#141
Flarm in the US
On 8/10/2010 9:58 PM, Alan wrote:
A reasonable point. There is a lot of little used space to fly in. As someone who started as a power pilot, I still find it hard to imagine how one would be willing to fly in such close proximity to other aircraft that you cannot continuously see. "Cessna 123, traffic at your 3 o'clock, one mile, same direction" gets my attention. "glider 45, traffic at your 6 to 7 o'clock, 50 yards behind, 100 feet above, circling in same direction" sounds terrifying. (I am in a blind spot for him, and he is in one for me.) I worry enough about a plane a mile away in a traffic pattern. Not having continuous visual separation at 50 yards distance scares me. Your concern is understandable, given your background, but the lack of a motor makes circling together more predictable than attempting the same thing with powered aircraft. Glider sink rates aren't very different when circling, even between a high performance glider and a club trainer, maybe 50 feet/minute. So, for each circle completed, the altitude difference has changed only 25 feet (typical circles take 20 to 35 seconds). Also, because they are going around the circle at about the same rate, the horizontal distance also changes slowly. That's what makes it work: the changes in relative position are slow, because the horizontal distances and vertical distances are changing slowly. Another factor is visibility out of a glider cockpit: it's large bubble canopy makes it far easier to see the other gliders than the typical airplane cockpit allows. A very important factor is most glider pilots have training and experience in circling together, often starting before they have even soloed, which is not the case for airplane pilots. Still, it is riskier than flying alone, but I don't mind doing it with pilots I know and trust (which is most of them), and I sometimes leave the gaggle when proper separation is too hard to maintain. I don't think the proprietary flarm system is the answer (being a fan of open standards). Where's the problem? It works well, it's available relatively cheaply, it's been available for years overseas, there are several licensed manufacturers, and now it's coming the USA. I'd say the proprietary nature is what makes all these things possible, as it guarantees all the units will work with each other. I would much prefer spending my time where the only other traffic is likely to be a bird, and enjoying the view. I enjoy that very much, but it is also great fun to sometimes fly with other pilots. And, a good way to learn more about soaring well, too. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
#142
Flarm in the US
On Wed, 11 Aug 2010 04:58:03 +0000, Alan wrote:
"glider 45, traffic at your 6 to 7 o'clock, 50 yards behind, 100 feet above, circling in same direction" sounds terrifying. (I am in a blind spot for him, and he is in one for me.) I worry enough about a plane a mile away in a traffic pattern. Not having continuous visual separation at 50 yards distance scares me. Me too. In my UK club we're trained to stay on the opposite side of the circle to a glider at a similar height. I don't do that to anybody. If I'm in a thermal with somebody who insists on sitting on my tail, typically a newly solo pilot, despite my best efforts to stay opposite him, I leave. I can't see FLARM having any bearing on this situation. If your club instructors don't teach correct thermalling etiquette and/or chew more experienced offenders who should know better, its time they start doing it. Martin -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#143
Flarm in the US
On Thu, 12 Aug 2010 12:33:04 +0000, Martin Gregorie wrote:
In my UK club we're trained to stay on the opposite side of the circle to a glider at a similar height. I don't do that to anybody. If I'm in a thermal with somebody who insists on sitting on my tail, typically a newly solo pilot, despite my best efforts to stay opposite him, I leave. That should, of course, read: "In my UK club we're trained to stay on the opposite side of the circle to a glider at a similar height. I consciously try to do that at all times, including when joining. If I'm in a thermal with somebody who insists on sitting on my tail despite my best efforts to stay opposite him, I leave." -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#144
Flarm in the US
On Aug 12, 5:21*am, Eric Greenwell wrote:
snip Did you turn off the power, or just press the "mute" button? snip I hope he pressed the mute button. If he turns the power off them it has to relocate the satellites and so on when he turns it back on again. If I turn the power off to mine I get a break in my IGC trace. |
#145
Flarm in the US
On Aug 12, 6:03*am, Cats wrote:
I hope he pressed the mute button. *If he turns the power off them it has to relocate the satellites and so on when he turns it back on again. *If I turn the power off to mine I get a break in my IGC trace. I think you must be talking about FLARM but the mute/off discussion related to ZAON PCAS. I hit mute on mine (ZAON MRX) in the situation described and the display does still have some value but not a lot. I generally only look at the display after an audio alert. There is enough to look at outside in a busy thermal. This is why target specific muting is so important if PowerFLARM is to be any better than the MRX for transponder based alerting. As I have posted previously, ZAON responded that they do not have enough processor power to implement this feature in the MRX. Andy |
#146
Flarm in the US
On Aug 11, 3:58*pm, Westbender wrote:
I would think it can still calculate whether a target is converging or not (range/altitude differential). Wouldn't it need multiple xpndr replies identifying the same target? I would guess such a thing would be pretty difficult in a gaggle though. I have sent an email inquiring about just how the different sources are dealt with in terms of predicting threats. Hopefully they'll respond. Here is their response to my email: Hi Dave, thanks for your message. 1) yes. Motion predictions are made of all data. 2) We do show relative positions of ADS-B 1090 traffic, however no directions are given for Mode-C/S traffic. Warnings are displayed as a ring, see the attached picture. I hope my answers help, if you have any questions left please tell me. Kind regards Marc Butterfly Support |
#147
Flarm in the US
....and a followup:
Hello Dave, yes, on the warning side there will be an option to disable all alarms or alarms from a specific source for a specified timeframe. This will be accomplished through double-clicking the rotary knob - very easy to do in-flight. One further info: Mode-C/S warnings are only given if there is specific threat. Mode-C/S targets will not clutter up the radar screen. Kind regards Marc |
#148
Flarm in the US
I'm waiting for one more response regarding flarm frequency and
approval status in the US. |
#149
Flarm in the US
It may make sense for contest gliders, and those operating in high
glider traffic areas (Whites, Ridges) to get Flarm, recreational gliders operating in low glider but high power traffic airspace to get transponders and Pcas, and lucky guys out in the middle of nowhere to simply open eyeballs. John Cochrane John raises an issue that surfaced at a PowerFLARM presentation Dave Nadler gave at the Hobbs Std. Class Nats this year (we had lots of time for non-flying activities there). Darryl Ramm has also discussed this. What's the best combination of hardware for a given pilot? I cringe when I hear people say (from a different thread): "There is no defensible rationale for failing to require everyone flying contests to be equipped with an operating FLARM device. It contributes more to safety than all the other pieces combined." That's very broad and overly simplistic. Whether to buy any type of radar/radio tracking/collision alert hardware depends on, among other things: 1. The nature of the threat(s) and the probability thereof. At most US national contests, the biggest threat is other gliders. At a Caesar Creek contest squeezed up between the Cincinnati Class B and Columbus and Dayton Class C's, however, it's not so clear. Factors include geography--including proximity to high-traffic areas; ridge vs. thermal vs. wave; contest vs. XC vs. local; military vs. biz jet vs. airliner vs. general aviation traffic nearby, number of hours/flights annually, etc. Probability factors include traffic density, typical visibility, altitude bands, etc. 2. Pilot skill/awareness: how well does he/she search for and maintain awareness of potential threats as well as how careful/predictable is he/she in thermals and the entry to and exit from. 3. Existing hardwa if a pilot already has a transponder and/or a PCAS (the "no brainer" purchases we were encouraged to make the last few years), buying another device means not only increasing an already considerable investment but either finding more panel space or electrical power or making a swap. If a PowerFLARM performs the PCAS function, the situation is simpler but not automatic. 4. Perception of the longevity of any potential purchase. I love it when someone encourages me to buy a Mode C transponder now because by the end of its useful life, ADS-B will be here in a big way. I'm still flying with the LNAV that has served me well for the past 18 years. I'm not sure what its useful life will be. Factors include technology, regulations, implementation of proposed systems, etc. And product offerings. FLARM was a non-issue 12 months ago in the US. Now it should be mandatory? Please. 5. Finally, a pilot's risk profile: let's acknowledge that some are willing to accept more risk than others (even when risk affects other pilots and passengers). Or they are unwilling to pay as much as others to reduce or eliminate certain risks. And risk can be defined different ways: exposure per flight or flight hour; exposure per flying year; etc. I don't react well when regulators--whether the US government or the US Rules Committee--mandate new equipment purchases. With all due respect, contest pilots were forced to purchase two 35mm clock cameras back in the early 90s, the clock feature of which cost an inordinate premium over conventional cameras at the time and which was never used at any contests I attended. A few years later, we were then compelled to buy GPS loggers, partly on the basis that prices would drop rapidly. The same governing body doubled down on that mandate recently by eliminating the use of cheap, off-the-shelf GPS receivers for contest logging backup although they've left the door open a bit. No regulatory body, however well intentioned (and I believe our Rules Committee guys are very much so), can predict with any accuracy the direction that technology, regulations, or competition will take. What CAN be predicted is that soaring will continue to decline, in part, because of its costs. Contest flying is not immune to this. It follows that anything that increases cost will have a small but undeniable impact, whether on soaring in general or on competition soaring in particular. Logic it out all you want but the demand for soaring is not inelastic. The only differences among soaring pilots in this regard are their own individual cost/demand curves. One person's "$1600 is a small amount to pay for increased safety" is another person's "I just can't afford to put any more money into soaring." It's true that midair collisions impact soaring's popularity and even continued viability if an airliner were to be involved. But Uvalde was notable this year for several reasons. The first, of course, is the tragic midair. The second is the remarkably low number of gliders in attendance at the US's best weather site. Don't think that cost isn't a factor, even for the competition pilots who are thought (not always accurately) to be most able and willing to afford new gadgets. Safety is a goal that's very difficult to argue against. After all, who wants less safety? On the other hand, if money were no object, we could make our sport safer by mandating ballistic recovery chutes, cockpit exit assistance devices, and more compressible fuselage sections; by eliminating water ballast; by requiring crash helmets in the cockpit and the redesign work for all gliders that would entail; and so forth. If PowerFLARM is the clear, economical answer to most of a soaring pilot's anti-collision problems AND collisions are deemed to be a serious risk, then pilots will buy them in droves. Then the Rules Committee can come in behind the trend and put their stamp of approval on it with a new Rule, like the architects of that apolcryphal college campus who initially allowed students to wear down their own paths in the grass among the buildings, then came around a year later and paved over what proved to be the most popular ones. What I'd like to see is a matrix or decision tree or expert system type of diagram that walks me through the purchase decision process by answering the questions I raised above. So if my biggest threat is other gliders in contests and fast bizjet and airliner traffic near NYC where I fly, and if I'm concerned that I should be more diligent at watching for traffic, and if I have no current anti-collision hardware, and if I'm not willing to buy something unless I know it will be useful for at least 5 years (preferably longer), and if I'm on a budget and don't want to or can't drop several thousand bucks into new avionics, then I should buy X because that's the sweet spot in my cost/benefit curve. Chip Bearden ASW 24 "JB" USA |
#150
Flarm in the US
On Aug 12, 4:48*pm, Dave Hoppe wrote:
I'm waiting for one more response regarding flarm frequency and approval status in the US. And here it is: Dave, no problems, I'm very glad to help you! It is a free frequency (SRD). In Europe we use 868Mhz, in the US it will be 433Mhz. PowerFLARM automatically chooses the right frequency for the place you are at - this means you can also use yours in europe e.g. on competitions without having to change settings. FCC approval is on its way and is going to be done before first units start shipping. Cheers Marc |
Similar Threads | ||||
IGC FLARM DLL | [email protected] | Soaring | 1 | March 25th 08 11:27 AM |
WinPilot ADV & PRO 9.0b Flarm | Richard[_1_] | Soaring | 15 | February 6th 08 09:49 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Flarm | Mal | Soaring | 4 | October 19th 05 08:44 AM |
FLARM | John Galloway | Soaring | 9 | November 27th 04 07:16 AM |
