Spinner strobing as a "Bird Strike Countermeasure"
Old December 6th 07, 05:04 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Alan Baker
Default Spinner strobing as a "Bird Strike Countermeasure"
In article
Harry K wrote:
On Dec 5, 2:05 pm, wrote:
In rec.aviation.piloting Harry K wrote:
snip
Harry K- Hide quoted text -
- Show quoted text -
After thinking that over...
It gets worse. There will be multiple rpm that will show the
effect
under strobe conditions. With a 2 blade prop it can be
sychronizing
every 1/2 rev. 3-blade prop every 1/3 or 2/3 rev, etc. in
addition to
synching on the harmonics.
It isn't that bad.
Synchronization only occurs on integral fractions and engine RPM is
usually 1000 and about 2700 RPM so the possibilities are limited.
For a 2 bladed prop:
7200/2= 3600 - 1800 RPM
7200/3= 2400 - 2400 RPM and 1200 RPM
7200/4= 1800 - 1800 RPM and 900 RPM
etc.
I leave it to someone else to show how many blades you see at each
RPM.
Jim Pennino
Since the prop appears stationary, you would see all the blades.
Yes, but how many virtual blades will you see?
Simple example: You are illuminating a 2 bladed prop running at 1000
RPM
with a strobe light pulsing at 4000 pulses per minute.
In the time between pulses, the prop makes 1/4 of a turn.
The prop is therefor lite up every 1/4 turn and it appears as though
the prop has 4 blades.
Jim Pennino
Remove .spam.sux to reply.- Hide quoted text -
Nope. The prop appears stationary and you see only the two.
What you see is the complete image (frame), not a composite of 4
'frames'.
I'm talking about eyeballs and strobed light here, there are no "images"
or "frames" involved.
What you see is a prop blade in whatever position it is in when
the light goes off.
If the light is going off every quarter turn, you see a particular
blade end in four different places each a quarter turn apart.
If the light is going off every sixth of a turn, you see a particular
blade end in six different places each a sixth of a turn apart.
Jim Pennino
Yes, but you will see them (along with all the others) one at a time.
Not the entire sequence at once or even a composite. It is the same
as taking a snap shot with shutter speed fast enough to stop the
motion, it will show all blades, in this case it will show two blades
and no 'virtual' blades. You can prove it with a fan and a variable
strobe light but I suspect that will not be a common kitchen
appliance .
Harry K
You are apparently unacquainted with the phenomenon known as
"persistence of vision".
Look it up.
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling four feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect if you
sit in the bottom of that cupboard."
  #182
Old December 6th 07, 05:55 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
the light goes off.
Jim Pennino
appliance .
Um, no.
Assuming everything is synchronous, you will see what appears to be
multiple blades because of eye persistence, the same reason movies
appear to smoothly move.
It is the same as taking snap shots with shutter speed fast enough
to stop the motion, and taking an integral number of snap shots
during the rotation.
Take one snap shot when the blade tip is straight up, take the
next when the blade has moved 90 degrees, the next when the blade
has moved another 90 degees, take the last when the blade has moved
another 90 degrees.
Make slides of the pictures and put them on top of each other to
simulate eye persistence.
Replace "take the snap shot" with "flash the strobe".
You can prove it with a fan and a variable strobe light.
Jim Pennino
  #183
Old December 6th 07, 06:19 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
d.g.s.
On 12/3/2007 8:32 PM Mxsmanic ignored two million years of human
evolution to write:
At any given moment there are thousands of aircraft powered by turbofans in
flight.
At any given moment, you're a total dip****. You also lie a lot.
dgs
  #184
Old December 6th 07, 01:46 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Airbus
says...
snip
effect
sychronizing
addition to
It isn't that bad.
etc.
RPM.
Jim Pennino
Simple example: You are illuminating a 2 bladed prop running at 1000 RPM
Jim Pennino
'frames'.
the light goes off.
Jim Pennino
appliance .
Don't agree - I agree with Jim, and I do frequently use scientific strobe
analysers for decomposing motion. With such a tool, one must be very careful to
avoid harmonic illusions. Obvjects may appear to be moving in reverse, and
indeed phantom members may appear - a fan or prop or spoke for example may
easily appear to have more blades than it really has. Our eyes do not
immobilize instantaneous images beyond a certain speed - this makes it
possible for us to watch movies - or to be fooled by stroboscopic images.
  #185
Old December 6th 07, 04:10 PM posted to rec.aviation.piloting, rec.aviation.homebuilt
Harry K
the light goes off.
Jim Pennino
appliance .
Um, no.
another 90 degrees.
Jim Pennino
Hmmm...It looks like I will have to locate a strobe and try it. I
don't recall anything like that illusion back in my physics classes in
HS but that was near 60 years ago. Just one of those things where I
have to see it myself to believe it.
Harry K
  #186
Old December 6th 07, 06:50 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
dgs writes:
You aren't only here to discuss aviation.
I try to discuss aviation, if I can find anyone else who wants to.
  #187
Old December 7th 07, 03:12 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
george
On Dec 5, 2:01 pm, Mxsmanic wrote:
I've written a lot of Wikipedia articles myself. Do you believe what I've
written because I put it in Wikipedia?
So that's where the inaccuracies about aviation came from...
Don't do it again
  #188
Old December 7th 07, 06:45 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
george writes:
Who said anything about aviation?
Don't do it again
Or else what?
  #189
Old December 7th 07, 02:21 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
george writes:
Don't do it again
Or else what?
Or you'll prove yourself to be an ever bigger dickhead than anyone thought,
I would imagine.
I disagree,of course, I have complete faith in you.
Bertie
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 10:48 PM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
Bird strike(s) Jay Honeck Piloting 45 November 30th 05 04:39 AM
Bird strike Jase Vanover Piloting 16 May 17th 05 11:44 AM
