#51
Use of weak links
On Mon, 07 Jun 2010 13:54:50 +0200, Andreas Maurer wrote:
On Mon, 07 Jun 2010 05:20:48 -0500, brian whatcott wrote: Brian wrote: On Jun 6, 5:54 pm, John Smith wrote: Brian wrote: True the 90deg AOA was justa theoritical way to look at the loads on a stalled wing. As soon as the wing stalls, the load decreases. Yes it decreases, but there is some load on it still. Even a stalled wings produces some lift just not nearly as much as a flying wing. Brian C. How about drag? Forget the drag - you cannot go fast enough with 90 degrees AoA to produce any significant amount of drag. There's another point that hasn't been mentioned - many winches can't pull in cable at anything like Vwinch for most gliders, e.g. most single seaters have a Vwinch of 65kts or higher but I'm told our Supacat's maximum cable speed is 55 kts. This doesn't mean that it can't break gliders: try this thought experiment. Launch without a weak link, wait until the glider is at 60-70 degrees from the winch and ramp the winch up to full power to cause a gross overspeed. This is the situation that will put maximum load on the wings and it is the situation where the weak link is designed to fail. At least one of these things is very likely to happen: (1) the pilot pulls the bung (2) a back release, if the glider gets far enough overhead of the winch (3) the hook gets pulled out of the glider (4) the wings break (5) the cable snaps arranged in increasing severity and (my guess) decreasing probability since I think that one of the less severe events will happen before the more severe ones. Some time back during a rainstorm our then CFI gave a talk about how the various airframe limits are set. I remember him saying that Vwinch is 95% of the speed at which the wing's maximum design loading is reached when the glider is overhead the winch with the stick fully back. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#52
Use of weak links
On Jun 7, 3:41*pm, Martin Gregorie
wrote: On Mon, 07 Jun 2010 13:54:50 +0200, Andreas Maurer wrote: On Mon, 07 Jun 2010 05:20:48 -0500, brian whatcott wrote: Brian wrote: On Jun 6, 5:54 pm, John Smith wrote: Brian wrote: True the 90deg AOA *was justa theoritical way to look at the loads on a stalled wing. As soon as the wing stalls, the load decreases. Yes it decreases, but there is some load on it still. Even a stalled wings produces some lift just not nearly as much as a flying wing. Brian C. How about drag? Forget the drag - you cannot go fast enough with 90 degrees AoA to produce any significant amount of drag. There's another point that hasn't been mentioned - many winches can't pull in cable at anything like Vwinch for most gliders, e.g. most single seaters have a Vwinch of 65kts or higher but I'm told our Supacat's maximum cable speed is 55 kts. This doesn't mean that it can't break gliders: try this thought experiment. Launch without a weak link, wait until the glider is at 60-70 degrees from the winch and ramp the winch up to full power to cause a gross overspeed. This is the situation that will put maximum load on the wings and it is the situation where the weak link is designed to fail. At least one of these things is very likely to happen: (1) the pilot pulls the bung (2) a back release, if the glider gets far enough overhead of the winch (3) the hook gets pulled out of the glider (4) the wings break (5) the cable snaps arranged in increasing severity and (my guess) decreasing probability since I think that one of the less severe events will happen before the more severe ones. snip Think I'd place cable snaps at #3, hook gets pulled out at #4 and wings break at #5 on the grounds that we practise cable breaks, the hook pulling out shouldn't affect *this* flight and wings breaking certainly will. |
#53
Use of weak links
On Mon, 07 Jun 2010 08:42:16 -0700, Cats wrote:
On Jun 7, 3:41Â*pm, Martin Gregorie wrote: On Mon, 07 Jun 2010 13:54:50 +0200, Andreas Maurer wrote: On Mon, 07 Jun 2010 05:20:48 -0500, brian whatcott wrote: Brian wrote: On Jun 6, 5:54 pm, John Smith wrote: Brian wrote: True the 90deg AOA Â*was justa theoritical way to look at the loads on a stalled wing. As soon as the wing stalls, the load decreases. Yes it decreases, but there is some load on it still. Even a stalled wings produces some lift just not nearly as much as a flying wing. Brian C. How about drag? Forget the drag - you cannot go fast enough with 90 degrees AoA to produce any significant amount of drag. There's another point that hasn't been mentioned - many winches can't pull in cable at anything like Vwinch for most gliders, e.g. most single seaters have a Vwinch of 65kts or higher but I'm told our Supacat's maximum cable speed is 55 kts. This doesn't mean that it can't break gliders: try this thought experiment. Launch without a weak link, wait until the glider is at 60-70 degrees from the winch and ramp the winch up to full power to cause a gross overspeed. This is the situation that will put maximum load on the wings and it is the situation where the weak link is designed to fail. At least one of these things is very likely to happen: (1) the pilot pulls the bung (2) a back release, if the glider gets far enough overhead of the winch (3) the hook gets pulled out of the glider (4) the wings break (5) the cable snaps arranged in increasing severity and (my guess) decreasing probability since I think that one of the less severe events will happen before the more severe ones. snip Think I'd place cable snaps at #3, hook gets pulled out at #4 and wings break at #5 on the grounds that we practise cable breaks, the hook pulling out shouldn't affect *this* flight and wings breaking certainly will. I was being pessimistic and assuming a new 3/16" steel cable is being used and made a guestimate that a new cable is stronger than a set of used glider wings. I'd certainly expect the hook to pull out before the spars snapped. I've taken my hook out for a thorough clean-up and have a pretty good idea of what its bolted to! I'm also assuming that a less severe event occurrence will reduce the load and prevent the more severe events from happening. e.g. pulling the hook out will prevent the spar or cable from breaking. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#54
Use of weak links
On Jun 4, 2:27*pm, Andreas Maurer wrote:
On Thu, 03 Jun 2010 19:43:46 -0500, brian whatcott wrote: Specifically what I am saying is that unless you are exceeding the Maximum Winch Launch speed of the glider it should be impossible to overstress the wings as the wing will stall before exceeding maximum structural load of the aircraft. Brian This is a perfectly sound argument in many phases of flight. *But a *tow capable of exerting enough force on a stalled structure will certainly break it. A winch need not relax when a wing stalls.... Visualize an airframe being hauled along at an AoA of 90 degrees, to exaggerate this point... This won't break the wing spars either. As long as the IAS is below VA (in other words: in the green range of the airspeed indicator), no control input at all can damage the glider - the definition of VA is that this is the speed under which a high speed stall will prevent exceeding the maximum g-load. So, as long as you are slower than VA, you are safe. (Of course - combined control inputs can indeed break the structure even below VA, usually by torsional load on the tail boom by a deflected rudder at speeds close to VA combined with significant yaw angle.) The problem of exceeding the Maximum Winch Launch speed is not the wing, but the attachment of the tow hook to the fuselage structure. Pretty hard to explain why you landed with the belly hook missing... Cheers Andreas Bye Andreas Hi Andreas, I thought you would know better that that! Gliders have a lower maximum winch launching speed than Va called Vw. This is because the pull is applied as a point load in the centre of the fuselage and, unlike in the manoeuvring case, there is no g unloading. Essentially the cable is pulling the fuselage down while the wings are providing large amounts of upward lift, which puts a large bending moment on the mainspar. This is fairly obvious if you watch a floppy winged glider being winch launched, when the wings bend quite alarmingly, especially near the top of the launch when the forces are most opposed. The recommended weak link is set by by the designer so that it fails well before the mainspar does. It is possible that other bits of structure such as the hook mounting will fail first. The only cases where I have known this happen were to old wooden gliders where the wood has become slightly rotten in the hook area. Essentially the weak link acts as a fuse that breaks before the glider does. Generally to damage a glider you would have to hit a sharp-edged gust while pulling back hard against a powerful winch, near the top of the launch, with an overstrength weak link, and exceeding VW, all at the same time. Derek Copeland |
#55
Use of weak links
Some time back during a rainstorm our then CFI gave a talk about how the various airframe limits are set. I remember him saying that Vwinch is 95% of the speed at which the wing's maximum design loading is reached when the glider is overhead the winch with the stick fully back. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Your CFI may have said that but there's no engineering data or certification specifications to back it up. There's no chance of overstressing an airworthy glider on a winch launch when using the correct weak link. |
#56
Use of weak links
On Mon, 07 Jun 2010 12:21:31 -0700, bildan wrote:
Some time back during a rainstorm our then CFI gave a talk about how the various airframe limits are set. I remember him saying that Vwinch is 95% of the speed at which the wing's maximum design loading is reached when the glider is overhead the winch with the stick fully back. -- martin@ Â* | Martin Gregorie gregorie. | Essex, UK org Â* Â* Â* | Your CFI may have said that but there's no engineering data or certification specifications to back it up. He was talking us through JAR 22 at the time and JAR 22.583 looks pretty prescriptive to me. There's no chance of overstressing an airworthy glider on a winch launch when using the correct weak link. Maybe so but note that JAR 22.583 defines the max weak link strength as the *lesser* of 83% of structural damage limit or max achievable lift with full up elevator and JAR 22.585 says the hook must withstand the larger of 125% of the weak link breaking load and the glider's MTOW. I agree that 22.583 and 22.585 taken together guarantee no damage if the right weak link is used, but I'd remind you that this discussion was triggered by a question about a club that was winching with NO weak link. JAR 22.583 has no guarantee against overstressing the glider under those conditions because it specifically says that its OK to design a glider for a weak link that breaks at a lower load than the wing can generate with full up elevator. Unless there's a clause somewhere else in JAR 22 that would prevent it, this implies that a compliant glider can be broken by pulling the stick back during an overspeed if it is winched on an incorrect weak link. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#57
Use of weak links
John Smith wrote:
Andreas Maurer wrote: Forget the drag - you cannot go fast enough with 90 degrees AoA to produce any significant amount of drag. I'd rather say that with a 90° AoA you have *only* drag. Quite. Cd reaches its peak (around 2) at 90 deg AoA, a notably bell shaped curve 0 - 180 deg AoA Cl peaks around 15, drops then rises again to peak around 45 deg AoA falling to zero round 90 AoA according to some NASA trials of several representative airfoils. It was written of several WWI incidents, that a falling leaf full stall could sometimes be walked away from. In those machines, going fast was not a prerequisite. Brian W |
#58
Use of weak links
On Mon, 07 Jun 2010 20:55:46 +0000, Martin Gregorie wrote:
On Mon, 07 Jun 2010 12:21:31 -0700, bildan wrote: Some time back during a rainstorm our then CFI gave a talk about how the various airframe limits are set. I remember him saying that Vwinch is 95% of the speed at which the wing's maximum design loading is reached when the glider is overhead the winch with the stick fully back. -- martin@ Â* | Martin Gregorie gregorie. | Essex, UK org Â* Â* Â* | Your CFI may have said that but there's no engineering data or certification specifications to back it up. He was talking us through JAR 22 at the time and JAR 22.583 looks pretty prescriptive to me. There's no chance of overstressing an airworthy glider on a winch launch when using the correct weak link. Maybe so but note that JAR 22.583 defines the max weak link strength as the *lesser* of 83% of structural damage limit or max achievable lift with full up elevator and JAR 22.585 says the hook must withstand the larger of 125% of the weak link breaking load and the glider's MTOW. I agree that 22.583 and 22.585 taken together guarantee no damage if the right weak link is used, but I'd remind you that this discussion was triggered by a question about a club that was winching with NO weak link. JAR 22.583 has no guarantee against overstressing the glider under those conditions because it specifically says that its OK to design a glider for a weak link that breaks at a lower load than the wing can generate with full up elevator. Unless there's a clause somewhere else in JAR 22 that would prevent it, this implies that a compliant glider ^^^^^^^^^^^^^^^^^^ can be broken by pulling the stick back during an overspeed if it is ^^^^^^ winched on an incorrect weak link. This should read "it is possible for some compliant gliders to be". -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#59
Use of weak links
/snip/ I was being pessimistic and assuming a new 3/16" steel cable is being used and made a guestimate that a new cable is stronger than a set of used glider wings. I'd certainly expect the hook to pull out before the spars snapped. I've taken my hook out for a thorough clean-up and have a pretty good idea of what its bolted to! I'm also assuming that a less severe event occurrence will reduce the load and prevent the more severe events from happening. e.g. pulling the hook out will prevent the spar or cable from breaking. Strength, according to this supplier: Long URL: http://www.ematerialhandling.com/mat...teel_cable.htm TinyURL format: http://tinyurl.com/6ztmkh 3/16 diam. stainless cable Construction: 1X19 Material: 304 316 Weight/1000ft 72 lb wkg load limit 940 lb 854 breaking load 4700 lb 4270 Construction: 7X7 Weight/1000ft 62 lb wkg 740 670 brk 3700 3350 Construction: 7X19 Wt/1000ft 65 lb wkg 740 642 brk 3700 3210 (I believe galvanized is usually a little stronger?) Supposing that sailplanes are designed to meet 6g limit loads, the most flexible 316 stainless 7X19 cable would break when transmitting a 6g load to an airframe capable of reacting over 535 lb at 1g (6 X 535 = 3215 lb) Brian W |
#60
Use of weak links
On Jun 7, 5:32*pm, Martin Gregorie
wrote: On Mon, 07 Jun 2010 20:55:46 +0000, Martin Gregorie wrote: On Mon, 07 Jun 2010 12:21:31 -0700, bildan wrote: Some time back during a rainstorm our then CFI gave a talk about how the various airframe limits are set. I remember him saying that Vwinch is 95% of the speed at which the wing's maximum design loading is reached when the glider is overhead the winch with the stick fully back. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Your CFI may have said that but there's no engineering data or certification specifications to back it up. He was talking us through JAR 22 at the time and JAR 22.583 looks pretty prescriptive to me. There's no chance of overstressing an airworthy glider on a winch launch when using the correct weak link. Maybe so but note that JAR 22.583 defines the max weak link strength as the *lesser* of 83% of structural damage limit or max achievable lift with full up elevator and JAR 22.585 says the hook must withstand the larger of 125% of the weak link breaking load and the glider's MTOW. I agree that 22.583 and 22.585 taken together guarantee no damage if the right weak link is used, but I'd remind you that this discussion was triggered by a question about a club that was winching with NO weak link. JAR 22.583 has no guarantee against overstressing the glider under those conditions because it specifically says that its OK to design a glider for a weak link that breaks at a lower load than the wing can generate with full up elevator. Unless there's a clause somewhere else in JAR 22 that would prevent it, this implies that a compliant glider * * * * * * * * * * * * * * * * * * * * * * * * * * *^^^^^^^^^^^^^^^^^^ can be broken by pulling the stick back during an overspeed if it is * ^^^^^^ winched on an incorrect weak link. This should read "it is possible for some compliant gliders to be". -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * |- Hide quoted text - - Show quoted text - Right, the point, if I'm not mistaken, is to USE A WEAK LINK (of the correct breaking strength). |
Similar Threads | ||||
Weak link - single or reserve? | Tom Nau | Soaring | 20 | January 19th 08 07:34 PM |
Are Weak Links really Necessary for Aero Tow? | [email protected] | Soaring | 41 | September 19th 06 06:49 PM |
Garmin 430, weak Loc/VOR | Greg Esres | Instrument Flight Rules | 8 | January 24th 05 05:49 PM |
Weak link for PW-5 | Nyal Williams | Soaring | 4 | June 1st 04 08:46 AM |
American soldiers are weak... | Gordon | Military Aviation | 0 | July 17th 03 07:55 PM |
