clare @ snyder.on .ca | Home Built | 9 | March 25th 04 05:51 PM |
New Piper Aircraft Designations | EDR | Piloting | 8 | October 27th 03 01:18 PM |
replacement rotating beacon for 64 piper cherokee | Patrick Mathews | Owning | 2 | October 1st 03 01:55 PM |
The Piper Cubs That Weren't | Veeduber | Home Built | 5 | August 28th 03 04:38 AM |
