Tow rope musings - informal survey
Old February 26th 19, 07:28 PM posted to rec.aviation.soaring
Matt Herron (Sr)
Default Tow rope musings - informal survey
My first launch in Lithuania last October was certainly no more than fifty feet behind the tow plane. I found it possible, but extremely difficult to stay in sync with the tow.
I was told the short line was standard there because it allows for retrieves from short fields.
In deference to my American ways, they added considerable length to the tow line for all subsequent launches.
Old February 26th 19, 09:36 PM posted to rec.aviation.soaring
You'd think they'd reserve the ultra-short ropes for short-field retrieves ONLY?
Old February 26th 19, 11:57 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
Just watched an American (PBS) film on "German transport aircraft
of WW2"; it had some interesting footage of THREE Heinkel 111's
(just) launching a truly massive transport glider......
Interesting to speculate on who was in control of that launch!
Dave Walsh
Old February 27th 19, 12:42 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
On Tue, 26 Feb 2019 23:57:53 +0000, Dave Walsh wrote:
Just watched an American (PBS) film on "German transport aircraft of
WW2"; it had some interesting footage of THREE Heinkel 111's (just)
launching a truly massive transport glider...... Interesting to
speculate on who was in control of that launch! Dave Walsh
An Me-321 Gigant, but initial tests used a Ju-90 and then three Me-110s
to tow them. Improvements were needed and two were made:
1) Use an He-111Z (two He-111s stuck together side-by-side with a 5th
engine fitted on the centre line where the cut-down inner wings joined.
This never seems to have been much good.
2) Fit 6 1160 hp radial engines made in the captured Gnome et Rhone
factory and call the result an Me-323 Gigant. They flew well enough, but
were slow and poorly defended, making them easy meat for the RAF
operating from Malta when they were used to supply Rommel's Afrika-Corps
Martin | martin at
Gregorie | gregorie dot org
Old February 27th 19, 12:45 AM posted to rec.aviation.soaring
George Haeh
The "Troika Schlepp" incurred considerable tow pilot attrition.
Old February 27th 19, 06:12 AM posted to rec.aviation.soaring
Bruce Hoult
If the difference between a 20m rope and 60m rope is going to make any significant difference to the takeoff then I'm going to be calling for the car and trailer in any case!
Old February 27th 19, 03:05 PM posted to rec.aviation.soaring
Tony[_5_]
Have you seen Lithuanian cars and trailers?
Old February 27th 19, 09:06 PM posted to rec.aviation.soaring
Bruce Hoult
No, but I've seen the top of a windbreak hedge a lot closer than I liked, and that was at the end of a 1000m long field. I don't believe 30 or 40 metres of tow rope length would make any appreciable difference, compared to the variability of wind, slope, and soft surface.
To be fair, the tow pilot held it in ground effect for a long time, so when he did eventually climb over the windbreak it was with speed in hand.
Old February 28th 19, 07:11 AM posted to rec.aviation.soaring
I make our tow ropes about 210' long, out of 3/8" hollow-braid poly (bought through W&W because for some reason the local businesses that sell rope around here consider it a waste of time to sell us four 1,000' spools of rope, prepaid). The ropes are used for one season maximum. We are on a nice, lush grass field and the ropes seldom need to have the ends cut and remade from abrasion. Any rope that looks suspect gets taken out of service. When we have an away trip to a paved field I take the rope that was used for towing there out of service when it returns because by then the combination of the wear it has received during flying at ho,e combined with the wear on the paved runway make it questionable enough that I would rather replace it. We have a set of weak links for the gliders we tow (club and private both Tost and Schweizer rings). The L-19 towplanes have Tost hooks.
Old February 28th 19, 01:05 PM posted to rec.aviation.soaring
Tango Eight
PM sent. Interested in your L-19 Tost hook installation.
best,
Evan
she will essentially confess informal and benefits our rapid, mature entitys in charge of a wall Robbie Piloting 0 August 13th 07 11:21 PM
Winter Musings Ray Lovinggood Soaring 0 December 3rd 06 01:28 PM
Report of Oct. '04 SSA Director's Mtg - informal Caracole Soaring 2 November 7th 04 05:32 AM
Informal Survey... john smith Piloting 21 September 21st 04 02:40 AM
Fwd: Informal Tonopah Flying Ramy Yanetz Soaring 0 June 10th 04 07:40 PM
