Questions on high altitude pressures
Old November 25th 08, 09:57 PM posted to rec.aviation.piloting
Mxsmanic
Default Questions on high altitude pressures
writes:
The point is that even with SA, GPS accuracy is pretty good and has nowhere
near 2 orders of magnitude altitude error compared to lateral as you stated.
You call a 500-foot error in altitude good?
Absolutely wrong.
All I have to do is look at my GPS and watch it wander up and down by tens of
metres at a time. GPS is not designed for vertical accuracy.
See the the data:
http://users.erols.com/dlwilson/gpswaas.htm
"The" data? It's just one person making experiments. I can do that, too; and
I get huge errors in altitude, so much so that I've never used GPS for
altitude measurements.
If you knew anything about real flying, you would know that you NEVER
use GPS as your altimeter under ANY circumstances for reasons entirely
unlrelated to GPS accuracy.
What are those reasons related to, if not accuracy?
If it's as accurate as you seem to believe, it should be fine for IFR. Go
ahead and use it for that, and make me a liar. Are you prepared to bet your
life on it?
But how would you know as you have never been in a real airplane with
a real altimeter and a real GPS?
I've been using GPS for many years. It's almost useless for measuring
altitude.
Old November 25th 08, 11:05 PM posted to rec.aviation.piloting
Mxsmanic wrote:
writes:
That's 492 feet with SA on, which as you've already acknowledged has been
off for a long time.
Absolutely wrong.
YOUR GPS receiver is not designed for vertical accuracy because you are
too poor to be able to afford a decent one.
See the the data:
I can point you to dozens of sites with similar data and the GPS
specs as well, but you could just do it yourself and admit for once
that you are wrong.
Regulations, the nature of real air, the way real airplanes fly and
common sense.
Beg for some money, give the money to a CFI, and it will be explained
in detail to you.
common sense.
altitude.
MY non-WAAS, aviation GPS receiver measures altitude that is within about
+/- 15 feet, or about +/- 4m, which is what everyone with a real GPS
gets.
So, to summarize:
You know nothing about GPS specifications.
You know nothing about aviation use of GPS.
Because you are such an arrogant, opinionated ass, you can't get a job
that would enable you to afford a decent GPS receiver.
That about sum it up?
I doubt the time accuracy on your piece of crap GPS is anywhere near
the nanosecond capabilities of a decent receiver either.
Jim Pennino
Remove .spam.sux to reply.
Old November 25th 08, 11:10 PM posted to rec.aviation.piloting
Viperdoc[_6_]
Anthony, what kind of GPS are you using- is it a Garmin 530/430 with WAAS?
How many satellites do you track at a time- or are you referring to playing
MSFS again and confusing it with reality?
  #24
Old November 25th 08, 11:35 PM posted to rec.aviation.piloting
I would guess an old Tom-tom someone threw away.
Jim Pennino
  #25
Old November 26th 08, 05:25 AM posted to rec.aviation.piloting
Mxsmanic
writes:
The GPS system is not designed for vertical accuracy. It was designed as an
aid to lateral navigation. The geometry of the system does not favor vertical
accuracy.
that you are wrong.
I can point you to dozens of sites that "prove" that Denver's airport overlies
a huge alien base underground, but that doesn't make it so.
common sense.
If GPS were accurate, why would any of these other factors make a difference?
in detail to you.
I know a lot more about how GPS works than the typical CFI.
common sense.
See above. Why wouldn't regulations allow something that is as accurate as
you say?
They cannot be designed for vertical accuracy. The system itself is not
designed for that.
gets.
How do you know?
Actually, they all need nanosecond accuracy. But if you know how GPS works,
you already know that, right?
  #26
Old November 26th 08, 05:26 AM posted to rec.aviation.piloting
Mxsmanic
Viperdoc writes:
In real life? I have a handheld Garmin. In simulation? A 530 and a 430,
without WAAS (but they are always completely accurate in simulation, anyway).
In real life, up to twelve satellites simultaneously.
  #27
Old November 26th 08, 05:27 AM posted to rec.aviation.piloting
Mxsmanic
Clark writes:
Of course mxy is ignorant of the current GPS performance and too stupid to
understand that the technology has improved.
The design has not changed, and unless the planet becomes transparent to GPS
signals, accuracy cannot improve much.
  #28
Old November 26th 08, 06:35 AM posted to rec.aviation.piloting
Mxsmanic wrote:
writes:
accuracy.
You are making yourself look the fool more than ever.
Both the specifications and typical results for vertical versus lateral
error for SA on, SA off, and WAAS are all less than 2:1, not the 100:1
you claim.
that you are wrong.
Sure, you can find kook sites, but that is an irrelevant red herring.
GPS error has been studied and results published on the web by lots
of univerities, major corporations, and government agencies, including
the NIST and the FAA.
The full specifications for GPS are publically available.
All say you are wrong, wrong, wrong.
common sense.
Start with the fact that not all real airplanes have GPS and not all real
airplanes that have GPS have WAAS capable GPS and no real airplane has a
"pause" key and see if you can figure it out.
From your statements so far, i.e. vertical error is two orders of magnitude
greater than lateral error, it appears you know nothing about GPS other
than how to spell it.
designed for that.
Wrong, wrong wrong.
You might try reading the actual GPS system specifications before you
make such inane statements.
gets.
How do you know?
By looking at the displayed GPS altitude while on the ground and comparing
that to the published field elevation.
By looking at the displayed GPS altitude and comparing to the surveyed
altitude of my location, e.g. my house.
That should be obvious to anyone with more than two functioning brain
cells.
Wrong again.
Time accuracy is a measure of the error in the GPS time of day output,
just like for position, which includes a 1 pps signal.
Most consumer grade GPS receivers do not contain the circuitry needed
for nanosecond accurate time of day output.
And before you make yourself even more a fool on this point too, you might
want to go see what the National Institute of Standards and Technology
has to say on the subject.
Jim Pennino
  #29
Old November 26th 08, 06:45 AM posted to rec.aviation.piloting
Mxsmanic wrote:
Clark writes:
Wrong yet again.
SA turned off, differential GPS, WAAS, and LAAS.
Jim Pennino
  #30
Old November 26th 08, 06:59 AM posted to rec.aviation.piloting
John E. Carty
"Mxsmanic" wrote in message
writes:
an
vertical
accuracy.
that you are wrong.
overlies
common sense.
difference?
in detail to you.
common sense.
as
you say?
designed for that.
gets.
How do you know?
works,
I usually refrain from this kind of post. However, you absolutely must be
one of the following:
A: A computer simulator "pilot"
B: An Idiot
C: Both A and B
High Altitude Waypoints Dennis Johnson Instrument Flight Rules 7 May 2nd 08 02:44 AM
High Altitude Linnies TTaylor at cc.usu.edu Soaring 4 August 4th 06 10:47 PM
High altitude & RPM abripl Home Built 1 September 1st 05 12:12 AM
High-altitude autorotations? Bill McClain Military Aviation 17 March 15th 04 04:23 PM
Low and high altitude airways David Megginson Instrument Flight Rules 7 September 9th 03 01:18 AM
