#61
Stall spin during aero tow? Std cirrus
I know, I have seen radios as low as $250. A decent used Becker or Dittel 25kHz unit can be picked up in Europe for 100-150 Euros, so the 'high cost' argument is BS. Uli 'AS' |
#62
At 17:21 27 August 2018, Jonathon May wrote:
At 15:48 27 August 2018, Dan Marotta wrote: On 8/27/2018 9:21 AM, kirk.stant wrote: ...Unfortunately our most commonly used trainer is a Blanik L- 13AC, and our A&Ps can't find a legal way to put a battery in it. Kirk I would think a simple fabricated tray with hold down and a mechanic's logbook entry would be sufficient. -- Dan, 5J I asked the tug pilot for 5Kn more last week and he said "At the rev limit"...Ballasted Ventus behind a Euro fox with fine prop to optimise towing 2 seaters.I was at 60 Kn so not too marginal. You cannot beat a pawnee but you can break the bank using them There's a device known as a throttle that helps with this. Suggest your towing organisation gets these installed and trains your tug pilots in its use. |
#63
weird when I read "Stick and Rudder" and went through flight training I was taught to pitch for airspeed
#64
On Tuesday, August 28, 2018 at 1:33:24 PM UTC-7, Tony wrote:
weird when I read "Stick and Rudder" and went through flight training I was taught to pitch for airspeed Nice one, Tony. Amazed it took three posts to hit it on the head. Jim |
#65
Well, maybe the pitch of the prop is such that 60 KIAS is his maximum
speed at the rev limiter and it's a fixed pitch prop.Â* If that's the case, then pitching down won't accomplish much other than to have the rev limiter shut off the ignition. On 8/28/2018 4:28 PM, JS wrote: On Tuesday, August 28, 2018 at 1:33:24 PM UTC-7, Tony wrote: weird when I read "Stick and Rudder" and went through flight training I was taught to pitch for airspeed Nice one, Tony. Amazed it took three posts to hit it on the head. Jim -- Dan, 5J |
Similar Threads | ||||
Stall/spin and ground reference maneuvers | Bill D | Soaring | 55 | March 11th 14 05:35 PM |
Improved shear/stall-spin alarms | KiloKilo[_2_] | Soaring | 23 | June 11th 13 11:55 PM |
Another stall spin | Jp Stewart | Soaring | 153 | September 14th 12 07:25 PM |
Stall/ Spin testing the RV-12 | cavelamb himself[_4_] | Home Built | 3 | May 14th 08 07:01 PM |
Glider Stall Spin Video on YouTube | ContestID67 | Soaring | 13 | July 5th 07 08:56 AM |
