Oudie / EW Microrecorder
Old February 28th 12, 01:00 PM posted to rec.aviation.soaring
Cats
Default Oudie / EW Microrecorder
Can the Oudie declare direct to the EW? I know SoaringPilot can!
Old February 28th 12, 04:35 PM posted to rec.aviation.soaring
Max Kellermann
Yes, if you run XCSoar on your Oudie.
Old February 28th 12, 04:42 PM posted to rec.aviation.soaring
Tony[_5_]
On Feb 28, 10:35*am, Max Kellermann wrote:
Cats wrote:
Can the Oudie declare direct to the EW? *I know SoaringPilot can!
or just use the Oudie out of the box running SeeYou Mobile and you can
(or at least my club-mate can) send declarations to the EW as well.
No computer hacking skills, or nunchuck skills, required.
Old February 28th 12, 04:59 PM posted to rec.aviation.soaring
Paul Remde
"Cats" wrote in message
Yes. In SeeYou Mobile you go to the Task Edit screen and hit the "Upload"
button. It is very simple and works great. I have tested it myself.
However, I should warn you that you should NOT connect the Oudie's
power/data cable directly to the EW microRecorder. The RJ45 connector on
the Oudie's power/data cable's RJ45 connector is wired for connection to an
"IGC Standard" devices like Volksloggers and FLARM units. I have received a
few e-mails from frustrated customers that made the bad assumption that
since the connector fit in the hole, it should work. They damaged their EW
microRecorders. An adapter cable should be used.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old February 28th 12, 05:12 PM posted to rec.aviation.soaring
Cats
Yes. *In SeeYou Mobile you go to the Task Edit screen and hit the "Upload"
button. *It is very simple and works great. *I have tested it myself.
power/data cable directly to the EW microRecorder. *The RJ45 connector on
the Oudie's power/data cable's RJ45 connector *is wired for connection to an
"IGC Standard" devices like Volksloggers and FLARM units. *I have received a
since the connector fit in the hole, it should work. *They damaged their EW
microRecorders. *An adapter cable should be used.
Thanks for the confirmation (I couldn't find mention of it in the
documentation), and yes, I am aware that the MicroRecorder doesn't use
the IGC standard pin-out for an RJ45. I have no idea why not - if it
predates the standard or the designer thought two different pin-outs
on the same plug was a good idea...
Ew Microrecorder help Cliff Hilty[_2_] Soaring 2 November 23rd 11 09:43 PM
EW Microrecorder for sale (USA) Mike the Strike Soaring 1 March 5th 11 01:52 AM
For Sale: EW MicroRecorder $500 noel.wade Soaring 1 February 24th 10 07:14 PM
EW microRecorder and ERIXX --=JJay=--[_2_] Soaring 8 June 12th 09 01:00 PM
microTracker/microRecorder Bob Soaring 15 May 11th 06 01:50 PM
