Too many accidents
Old September 11th 18, 04:00 PM posted to rec.aviation.soaring
Dan Marotta
Default Too many accidents
On 9/11/2018 1:15 AM, Ian wrote:
Anecdotally, I notice that quite a few of these accidents involve 2
seaters. Maybe when there are two, experienced, pilots on board, the
dynamics change - both waiting for each other to take control and
recover when things go wrong?
Not an accident, but...
I was once in the back of my friend's two seater and we had been in a
straight line cruise towards home for quite some time.Â* At about 5-10
miles out he said that he'd take over now.Â* What?Â* I thought you were
flying!
There should never be waiting to take over; the pilot flying should take
action when something goes wrong.Â* And there should always be a positive
transfer of control when switching over.
Dan, 5J
  #92
Old September 11th 18, 04:33 PM posted to rec.aviation.soaring
Good point Dan,
The best procedure to insure both pilots know who is actually flying the aircraft is for pilot 1 to say, "you have the aircraft", then pilot 2 says, "I have the aircraft" and then shakes the stick! Never a good idea to add any other info with the transfer of control, like "we need to program the computer, you fly". This message can be easily misunderstood and both pilots start programming the computer and nobody is flying the aircraft!
Food for thought,
JJ
  #93
Old September 11th 18, 04:47 PM posted to rec.aviation.soaring
Jonathan St. Cloud
On Tuesday, September 11, 2018 at 8:33:57 AM UTC-7, wrote:
Good point Dan,
Food for thought,
JJ
I know in the case of my CFI friend David who died a few weeks ago in a citabria spin two CFI's onboard. Dave was insistent on positive transfer of control. And when doing a task, it was sterile cockpit, only relevant information for task at hand.
  #94
Old September 11th 18, 05:08 PM posted to rec.aviation.soaring
Jonathan St. Cloud
On Monday, September 10, 2018 at 9:26:48 PM UTC-7, Eric Greenwell wrote:
George Haeh wrote on 9/10/2018 12:57 PM:
So how does one demonstrate or practice a spin or incipient spin without "misusing" the rudder?
[Puchaz excepted]
In my ASW 20C and ASH 26 E, I could easily get a wing drop from coordinated
flight. I never let either enter a full spin, but always recovered at less than a
quarter turn. Easy to do: I circle at about 20 degree bank while continuously
slowing down, always maintaining coordinated flight; at some point as I slow, the
inner wing will drop and can not be picked up with the ailerons. So, spin entry
with no rudder misuse, just flying too slowly in a turn.
The above is harder to do at 30 degree bank, and I couldn't get it too happen at
40-45 degree bank. I did not experiment with different CG positions - mine was a
bit towards the aft side, but not near the rear limit.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Thanks Eric and Hank for this. I recently viewed on YouTube a good video of a K-23 doing spins from coordinated flight. I had a Nimbus 4T start a spin in coordinated thermaling flight. Quick to put stick against forward stop and rudder opposite to rotation was flying in quarter turn and not sure how much altitude loss, but would be surprised if it was more than 75 feet.
  #95
Old September 11th 18, 06:15 PM posted to rec.aviation.soaring
Great idea!
I do that, I have also flown with other CFIG's and tend to make it obvious whom is flying and whom "may" take control.
In limited cases, the "friendly handshake" is replaced by, grabbing the stick, huge wiggle with a "my ship!" Is crude, but our asses are on the line!
Most "fun" to me was flying power with a towpilot/my GF at the time. Coming in on final in a C-150, short of field, stall warning going off, calm day, they were reaching for yoke, my comment, "Don't **** with the plane!". Hit the numbers, slight tap on brakes, first turnoff.
Stall warning was early, butt and feel said plenty,of margin.
Yes, knowing whom is flying is paramount.
With my mentor or others, a stick nudge or comment is a suggestion to do something else, but, no transfer of PIC.
  #96
Old September 12th 18, 03:29 AM posted to rec.aviation.soaring
2G
On Tuesday, September 11, 2018 at 8:47:49 AM UTC-7, Jonathan St. Cloud wrote:
Good point Dan,
Food for thought,
JJ
"I know in the case of my CFI friend David who died a few weeks ago in a citabria spin two CFI's onboard."
That's very interesting because there hasn't been an accident, fatal or otherwise, involving a Citabria since 2006. Was this outside the US?
Tom
  #97
Old September 12th 18, 03:53 AM posted to rec.aviation.soaring
2G
Good point Dan,
Food for thought,
JJ
There hasn't been an accident involving a Citabria since 2006.
Tom
  #98
Old September 12th 18, 04:03 AM posted to rec.aviation.soaring
Charlie Ryan
The NTSB Aviation Accident Database indicates there have been 13 accidents of Champion built aircraft since February of this year.
5 Scouts (8GCBC), 3 fatalities in 2 accidents, 8 Citabrias (7XXXX, several variants) 1 fatality.
  #99
Old September 14th 18, 12:32 AM posted to rec.aviation.soaring
Andreas Maurer
On Mon, 10 Sep 2018 08:56:05 -0700 (PDT), krasw
maanantai 10. syyskuuta 2018 16.54.53 UTC+3 kirjoitti:
Un-spinable? You might want to watch this and look up the USAF report conducted on the spin characteristics of the ASK-21.
https://www.youtube.com/watch?v=yXH6XDxQdPY
ASK21 is unspinable unless you equip with spin kit designed to move cg well aft of normal limits. Without this kit you cannot spin 21.
One addition:
The spin weights put the CG to the normal aft limit, but not beyond
it.
This is the same CG that you would have if a light pilot flies without
a copilot.
With the spin weights the ASK-21 is an excellent spin trainer.
Cheers
Andreas
  #100
Old September 14th 18, 09:41 AM posted to rec.aviation.soaring
Steve Thompson[_2_]
Referring to the ASK21 TM4b, publicly available on the
AS site. I see on page 4 : "By following the spin ballast
table a c.g. of approx. 406 mm (16 inch) is set in for the
flight."
As far as I can tell from other data, this is not the aft
limit. I believe the aft limit is 469mm.
The USAF spinning tests are well documented in the
technical note flight manual and discusses inertia effects
as well as just CG position effects. 406mm is aft enough.
kirjoitti:
up the USAF report
designed to move cg
spin 21.
One addition:
not beyond
it.
flies without
a copilot.
trainer.
Cheers
Andreas
UK Air Accidents Graham Drinkell Soaring 12 June 18th 09 02:29 PM
Physiology and accidents Bill Daniels Soaring 7 May 30th 07 02:14 PM
Physiology and accidents [email protected] Soaring 0 May 29th 07 09:50 PM
Accidents in progress Dave Kearton Aviation Photos 1 April 30th 07 03:27 PM
Accidents Big John Piloting 3 December 14th 05 01:19 PM
