#11
Trip report: Cirrus SR-22 demo flight
You didn't mention how it handled in the bumps, below clouds on the return flight. How did it handle then?
It handled fine in the bumps. I don't remember when (or even if there was a specific point at which) I became aware of the somewhat unnatural (or perhaps just unfamiliar) feel of the bungee forces (rather than the aerodynamic forces) on the control stick, but it might have been that the way the aircraft handled in the bumps contributed to identifying the issue. You can't (while hand flying) let your attention wander from the altimeter though, pitch trim is crucial and very sensitive. You'll find yourself climbing or descending unawares if you don't keep on top of that. A few other points I forgot to mention. Presumably because of the issues Cirrus had with the brakes, there is a little blue dot on each main gear to check during preflight. If it's no longer blue, that means "something is wrong" (I presume it indicates the brakes had overheated) and should be checked further. Also the windows don't open. There is no little window to shout "clear" out of (though you could easily open the gull door), and no window to open for photography. And when seated at the controls, my knees were close to the bottom of the control panel - a tighter fit than I am used to. The flight computers give wind speed and direction, calculated from heading and track information. This is pretty cool. If would be nice if one of the approach chart configurations gave the (enlarged) plan view as well as the comm strip at the same time. An awesome machine to be sure. Now all we need is a return of some irrational exuberance and I can upgrade from my Cherokee! My offer still stands. If anybody wants to send me a half million dollars, I'll be happy to keep it warm for you. I'll even do it with a quarter million dollars, if you happen to be out of change at the moment. How's that for irrational exuberance? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote: You didn't mention how it handled in the bumps, below clouds on the return flight. How did it handle then? It handled fine in the bumps. I don't remember when (or even if there was a specific point at which) I became aware of the somewhat unnatural (or perhaps just unfamiliar) feel of the bungee forces (rather than the aerodynamic forces) on the control stick, but it might have been that the way the aircraft handled in the bumps contributed to identifying the issue. You can't (while hand flying) let your attention wander from the altimeter though, pitch trim is crucial and very sensitive. You'll find yourself climbing or descending unawares if you don't keep on top of that. A few other points I forgot to mention. Presumably because of the issues Cirrus had with the brakes, there is a little blue dot on each main gear to check during preflight. If it's no longer blue, that means "something is wrong" (I presume it indicates the brakes had overheated) and should be checked further. Also the windows don't open. There is no little window to shout "clear" out of (though you could easily open the gull door), and no window to open for photography. And when seated at the controls, my knees were close to the bottom of the control panel - a tighter fit than I am used to. The flight computers give wind speed and direction, calculated from heading and track information. This is pretty cool. If would be nice if one of the approach chart configurations gave the (enlarged) plan view as well as the comm strip at the same time. An awesome machine to be sure. Now all we need is a return of some irrational exuberance and I can upgrade from my Cherokee! My offer still stands. If anybody wants to send me a half million dollars, I'll be happy to keep it warm for you. I'll even do it with a quarter million dollars, if you happen to be out of change at the moment. How's that for irrational exuberance? Jose I got to fly an SR-22 in a formation flight a couple of weeks ago. I found that there were significant breakout forces in the control system (friction) and that the single power control had some dead spots in it, which made precision flying difficult. The owner, however, did not have much trouble, as he was used to those characteristics. |
found that there were significant breakout forces in the control system (friction) There is a significant initial force required to deflect the control from center, but once deflected, it did not take proportionally more force to deflect it further. It was definately a "snap to center" type of stick. Is this what you are referring to? and that the single power control had some dead spots in it I didn't fly it enough to notice that, however I did notice that when reducing power in the pattern (it has to be reduced a lot!) there =seem= to be areas where the reduction seems nonlinear. This could however be due to the power computer adjusting its propeller pitch parameters. Twice in the pattern wasn't enough to nail that down, beyond "gee, I noticed that". The owner, however, did not have much trouble, as he was used to those characteristics. Every plane has its character. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote: I got to fly an SR-22 in a formation flight a couple of weeks ago. I found that there were significant breakout forces in the control system (friction) There is a significant initial force required to deflect the control from center, but once deflected, it did not take proportionally more force to deflect it further. It was definately a "snap to center" type of stick. Is this what you are referring to? Yes -- it makes precision flying difficult. and that the single power control had some dead spots in it I didn't fly it enough to notice that, however I did notice that when reducing power in the pattern (it has to be reduced a lot!) there =seem= to be areas where the reduction seems nonlinear. This could however be due to the power computer adjusting its propeller pitch parameters. Twice in the pattern wasn't enough to nail that down, beyond "gee, I noticed that". The owner explained that there is a cam connecting throttle and prop control and that it has a deadband. The owner, however, did not have much trouble, as he was used to those characteristics. Every plane has its character. So does every Newsgroup. :) |
Similar Threads | ||||
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Cirrus SR22 demo flight | [email protected] | Piloting | 44 | May 6th 05 04:47 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
