PowerFLARM updates and installation notes
Hi All - I've posted some notes about
PowerFLARM at Mifflin, and encourage pilots to post their experiences he http://powerflarm.us/2012/05/powerfl...and-elswehere/ Also, I posted some notes on installations, including the "Hall of Shame" which you may find entertaiing. Hopefully this will answer some of the ~100 emailed questions I have been unable to personally respond to yet... http://powerflarm.us/powerflarm-installation-notes/ Hope you find these helpful, Best Regards, Dave "YO electric" |
Good news !!
And good initiative about the "Hall of Shame". It cannot be expected that everybody has a reasonable understanding of radio wave propagation. So, the illustrations of "How Not To" are very usefull. Now the most important question: What about Brick delivery schedule (for non-contest folks that often fly together in close proximity on convergence lines) ? 3U |
On May 31, 2:50*pm, Three Uniform wrote:
Good news !! And good initiative about the "Hall of Shame". It cannot be expected that everybody has a reasonable understanding of radio wave propagation. So, the illustrations of "How Not To" are very usefull. Now the most important question: What about Brick delivery schedule (for non-contest folks that often fly together in close proximity on convergence lines) ? 3U It looks to me that we're about 6 weeks or more from delivery. My vendor just sent out a note to his customers confirming which display they were ordering, but he hasn't asked for the up-front payment yet. I've got a question. It looks like the top of the glare shield is the best spot. However, in my plane (ASW-19) the glare shield ejects with the canopy. If I ever have to bail out installing the antenna up there will keep the canopy from coming loose. Is there some kind of breakaway connector I can use in the antenna cable? Alternately, is there a rubber duck kind of antenna I can use instead that would poke through a hole in the glare shield, like Bill Elliot did in this install: http://www.gliderpilot.org/FlarmInstallation Thanks, -- Matt |
On May 31, 1:32*pm, Matt McKrell wrote:
On May 31, 2:50*pm, Three Uniform wrote: Good news !! And good initiative about the "Hall of Shame". It cannot be expected that everybody has a reasonable understanding of radio wave propagation. So, the illustrations of "How Not To" are very usefull. Now the most important question: What about Brick delivery schedule (for non-contest folks that often fly together in close proximity on convergence lines) ? 3U It looks to me that we're about 6 weeks or more from delivery. *My vendor just sent out a note to his customers confirming which display they were ordering, but he hasn't asked for the up-front payment yet. I've got a question. *It looks like the top of the glare shield is the best spot. However, in my plane (ASW-19) the glare shield ejects with the canopy. If I ever have to bail out installing the antenna up there will keep the canopy from coming loose. *Is there some kind of breakaway connector I can use in the antenna cable? *Alternately, is there a rubber duck kind of antenna I can use instead that would poke through a hole in the glare shield, like Bill Elliot did in this install:http://www.gliderpilot.org/FlarmInstallation Thanks, -- Matt Matt, I helped install many different FLARM units at Mifflin. On the AS and LS planes we would attach the antenna from under the glare screen and use Velcro or similar so that it would pull loose if you need to eject. There should be no metal interference under the glare screen like in a SH, so you can just put the top half of the antenna up through the screen and have the wire just below. We did this on an LS-6 and I believe it worked fine. The alternative is to cut a hole large enough for the entire antenna to come through but still attach it on the underside so it will pull loose. |
On May 31, 4:04*pm, Tim Taylor wrote:
On May 31, 1:32*pm, Matt McKrell wrote: On May 31, 2:50*pm, Three Uniform wrote: Good news !! And good initiative about the "Hall of Shame". It cannot be expected that everybody has a reasonable understanding of radio wave propagation. So, the illustrations of "How Not To" are very usefull. Now the most important question: What about Brick delivery schedule (for non-contest folks that often fly together in close proximity on convergence lines) ? 3U It looks to me that we're about 6 weeks or more from delivery. *My vendor just sent out a note to his customers confirming which display they were ordering, but he hasn't asked for the up-front payment yet. I've got a question. *It looks like the top of the glare shield is the best spot. However, in my plane (ASW-19) the glare shield ejects with the canopy. If I ever have to bail out installing the antenna up there will keep the canopy from coming loose. *Is there some kind of breakaway connector I can use in the antenna cable? *Alternately, is there a rubber duck kind of antenna I can use instead that would poke through a hole in the glare shield, like Bill Elliot did in this install:http://www.gliderpilot.org/FlarmInstallation Thanks, -- Matt Matt, I helped install many different FLARM units at Mifflin. *On the AS and LS planes we would attach the antenna from under the glare screen and use Velcro or similar so that it would pull loose if you need to eject. *There should be no metal interference under the glare screen like in a SH, so you can just put the top half of the antenna up through the screen and have the wire just below. *We did this on an LS-6 and I believe it worked fine. *The alternative is to cut a hole large enough for the entire antenna to come through but still attach it on the underside so it will pull loose. For Schleicher (I'm not familiar with LS gliders), I strongly recommend supporting the antenna from something other than the glare shield. I suggest a non-conductive (plastic, G-10, phenolic laminate...) rail mounted to the canopy/instrument panel supporting structure below the glare shield, with a hole in the glare shield that allows positioning the tip of the dipole antenna close to but not touching the canopy. I did this on my ASW-20 such that I can easily remove and replace the canopy without disturbing the flarm antenna. I'd go nuts if I had to mess with that antenna every time I pulled the canopy off... and even more so if I forgot about the antenna and damaged something. -Evan Ludeman / T8 |
On May 31, 11:07*am, Dave Nadler wrote:
Hi All - I've posted some notes about PowerFLARM at Mifflin, and encourage pilots to post their experiences hehttp://powerflarm.us/2012/05/powerfl...fflin-and-elsw... Also, I posted some notes on installations, including the "Hall of Shame" which you may find entertaiing. Hopefully this will answer some of the ~100 emailed questions I have been unable to personally respond to yet...http://powerflarm.us/powerflarm-installation-notes/ Hope you find these helpful, Best Regards, Dave "YO electric" You have to admit that the huge honking dipole antenna, coax cable, and mount, right in the middle of where you want to look on the glareshield amounts to Chinese torture. Or at least will not make for any cool industrial design awards. http://powerflarm.us/wp-content/uplo..._dipole_SH.jpg I hope to heaven you guys can work out a prettier antenna and installation. |
On Thursday, May 31, 2012 5:17:17 PM UTC-4, John Cochrane wrote:
You have to admit that the huge honking dipole antenna, coax cable, and mount, right in the middle of where you want to look on the glareshield amounts to Chinese torture. Or at least will not make for any cool industrial design awards. http://powerflarm.us/wp-content/uplo..._dipole_SH.jpg I hope to heaven you guys can work out a prettier antenna and installation. Thanks to Dave and PowerFLARM US for the hard work at Perry and Mifflin to improve the PowerFLARM range issue. However I totally agree with John regarding the uglyness and size of the dipole antenna in the above URL. Forgive me for being reckless with my opinion but that installation sucks and is just not acceptable in the middle of one's vision field. My PowerFLARM order is "on hold" until a "no restricted vision" antenna is available. Please, please come up with something better. |
On Thursday, May 31, 2012 4:47:46 PM UTC-7, wrote:
On Thursday, May 31, 2012 5:17:17 PM UTC-4, John Cochrane wrote: You have to admit that the huge honking dipole antenna, coax cable, and mount, right in the middle of where you want to look on the glareshield amounts to Chinese torture. Or at least will not make for any cool industrial design awards. http://powerflarm.us/wp-content/uplo..._dipole_SH.jpg I hope to heaven you guys can work out a prettier antenna and installation. Thanks to Dave and PowerFLARM US for the hard work at Perry and Mifflin to improve the PowerFLARM range issue. However I totally agree with John regarding the uglyness and size of the dipole antenna in the above URL. Forgive me for being reckless with my opinion but that installation sucks and is just not acceptable in the middle of one's vision field. My PowerFLARM order is "on hold" until a "no restricted vision" antenna is available. Please, please come up with something better. I second that. As much as I am advocating for powerflarm, I did not envision having to look through something like that, nor even through 2 rubber duckies that going all the way to the canopy. I sure hope there is less intrusive solution, even if it will reduce the range a little. BTW, I flew with my MRX PCAS antenna horizontally for years from the same reason and there was no noticable reduction in range, but I understand that powerflarm is much more sensitive to antenna installation. I sure hope a clean installation which does not interfere with visibility is available. After all, a powerflarm is no good if it reduces forward visibility. Ramy |
On May 31, 6:21*pm, Ramy wrote:
On Thursday, May 31, 2012 4:47:46 PM UTC-7, wrote: On Thursday, May 31, 2012 5:17:17 PM UTC-4, John Cochrane wrote: You have to admit that the huge honking dipole antenna, coax cable, and mount, right in the middle of where you want to look on the glareshield amounts to Chinese torture. Or at least will not make for any cool industrial design awards. http://powerflarm.us/wp-content/uplo..._dipole_SH.jpg I hope to heaven you guys can work out a prettier antenna and installation. Thanks to Dave and PowerFLARM US for the hard work at Perry and Mifflin to improve the PowerFLARM range issue. However I totally agree with John regarding the uglyness and size of the dipole antenna in the above URL. Forgive me for being reckless with my opinion but that installation sucks and is just not acceptable in the middle of one's vision field. My PowerFLARM order is "on hold" until a "no restricted vision" antenna is available. Please, please come up with something better. I second that. As much as I am advocating for powerflarm, I did not envision having to look through something like that, nor even through 2 rubber duckies that going all the way to the canopy. I sure hope there is less intrusive solution, even if it will reduce the range a little. BTW, I flew with my MRX PCAS antenna horizontally for years from the same reason and there was no noticable reduction in range, but I understand that powerflarm is much more sensitive to antenna installation. I sure hope a clean installation which does not interfere with visibility is available. After all, a powerflarm is no good if it reduces forward visibility. Ramy I was involved with installing about seven units and all were much more elegant than what you see on the web page. Mine is installed about 4" in front on my compass that is on top of the glare screen. I only see the top 1.5 inches of the antenna which is very small and narrow. Many others put the bulk below the glare screen with only the top 1.5 inches showing. It would be nice to see the antenna have the cable come in from one end rather than at the middle. Remember what you see so far were done in a loaned hanger on a rainy day in the midst of a contest. Evan's is installed below and mine is very unobtrusive in flight. |
On May 31, 8:52*pm, Tim Taylor wrote:
On May 31, 6:21*pm, Ramy wrote: On Thursday, May 31, 2012 4:47:46 PM UTC-7, wrote: On Thursday, May 31, 2012 5:17:17 PM UTC-4, John Cochrane wrote: You have to admit that the huge honking dipole antenna, coax cable, and mount, right in the middle of where you want to look on the glareshield amounts to Chinese torture. Or at least will not make for any cool industrial design awards. http://powerflarm.us/wp-content/uplo...dipole_SH..jpg I hope to heaven you guys can work out a prettier antenna and installation. Thanks to Dave and PowerFLARM US for the hard work at Perry and Mifflin to improve the PowerFLARM range issue. However I totally agree with John regarding the uglyness and size of the dipole antenna in the above URL. Forgive me for being reckless with my opinion but that installation sucks and is just not acceptable in the middle of one's vision field. My PowerFLARM order is "on hold" until a "no restricted vision" antenna is available. Please, please come up with something better. I second that. As much as I am advocating for powerflarm, I did not envision having to look through something like that, nor even through 2 rubber duckies that going all the way to the canopy. I sure hope there is less intrusive solution, even if it will reduce the range a little. BTW, I flew with my MRX PCAS antenna horizontally for years from the same reason and there was no noticable reduction in range, but I understand that powerflarm is much more sensitive to antenna installation. I sure hope a clean installation which does not interfere with visibility is available. After all, a powerflarm is no good if it reduces forward visibility. Ramy I was involved with installing about seven units and all were much more elegant than what you see on the web page. *Mine is installed about 4" in front on my compass that is on top of the glare screen. I only see the top 1.5 inches of the antenna which is very small and narrow. * Many others put the bulk below the glare screen with only the top 1.5 inches showing. It would be nice to see the antenna have the cable come in from one end rather than at the middle. Remember what you see so far were done in a loaned hanger on a rainy day in the midst of a contest. *Evan's is installed below and mine is very unobtrusive in flight. In a Schleicher installation, about 50% of the dipole will be below the glare shield. What's visible in my case may not be pretty, but I don't find it distracting or obstructing, any more so than my yaw string. I'll get some pics next opportunity. This really isn't a big deal, imo. If you think it might be a big deal, please keep an open mind until you see a good installation in a cockpit similar to what ever you fly. Evan Ludeman / T8 |
Similar Threads | ||||
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
If your bored, think about this and notes about Ely, Nv. | [email protected] | Soaring | 15 | February 9th 07 11:30 PM |
Notes from the RAP pre-OSH party | Viperdoc | Piloting | 2 | July 23rd 06 06:24 PM |
DG500 AD notes | Sailplane Mechanic | Soaring | 2 | August 27th 04 05:35 PM |
A few notes from Uvalde | Dave Nadler YO | Soaring | 0 | August 13th 04 05:26 PM |
