O2 cylinder
Old February 8th 06, 04:31 PM posted to rec.aviation.soaring
Default O2 cylinder
I think you got it right Gary. Those 180 and 173 rules are all about
transportation in commerce. However, most IA's will still want to see a
hydro date if that bottle is in your glider during your annual.
Old February 8th 06, 05:13 PM posted to rec.aviation.soaring
Default O2 cylinder
Jim, Gary - did you guys read the following (FAA Order 8000.40D)?
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/ed3ccb2b0c40bdad86256abf006f380c/$FILE/8000-40.pdf
1. It applies to Part 91 aircraft, among others (para 1)
2. It says the FAA Adminstrator has adopted "the rules and regulations
of DOT, RSPA, USCG, UL, MIL-SPEC, and applicable manufacturers as
acceptable methods for controlling the hydrostatic tests and life
limits of pressure cylinders" (para 4d)
3. It says "pressure cylinders used aboard aircraft should be
maintained under the same specifications prescribed by the appropriate
regulatory agency and manufacturers if no other requirements are
available." (para 4e)
4. It says "Cylinders which have reached their hydrostatic test due
date cannot be recharged or installed until hydrostatically tested."
(para 6e)
This seems pretty clear - even if your oxygen tank is non-DOT approved,
you have to follow the manufacturer's specs and you have to have it
hydrostatically tested in order to use it in your aircraft.
-John
Old February 8th 06, 07:57 PM posted to rec.aviation.soaring
Default O2 cylinder
John,
That Order was cancelled. It is replaced by HBAW 02-01B.
http://www.airweb.faa.gov/Regulatory...light=8000.40d
Old February 8th 06, 11:05 PM posted to rec.aviation.soaring
Default O2 cylinder
8000.40D)?
http://www.airweb.faa.gov/Regulatory...brary/rgOrders
1)
2. It says the FAA Adminstrator has adopted 'the rules
and regulations
as
tests and life
limits of pressure cylinders' (para 4d)
3. It says 'pressure cylinders used aboard aircraft
should be
by the appropriate
are
available.' (para 4e)
4. It says 'Cylinders which have reached their hydrostatic
test due
tested.'
(para 6e)
have to have it
-John
are all about
still want to see a
your annual.
Yes, that was covered several posts back. FAA wants
the cylinder tested as if it were DOT approved which
is very reasonable. Getting a hydro on a non-DOT 02
cylinder is no problem.
Old February 9th 06, 08:04 AM posted to rec.aviation.soaring
Default O2 cylinder
Eric Greenwell wrote:
I'm under the impression that the cylinders we use in our gliders are
NOT classified as aircraft components, but are, instead, considered
"portable" equipment. To be aircraft components, the glider would have
to be certified with an oxygen system, and none of them are.
This MAY not be true. The FAA reference in Sect 3(Guidance), para D(4)
says:
Any cylinder that is part of a supplementary oxygen system,
that in the course of its normal operation is gradually
depleted, may remain in service if it meets the operational
requirements in 14 CFR § 91.211, Supplemental oxygen.
I would have thought that the oxygen systems we use in gliders are the
same conceptually as the portable cylinders carried on most commercial
airliners for crew use in the event of a decompression. I thought (but
could be wrong) that these were "supplementary oxygen systems"? If so,
DOT markings are unnecessary. I flew with an airline for some years but
I don't recall seeing DOT marked on any of the portable cylinders on the
flight deck.
...What we do
is (I believe) no different than the airplane pilot that carries on a
cloth bag with the cylinder and regulator in it, then uses the seat belt
to strap it down next to him. In other words, our gliders do not have
oxygen systems in them, just carry-on baggage that happens to be an
oxygen system.
If true, then the cylinders have to meet the regulations for carrying
these cylinders around in cars, busses, etc, which would be DOT
regulations.
I'm not sure about that. If we forget how it came into your possession,
the FAA reference in 2(Background) says:
C. Title 49 CFR parts 171 through 180, Hazardous
Materials Regulations (HMR), pertains to the retest
and inspection of cylinders in transportation in
commerce. However, cylinders used as components in
aircraft are not considered to be in transportation in
commerce when installed in an aircraft.
That seems to me to imply that carriage as a supplementary oxygen system
in an aircraft does not qualify as "transportation in commerce". Again,
DOT regs would be inapplicable.
I recall once that a request from our navigators to have a pencil
sharpener clamped to the edge of their table was refused because that
would "install it" in the aircraft. Drawings would have to be drawn,
stress calculations made, Engineering Orders would have to be approved.
A maintenance schedule would need to be developed, transit
qualifications and MELs would have to be considered. I think they were
each issued with pocket sharpeners.
Bush lawyer anybody?
Graeme Cant
Old February 9th 06, 02:19 PM posted to rec.aviation.soaring
Default O2 cylinder
Jim, well that's a bummer! Someone writes an order to bring clarity to
a murky area, then that order is made obsolete by a superceding
directive which leaves us in the dark again. Perhaps this is why my
ASTM buddy hasn't been able to find anything to answer George's
question. It may be that use of pressure systems is not driven by
regulation so much as common sense, fear of litigation, and the
influence of insurance companies.
To answer JW's questions, aluminum and steel are pretty equal with
regard to safety. Of course, aluminum is generally more susceptible to
stress corrosion cracking than steel, and it will have a lower fatigue
life, so I would chose steel if you can stand the weight. The metal
alloys chosen for this application are ductile, so in neither case
would shrapnel be likely to be an issue. (The exception might be if the
bottle were cold enough at altitude to be below its ductile to brittle
transition temperature.) But, exploding in flight would be a pretty
unlikely event; refilling is the dangerous process as it puts rising
tension on any crack tip that may exist.
That said, you really don't want to be anywhere near a failing high
pressure cylinder! There will be an extremely high speed, high pressure
jet going in one direction, and a metal bottle going in the opposite
direction. Failing bottles have been known to go through solid concrete
walls, while high pressure jets have been known to cut people apart.
No one has remarked on the engineering behind these bottles. There are
three main concerns, flaws, fatigue life and corrosion. Flaws are
mostly found through hydrotesting; if a bottle passes it means any flaw
is below the critical crack size for the material. The crack growth
rate per fatigue cycle figure is determined for the material, and the
retest interval is chosen such that a sub-critical crack cannot grow
through refill cycling to critical crack size during the interval. But
fatigue cracking isn't the only mechanism of failure, stress corrosion
crack growth can occur simply by the passage of time, without any need
for stress cycles (it can happen to a full cylinder sitting on the
shelf).
A careful and prudent individual will get his high pressure cylinder
hydrotested every five years (or whatever the manufacturer recommends).
Remember, it's not just the number of refills, it's time passing itself
that can get you. If you think hyrotesting is expensive or
inconvenient, then I recommend you keep in mind Dirty Harry's question
"do you feel lucky?"
-John
jphoenix wrote:
John,
Old February 9th 06, 05:35 PM posted to rec.aviation.soaring
Default O2 cylinder
I think "cylinders used as components in aircraft" refers to built-in
oxygen systems, not the portable, carry-on, systems used in gliders and
the smaller general aviation aircraft. I know it looks like our
cylinders are "components" because there is a mounting hole and strap
for the cylinders, but without an oxygen system certification as part of
the glider, that hole is just another baggage space.
Eric Greenwell
Washington State
USA
www.motorglider.org
Bad cylinder Denny Owning 17 September 12th 05 06:04 PM
Path of an airplane in a 1G roll Chris W Piloting 47 July 4th 05 10:53 PM
Path of an airplane in a 1G roll Chris W Aerobatics 20 June 29th 05 09:35 AM
Path of an airplane in a 1G roll Chris W Home Built 22 June 29th 05 09:35 AM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 01:13 PM
