#11
1-26 1000km attempt
I thought it was just Ron wishing he'd flown the ASW20.
Jim |
1-26 1000km attempt
On Thursday, April 24, 2014 10:00:19 PM UTC-5, JS wrote:
I thought it was just Ron wishing he'd flown the ASW20. Jim Or subliminal (ASW27) messaging (ASG29) of some sort. Steve |
1-26 1000km attempt
On Thursday, April 24, 2014 3:42:48 PM UTC-4, Vernon Brown wrote:
On these discussion groups and R.A.S in particular I keep seeing "=20" Can some please explain the meaning? I wondered the same thing so I Googled it and found the answer. =20 is code for a normal space and =A0 is code for a space between words where the line can't break (a non-breaking space). For an example of the use of the latter, if I was to type something like "read this help article: https://productforums.google.com/d/topic/gmail/WCklpQTrJMk/discussion", the Forum editor puts a non-breaking space in place of the normal space after the ":". You can check the effect by changing the width of the window where you are reading this to try and make the word "article:" sit at the end of a line - it will instead wrap on to the next line along with the URL. |
1-26 1000km attempt
Thanks to all who contributed with the explanation of =20
Tried to send this message earlier today, but for some reason it did not appear Vernon At 16:43 25 April 2014, Soartech wrote: On Thursday, April 24, 2014 3:42:48 PM UTC-4, Vernon Brown wrote: On these discussion groups and R.A.S in particular I keep seeing "=3D20" =20 Can some please explain the meaning? =20 I wondered the same thing so I Googled it and found the answer. =3D20 is code for a normal space and =3DA0 is code for a space between word= s where the line can't break (a non-breaking space). For an example of th= e use of the latter, if I was to type something like "read this help articl= e: https://productforums.google.com/d/topic/gmail/WCklpQTrJMk/discussion", = the Forum editor puts a non-breaking space in place of the normal space aft= er the ":". You can check the effect by changing the width of the window w= here you are reading this to try and make the word "article:" sit at the en= d of a line - it will instead wrap on to the next line along with the URL. |
Similar Threads | ||||
1000km in a 1-26 | Tony[_5_] | Soaring | 8 | June 29th 12 03:04 PM |
Check out Ron Tabery's 1000km | WR | Soaring | 3 | August 12th 09 02:41 AM |
1000km Soaring Weather coming to NV CA SW U.S. - Fri-Sun 06/23-25 | WaltWX | Soaring | 16 | June 29th 06 09:04 AM |
1000KM + Soaring conditions - SPECTACULAR - Fri-Mon 06/23 - 26 | WaltWX | Soaring | 1 | June 22nd 06 11:14 PM |
Narromine FAI 750 Km and 1000KM in Australia | Mal | Soaring | 1 | November 2nd 04 04:08 AM |
