3 Turn Point Distance
Old March 4th 21, 11:51 AM posted to rec.aviation.soaring
Tango Eight
Default 3 Turn Point Distance
On Wednesday, March 3, 2021 at 10:05:20 PM UTC-5, xcnick wrote:
On Wednesday, March 3, 2021 at 6:55:33 PM UTC-8, tango:
CNv works a little differently, you must declare the task you want declared on the ground, then that declaration remains active until superseded.
does this mean that if I change the go to on the CNv I loose the declaration?
No, once the declaration is set in CNv, it's set for keeps. Use for navigation as you like.
A 750 diplome needs to be done to 3TP distance rules. Use release or declared start, up to 3 turn points (in any order), finish isn't declared, it's best fix. Free 3TP distance is a separate category for records.
T8
Video Surfaces Of Russian Su-27 Making Aggressive Turn Into U.S. F-15 During Intercept - Su-27 aggressive turn.jpg Miloch Aviation Photos 0 February 1st 19 03:27 AM
turn point glen Soaring 14 May 26th 13 02:15 AM
Turn point Files Zaphod Beeblebrox Soaring 1 March 25th 12 02:26 PM
Turn point website and flight logs Udo Soaring 2 December 5th 06 10:03 PM
Calculating vertical time and distance in a stall turn (US Hammerhead) Dave Aerobatics 3 November 20th 03 10:48 AM
