#21
Why are airplanes white?
In a previous article, "Bob Gardner" said:
It gives the manufacturer more options in selecting trim colors, just as all Boeing jets come out of the factory green. I thought Boeing jets come out of the factory covered in Zinc Chromate rather than paint? -- Paul Tomblin http://blog.xcski.com/ Beware of bugs in the above code; I have only proved it correct, not tried it. - Donald Knuth |
Your assumption is that solar heating is a factor. If the aerodynamic
heating is high, one could argue radiative heat transfer would be enhanced with black body radiation. The SR 71 is, you might notice, black, but that may be the result of long wavelength (longer than optical at least) absorbance considrations. On Nov 3, 1:41 pm, Mxsmanic wrote: Jay Honeck writes: My daughter innocently asked that question the other day, and I gave her the usual "because white reflects heat better" answer -- but that really doesn't add up, does it? Actually it does, at least for high-speed aircraft. They are already heated externally by aerodynamic friction, and letting the sun beat down on them at high altitude with a black paint job would only heat them up more. However, some black liveries are in service, so apparently it's not enough to cause a problem. The old Playboy corporate jet was entirely black, and I think there have been a few others. For small GA aircraft, I can't think of any obvious reason why they should be painted white. |
On 3 Nov, 19:04, Tony wrote:
Your assumption is that solar heating is a factor. If the aerodynamic heating is high, one could argue radiative heat transfer would be enhanced with black body radiation. The SR 71 is, you might notice, black, but that may be the result of long wavelength (longer than optical at least) absorbance considrations. On Nov 3, 1:41 pm, Mxsmanic wrote: Jay Honeck writes: My daughter innocently asked that question the other day, and I gave her the usual "because white reflects heat better" answer -- but that really doesn't add up, does it? Actually it does, at least for high-speed aircraft. They are already heated externally by aerodynamic friction, and letting the sun beat down on them at high altitude with a black paint job would only heat them up more. However, some black liveries are in service, so apparently it's not enough to cause a problem. The old Playboy corporate jet was entirely black, and I think there have been a few others. For small GA aircraft, I can't think of any obvious reason why they should be painted white.- Hide quoted text - - Show quoted text - Loads of good stuff already; I am pretty sure that white shows up surface defects less redily than other colours and that black shows them most clearly. Anyone in car painting would know this for sure. I did read recently that the SR-71 was black to reduce the surface temperature by increasing radiation away from the aircraft. Clearly aeordynamic heating of the structure put a lot of energy in. |
"Richard Riley" wrote http://tinyurl.com/yv62an http://tinyurl.com/yu2jnu That one is close, though there was a clearer, easy to interpret study, I think. -- Jim in NC |
I just hope this conversation doesn't give them the Green light to start
profiteering from the aviation industry. We can talk until we're blue in the face, but it'll remain a black comedy until Sharpton (whatta marroon!) sees this golden opportunity to get back in the pink with his followers, and shows signs of seeing the many shades of gray that this topic has to offer. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
reduce the surface temperature by increasing radiation away from the aircraft. ??? I thought black increased surface temperature? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message ups.com... My daughter innocently asked that question the other day, and I gave her the usual "because white reflects heat better" answer -- but that really doesn't add up, does it? Automobiles, motorcycles, boats -- you name it -- all come in a rainbow of colors. Why are 99.5% of all planes (except for some cool old classics and some neat homebuilts) white? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" http://www.soaridaho.com/Schreder/Co...olor_Temp.html JS |
No Jay, black is more absorbant and more emissive than a shiny
surface. If it's sun light heating you're trying to reduce, you'd want to reflect away the energy with a reflective surface. If, though, the thing you're worried about is hotter than its surroundings and you are interested in radiating the heat away, you'd want increased emissivity, and make it black. A black body radiater is considered perfect, and it is very black indeed. On Nov 3, 5:22 pm, Jay Honeck wrote: I did read recently that the SR-71 was black to reduce the surface temperature by increasing radiation away from the aircraft. silverf sur ??? I thought black increased surface temperature? -- Jay Honeck Iowa City, IA Pathfinder N56993www.AlexisParkInn.com "Your Aviation Destination" |
#29
On Sat, 3 Nov 2007 09:31:29 -0400, "Morgans"
wrote: Fiberglass airplanes almost demand it. If they get too hot, the epoxy gets hot, and gets weak. Very weak. Some of the new Cirrus versions are not white. |
#30
(Paul Tomblin) wrote: In a previous article, "Bob Gardner" said: It gives the manufacturer more options in selecting trim colors, just as all Boeing jets come out of the factory green. I thought Boeing jets come out of the factory covered in Zinc Chromate rather than paint? I thought Zinc Chromate is green. At least the Zinc Chromate I have is green. -- Bob Noel (goodness, please trim replies!!!) |
Similar Threads | ||||
Does it have to WHITE!!! | firstflight | Home Built | 33 | July 26th 05 06:17 PM |
Why are airplanes white? | gatt | Piloting | 30 | July 21st 04 02:55 PM |
*White* Helicopters??!!! | Stephen Harding | Military Aviation | 13 | March 9th 04 07:03 PM |
White over white is alright? | Ron Natalie | Piloting | 3 | July 16th 03 05:24 PM |
white lightning | mansour | Home Built | 16 | July 10th 03 08:46 PM |
